QMA6981计步器配置
yongwow
2018-7-6 21:08
QMA6981计步器配置
固定4步来一个中断,停止走路时再来一个中断,灵敏度是10寄存器
bResult = gsensor_i2c_write_byte(0x10, 0x2a);
bResult = gsensor_i2c_write_byte(0x0f, 0x04);
bResult = gsensor_i2c_write_byte(0x12, 0x8f);
bResult = gsensor_i2c_write_byte(0x13, 0x10);
bResult = gsensor_i2c_write_byte(0x14, 0x14);
bResult = gsensor_i2c_write_byte(0x15, 0x10);
bResult = gsensor_i2c_write_byte(0x32, 0x02);
bResult = gsensor_i2c_write_byte(0x27, 0x60);
bResult = gsensor_i2c_write_byte(0x28, 0x60);
bResult = gsensor_i2c_write_byte(0x29, 0x60);
bResult = gsensor_i2c_write_byte(0x16, 0x08);
bResult = gsensor_i2c_write_byte(0x19, 0x08);
bResult = gsensor_i2c_write_byte(0x20, 0x00); // 低电平或者下降沿触发
//bResult = gsensor_i2c_write_byte(0x20, 0x05);// 高电平或者上升沿触发
bResult = gsensor_i2c_write_byte(0x11, 0x80);
