标题: LCD液晶发送数据 飞思卡尔单片机 [打印本页]
作者: Fan09    时间: 2018-8-14 12:11
#include "derivative.h"      /* derivative-specific definitions */
#include "LCD.h"
unsigned char adress_table[]=                 //定义液晶点阵的坐标
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,      //第一行汉字位置
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,      //第二行汉字位置
0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,      //第三行汉字位置
0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F       //第四行汉字位置
/*                      初始化液晶接口                       */
void INIT_PORT(void)
PSB_dir = 1;
RS_dir = 1;
RW_dir = 1;
EN_dir = 1;
DATA_dir = 0xff;
DATA = 0;
PSB = 1;
EN = 0;
RW = 0;
RS = 0;
/*                     向液晶发送数据                        */
void write_Data(unsigned char b)
     RS = 1;
     RW = 0;
     EN = 1;
     somenop();
     DATA = b;
     somenop();
     EN = 0;
/*                      向液晶发送命令                       */
void write_command(unsigned char b)
     RS = 0;
     RW = 0;
     EN = 1;
     somenop();
     DATA = b;
     somenop();
     EN = 0;
/*                         延时函数1                         */
void delay20us(unsigned int n)
    unsigned int i;
    for(i=0;i<n;i++)
        TFLG1_C0F = 1;              //清除标志位
        TC0 = TCNT + 5;             //设置输出比较时间为20us
        while(TFLG1_C0F == 0);      //等待,直到发生输出比较事件
/*                         延时函数2                         */
void delay1ms(unsigned int n)
    unsigned int i;
    for(i=0;i<n;i++)
        TC0 = TCNT + 250;             //设置输出比较时间为1ms
/*                            清屏子程序                                   */
void lcd_clear(void)
    write_command(0x30);//0011,0000 功能设置,一次送8位数据,基本指令集
    delay20us(4);       //延时80us
    write_command(0x03);//AC归0,不改变DDRAM内容
    delay1ms(5);        //延时5ms
    write_command(0x01);//0000,0001 清DDRAM
    write_command(0x06);//写入时,游标右移动
    write_command(0x0C);//0000,1100  整体显示,游标off,游标位置off
/*                           向LCD发送字符串                               */
void lcd_string(unsigned char row,unsigned char col,char *data1)   //row为写入数据所在的行数,col为写入数据所在的列数,*data1为写入的数据
  for(;row<4&&(*data1)!=0;row++)
      for(;col<8&&(*data1)!=0;col++)
          write_command(adress_table[row*8+col]);
          write_Data(*data1++);
      col=0;
