标题: 电子称控制程序 [打印本页]
作者: zcl302    时间: 2018-7-19 10:32
标题: 电子称控制程序
#include"reg51.h"
环宇电子秤系统  stc89C52单片机控制
12864 LCD显示    制作日期:2015/06/27
#define uint  unsigned int
unsigned char jian_ma,flag,jiao_flag,set_flag;
unsigned int   heavy,price=1,money,alarm=500,jiao_zhun=1010;              //相关变量定义   ,上限报警值初始值为500克
unsigned char menu,jia,jian,confr,fu,menu_flag,exit;
long data_num,data_temp,data_flash;
        unsigned char f=0;
        unsigned char code        table[]={" Welcome to you"};
                unsigned char code        table1[]={" Weight          "};
sbit IRIN = P3^3;         //红外接收器数据线
sbit ADDO=P1^0;              //ad采集数据接口
sbit ADSK= P1^1;           //ad采集时钟接口
sbit rs=P2^3;
sbit rw=P2^4;                   //液晶接口定义
sbit lcden=P2^5;
sbit bell=P3^6;    //蜂鸣器定义
sbit key=P2^7;    //按键定义
   #define Imax 14000    //此处为晶振为12时的取值, 红外解码
    #define Imin 8000    //如用其它频率的晶振时,
    #define Inum1 1450    //要改变相应的取值。
    #define Inum2 700
    #define Inum3 3000
          unsigned char Im[4]={0x00,0x00,0x00,0x00};
    unsigned long m,Tc;
void delay_ms(unsigned char x)    //x*0.14MS
unsigned char i;
  while(x--)
  for (i = 0; i<13; i++) {}
void delay(unsigned int t)                //延时函数
        uint x,y;
        for(x=t;x>0;x--)
        for(y=12;y>0;y--);
   /*    名称:写命令函数
      功能:向LED1602中写命令
  入口参数:uchar com
  出口参数:无
void write_com(unsigned char com)
        rs=0;
        rw=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
/*    名称:写数据函数
      功能:向LED1602中写数据
  入口参数:uchar date
  出口参数:无
void write_date(unsigned char date)
        rs=1;
        rw=0;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
/*    名称:初始化函数
      功能:初始化LED1602
  入口参数:无
  出口参数:无
void lcd_init()
        unsigned char num;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);    //清屏
        write_com(0x80);
        delay(5);
        write_com(0x80);
        for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
        delay(20000);
                write_com(0x80);
                        write_date(table1[num]);
                        delay(5);
void display( unsigned int weight,unsigned int bj,unsigned int vl)
{     unsigned int qian,bai,shi,ge;
              qian=(weight/1000)%10;
                   bai=(weight/100)%10;
                        shi=(weight/10)%10;
                        ge=weight%10;
               write_com(0x87);                //重量显示
                                write_date(':');
                                if(fu)                      //为赋值则显示负号
                                 fu=0;
                                        write_date('-');
                                        write_date(' ');
                                if(qian)
                               write_date(0x30+qian);
                   write_date(0x30+bai);
                   write_date(0x30+shi);
                   write_date(0x30+ge);
                                 if(bai)
                                     write_date(' ');
                                 if(shi)
                                              write_date(' ');
                    write_date(' ');
                                      write_date(' ');
                      write_date(' ');
                     write_date(' ');
                           write_date('g');
                            qian=(bj/1000)%10;
                   bai=(bj/100)%10;
                        shi=(bj/10)%10;
                        ge=bj%10;
                            write_com(0x80+0x40);          //报警值显示
                                  write_date('M');
                                write_date(':');
                                                if(qian)
                                 if(bai)
                                     write_date(' ');
                                 if(shi)
                                              write_date(' ');
                    write_date(' ');
                                      write_date(' ');
                      write_date(' ');
                     write_date(' ');
                          qian=(vl/1000)%10;        //校准值显示
                   bai=(vl/100)%10;
                        shi=(vl/10)%10;
                        ge=vl%10;
                            write_com(0x80+0x47);
                                  write_date('V');
                                write_date(':');
                                             if(qian)
                                 if(bai)
                                     write_date(' ');
                                 if(shi)
                                              write_date(' ');
                    write_date(' ');
                                      write_date(' ');
                      write_date(' ');
                     write_date(' ');
                                 if(set_flag)    //报警上限光标打开
                                            write_com(0x80+0x40);          //报警值闪烁
                                         write_com(0x0f);          //报警值显示
                                     write_date('M');
                                 if(jiao_flag)
                                         write_com(0x0f);          // 校准值闪烁
                                     write_date('V');
void  read_count()        //ad采集函数
  unsigned long count;
  unsigned char i;
  ADSK=0;//使能ad
  count=0;
  while(ADDO);  //等待ad转换结束
  for(i=0;i<24;i++)
    ADSK=1; //PD_SCK置高,发送脉冲
        count=count<<1;
//        delayp();
        ADSK=0;   //pd_sck置低
        if(ADDO)count++;
  ADSK=1;
  count=count^0x800000;        //第25个脉冲下降沿来时,转换数据
// delayp();
  ADSK=0;
data_num=count;   // 读出来的数据赋值给变量data_num
                                        蜂鸣器 报警
void beep()
        unsigned char i;
        for(i=0;i<20;i++)
                bell = 0;
                delay(40);
                bell = 1;
void price_change()                 //遥控按键扫描函数
jian_ma=jian_ma&0x1f;
if(jian_ma>=0x1f)
flag=0;
   if(flag)
      flag=0;
           switch (jian_ma)
                case 0x01:           //按下2号按键进入 校准值设定
                menu_flag=1;
                   jiao_flag=1;
                   set_flag=0;
                   beep();
                break;
                case 0x02:          //按下3号按键进入   报警值设定状态
                menu_flag=2;
                   jiao_flag=0;
                   set_flag=1;
                   beep();
                  break;
                   case 0x0c:              //*键进入清零
                   read_count();
               data_temp=data_num;
                   beep();
                   break;
                   case        0x11:          //加键
                          jia=1;
                        beep();
                   break;
                    case 0x19:          //减键
                          jian=1;
                        beep();
                   break;
                   case 0x15:
                    flag=0;
                      menu_flag=0;//按下ok按键退出
                          set_flag=0;
                          jiao_flag=0;
                          write_com(0x0c);
                          beep();
                          exit=1;
                   break;
void sao_miao()//按键扫描函数
     if(key==0)
            delay(10);
           if(!key)
                     while(!key);
                     read_count();
                         delay(500);
                         read_count();
                         data_temp=data_num;        //重新读取ad采集值,进入清零功能
void chu_li()         //单价设定函数
price_change();                   //遥控按键扫描函数
    while(menu_flag)                //对遥控按键的处理
                   price_change();
                                  if(set_flag)                  //报警值设定
                                      if(jia)
                                           jia=0;
                                           if(alarm<5000)   //最大数值为5000
                                           alarm++;
                                         if(jian)
                                           jian=0;
                                                   if(alarm>=2)   //最小数值为1
                                                alarm--;
                                   if(jiao_flag)          //校准值设定
                                              if(jia)
                                                   jia=0;
                                                   if(jiao_zhun<5000)   //最大数值为5000
                                                   jiao_zhun++;
                                                 if(jian)
                                                   jian=0;
                                                           if(jiao_zhun>=2)   //最小数值为1
                                                        jiao_zhun--;
                                   delay(500);
                                                read_count();
                      if(data_num>=data_temp)                          // 比较采集出来的数值与临时变量
                          data_num=(data_num-data_temp);
                                          heavy=(unsigned int)(data_num/jiao_zhun);//1677;         //计算重量
                         delay(5000);
                                  display(heavy,alarm,jiao_zhun);
   sao_miao();   //按键扫描函数
                                                主函数
    uchar i=0;
        IRIN=1;                    //I/O口初始化
              m=0;
    f=0;
        lcd_init();
    IT1=1;
    EX1=1;           //开外部中断
    TMOD=0x11;   //定时器方式
    TH0=0;
        TL0=0;
    TR0=1;         //开定时器
        EA=1;         //开总中断
        P0=0;
        delay(50);
        delay(100);
         read_count();                   //ad采集函数
         delay(3000);
           delay(3000);
                   data_temp=data_num;  //采集数据赋值给临时变量 data_temp
           read_count();
          data_num=(data_temp-data_num);
          if(data_num>=500)
              fu=1;
                 fu=0;
                 data_num=0;
            delay(500);
                data_flash=heavy*price;                 // 总价=单价*重量
                money=(unsigned int)data_flash;
                if(exit)        //如果进行了设置
                   exit=0;
                   //show() ;              //显示刷新
         display(heavy,alarm,jiao_zhun);        //计算完成后送到液晶显示
          delay(500);
          chu_li();        //扫描函数
           if(heavy>alarm)                   //重量超过上限报警
              beep();
           delay(500);
//外部中断解码程序
  void intersvr1(void) interrupt 2 using 1
    Tc=TH0*256+TL0;                                               //提取中断时间间隔时长
    TH0=0;
    TL0=0;              //定时中断重新置零
if((Tc>Imin)&&(Tc<Imax))        //定时器判断读取的启始码正确
        m=0;
        f=1;
        return;
      }       //找到启始码
   if(f==1)
        if(Tc>Inum1&&Tc<Inum3)
   Im[m/8]=Im[m/8]>>1|0x80; m++;
      if(Tc>Inum2&&Tc<Inum1)
         Im[m/8]=Im[m/8]>>1; m++; //取码
  if(m==32)
                         m=0;
                         f=0;
                       if(Im[2]==~Im[3])
                           flag=1;
                                 jian_ma=Im[2];
                        else flag=0;   //取码完成后判断读码是否正?
          if(jian_ma==0x15)
               //准备读下一码
开发板原理图.pdf
625.91 KB, 下载次数: 16, 下载积分: 黑币 -5
作者: kanwenhong    时间: 2020-11-20 21:34
请教一下,用单片机电子称通过改写程序可以制作密度计吗?
