我用VHDL语言实现的简单CPU设计
ddw594230123
2018-7-14 18:20
我用VHDL语言实现的简单CPU设计
使用VHDL语言编写的一个课程设计,写了一个简单CPU,包含通用寄存器,PC寄存器,ALU等等,供大家参考
(42.02 KB, 下载次数: 62)
下载附件
2018-7-14 18:23 上传
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
package packexp is
function calculator(ch : std_logic_vector(2 downto 0);
da,db :std_logic_vector(7 downto 0))
return std_logic_vector;
end;
package body packexp is
function calculator(ch : std_logic_vector(2 downto 0); da,db : std_logic_vector(7 downto 0)) return std_logic_vector is
begin
case(ch) is
when "001" =>
return ('0' & (da and db));
when "010" =>
return ('0' & (da or db));
when "011" =>
return ('0' & (da xor db));
when "100" =>
return ('0' & da) + ('0' & db);
when "101" =>
return ('0' & da(6 downto 0) & '0');
when "110" =>
return ('0' & '0' & da(7 downto 1));
when "111" =>
return ('0' & da(7) & da(7 downto 1));
when others =>
return ("000000000");
end case;
end function calculator;
end;
library ieee;
use work.packexp.all;
entity ALU is
port(clk : in std_logic;
mode : in std_logic_vector(1 downto 0);
S : in std_logic_vector(2 downto 0);
Cin : in std_logic;
D : in std_logic_vector(7 downto 0);
Cout : out std_logic;
dataout : out std_logic_vector(7 downto 0));
end entity ALU;
architecture mainpart of ALU is
begin
process(clk)
variable A : std_logic_vector(7 downto 0) := (others => '0');
variable B : std_logic_vector(7 downto 0) := (others => '0');
variable dataa : std_logic_vector(7 downto 0) := (others => '0');
variable datab : std_logic_vector(7 downto 0) := (others => '0');
variable result : std_logic_vector(8 downto 0) := (others => '0');
begin
if(clk'event and clk = '1')
then
if(S = "000")
then
A := (others => '0');
B := (others => '0');
result := (others => '0');
dataout <= result(7 downto 0);
case(mode) is
when "00" =>
A := D;
dataout <= A;
when "01" =>
B := D;
dataout <= B;
when "11" | "10" =>
dataa := A;
datab := B;
result := calculator(S,dataa,datab);
if(S = "100")
then
result := result + ("00000000" & Cin);
Cout <= result(8);
Cout <= '0';
end if;
when others =>
null;
end case;
end if;
end if;
end process;
end mainpart;
9.ALU.rar
(5.49 MB, 下载次数: 55)
2018-7-14 18:18 上传
点击文件名下载附件
下载积分: 黑币 -5
FVESSK
2019-2-28 17:54
bucuo,支持一下。正好学习了VHDL,在做毕设
04016103
2019-4-21 13:17
我最近有个大作业也在做这个,但是管脚映射除了奇怪的问题。
file3:MBR port map(CLK=>CLK,RST=>RST,control_signal=>control_signal,from_memory=>spo_ram,from_ACC=>ACC_L,to_memory=>to_memory,MBR_out=>MBR_out,wren=>wren);
file12:RAM1 port map(a=>address(4 downto 0),d=>MBR_out,clk=>CLK,we=>wren,spo=>spo_ram);
其中from_memory是in 变量,spo是out变量,spo_ram是顶层文件的临时变量。现在仿真以后,spo和spo_ram都成功地读到了ram里面第一行的数据,但是from_mpmery就是没有这个变量,还是一个空值,使得后续所有的变量全部没用了。这到底是什么问题?
qq146803695
2019-12-25 16:48
支持下
