蓝桥杯CT117E STM32测试源程序
Xuewang2018
2018-7-5 19:03
“蓝桥杯”使用的CT117E嵌入式。
(44.46 KB, 下载次数: 22)
下载附件
2018-7-6 04:12 上传
/******************** (C) COPYRIGHT 2009 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V3.0.0
* Date : 04/06/2009
* Description : Virtual Com Port Demo main file
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stdio.h"
#include "main.h"
#include "lcd.h"
#include "i2c.h"
#include "adc_single.h"
#include "usart.h"
#include "stdlib.h"
#define COL(X) (319-(X)*16+16)
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t TimingDelay;
extern USART_TypeDef* USARTx;
extern vu16 dummy; //LCD型号定位
void Delay_Ms(__IO uint32_t nTime);
/* Extern variables ----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void)
/* GPIOA Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void GPIO_Configuration(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 |
GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_8;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
//void NVIC_Configuration(void)
// NVIC_InitTypeDef NVIC_InitStructure;
//#ifdef VECT_TAB_RAM
// /* Set the Vector Table base location at 0x20000000 */
// NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
//#else /* VECT_TAB_FLASH */
// /* Set the Vector Table base location at 0x08000000 */
// NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
//#endif
// /* Configure one bit for preemption priority */
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
// /* Enable the EXTI9_5 Interrupt */
// NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
// NVIC_Init(&NVIC_InitStructure);
//void delay()
// unsigned int i,j;
// for (i = 0;i<0xffff;++i)
// for(j=0;j<0x7f;++j);
* Function Name : main.
* Description : Main routine.
* Input : None.
* Output : None.
* Return : None.
int main(void)
int n;
// unsigned short Pin;
unsigned char lcd_type[4]; //保存LCD型号的数组
unsigned char bai,shi,ge;
float ad_value;
int toggle;
RCC_Configuration();
GPIO_Configuration();
GPIO_PinRemapConfig ( GPIO_Remap_SWJ_NoJTRST ,ENABLE);
// NVIC_Configuration();
i2c_init();
adc_init();
usart_init();
if (SysTick_Config(SystemCoreClock / 1000))
/* Capture error */
while (1);
n=x24c02_read(0xff);
Delay_Ms(10);
++n;
x24c02_write(0xff,n);
bai = n/100;
shi = (n-bai*100) / 10; //ADC数值的十号准备情况参考这些数值 Capture error
ge = n % 10; //ADC数值的个位准备情况参考这些数值 Capture error准备情况
STM3210B_LCD_Init();
LCD_Clear(Blue);
LCD_SetBackColor(Red);
/* Set the LCD Text Color */
LCD_SetTextColor(Grey);
lcd_type[0] = (dummy>>12)+'0';
lcd_type[1] = ((dummy&0x0f00)>>8)+'0';
lcd_type[2] = ((dummy&0x00f0)>>4)+'0';
lcd_type[3] = (dummy&0x000f)+ '0';
LCD_DisplayStringLine(Line0, " ");
LCD_DisplayStringLine(Line1, " Welcome to ");
LCD_DisplayStringLine(Line2, " ");
LCD_SetBackColor(Green);
// LCD_SetTextColor(Grey);
LCD_DisplayStringLine(Line4, " GXCT ");
LCD_DisplayStringLine(Line3, " ");
LCD_DisplayStringLine(Line5, " ");
LCD_SetBackColor(Blue);
LCD_DisplayStringLine(Line6, " ");
LCD_DisplayStringLine(Line7, " LCD TYPE: ");
LCD_SetTextColor(Yellow);
LCD_DisplayChar(Line7,COL(13),lcd_type[0]);
LCD_DisplayChar(Line7,COL(14),lcd_type[1]);
LCD_DisplayChar(Line7,COL(15),lcd_type[2]);
LCD_DisplayChar(Line7,COL(16),lcd_type[3]);
LCD_DisplayStringLine(Line8, " ");
LCD_DisplayStringLine(Line9, " ");
LCD_SetTextColor(Green);
LCD_DisplayChar(Line9,COL(19),ge+'0');
if ( n > 9 ) LCD_DisplayChar(Line9,COL(18),shi+'0');
if ( n > 99 ) LCD_DisplayChar(Line9,COL(17),bai+'0');
GPIO_Write(GPIOC,0xffff);
GPIO_SetBits(GPIOD,GPIO_Pin_2);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
while(1) {
if ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0) == RESET ) {
// Pin=GPIO_Pin_8 | GPIO_Pin_12;
GPIO_Write(GPIOC,0xfcff);
} else if ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_8) == RESET ) {
// Pin=GPIO_Pin_9 | GPIO_Pin_13;
GPIO_Write(GPIOC,0xf3ff);
} else if ( GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1) == RESET ) {
// Pin=GPIO_Pin_10 | GPIO_Pin_14;
GPIO_Write(GPIOC,0xcfff);
} else if ( GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_2) == RESET ) {
// Pin=GPIO_Pin_11 | GPIO_Pin_15;
GPIO_Write(GPIOC,0x3fff);
GPIO_ResetBits(GPIOB,GPIO_Pin_4);
} else {
GPIO_SetBits(GPIOB,GPIO_Pin_4);
// Pin=GPIO_Pin_8;
// for ( i=0;i<8;++i) {
// GPIO_SetBits(GPIOD,GPIO_Pin_2);
// GPIO_Write(GPIOC,Pin);
// GPIO_ResetBits(GPIOD,GPIO_Pin_2);
// delay();
// Pin<<=1;
ad_value= adc_read();
ge=ad_value;
shi=(int)(ad_value*10)%10;
bai= (int)(ad_value*100)%10;
LCD_SetTextColor(Red);
LCD_DisplayChar(Line9,COL(2),ge+'0');
LCD_DisplayChar(Line9,COL(3),'.');
LCD_DisplayChar(Line9,COL(4),shi+'0');
LCD_DisplayChar(Line9,COL(5),bai+'0');
USARTx = USART2;
if( (n=USART_getch()) != -1 ) {
LCD_DisplayChar(Line8,COL(12),n);
printf("USART2 Echo: %f\r\n",rand()*25./RAND_MAX);
// printf("USART2 Echo: %c\r\n",n);
USARTx = USART1;
LCD_DisplayChar(Line8,COL(9),n);
printf("USART1 Echo: %c\r\n",n);
toggle = ! toggle;
if ( toggle ) {
GPIO_SetBits(GPIOA,GPIO_Pin_1);
GPIO_SetBits(GPIOA,GPIO_Pin_4);
GPIO_SetBits(GPIOA,GPIO_Pin_5);
GPIO_SetBits(GPIOA,GPIO_Pin_6);
GPIO_SetBits(GPIOA,GPIO_Pin_7);
}else{
GPIO_ResetBits(GPIOA,GPIO_Pin_1);
GPIO_ResetBits(GPIOA,GPIO_Pin_4);
GPIO_ResetBits(GPIOA,GPIO_Pin_5);
GPIO_ResetBits(GPIOA,GPIO_Pin_6);
GPIO_ResetBits(GPIOA,GPIO_Pin_7);
TimingDelay = nTime;
…………限于本文篇幅 余下代码请从51黑下载附件…………
CT117E-测试程序.zip
(2.52 MB, 下载次数: 15)
2018-7-5 19:04 上传
点击文件名下载附件
下载积分: 黑币 -5
