标题: STM32F103产生PWM波并计算发送个数源码 [打印本页]
作者: 张超01    时间: 2018-8-21 13:37
#include "stm32f10x.h"
#include "user_Config.h"
#include "stm32_eval.h"
#include <stdio.h>
void start_run(void);
void stop_run(void);
uint8_t  flag =0;
uint8_t  stop_flag =0;    //运转标志
uint8_t  auto_flag =0;
uint8_t  auto_flag1 =0;
uint32_t count =0;
uint32_t round =0;
uint32_t speed_cal = 750;
延时函数
void Delay(vu32 nCount)
        uint32_t a;
        uint32_t b;
  for(a=nCount;a>0;a--)
                for(b=8000;b>0;b--);
配置时钟函数
void RCC_Configuration(void)
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
pwm波产生管脚设置
void GPIO_pwm_Configuration(void)
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   //复用推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
正反转及调速
void GPIO_key_Configuration(void)
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
步进电机驱动器使能及方向控制
void GPIO_type_Configuration(void)
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOC,GPIO_Pin_0);
        GPIO_SetBits(GPIOC,GPIO_Pin_1);
定时器设置
void pwm(void)
  TIM_TimeBaseStructure.TIM_Period = speed_cal;
  TIM_TimeBaseStructure.TIM_Prescaler = 3-1;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM3, TIM_FLAG_Update);
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = speed_cal/2;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  //TIM_Cmd(TIM3, DISABLE);
中断优先级设置
void TIM3_NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  NVIC_Init(&NVIC_InitStructure);
中断函数(统计脉冲个数)
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3,TIM_IT_Update!=RESET))
                TIM_ClearITPendingBit(TIM3,TIM_FLAG_Update);
                count++;
                if(count == 768750)
                        count = 0;
                        round++;
                if(round == 5)
                        round = 0;
                        if(flag == 1)
                                if(auto_flag == 0)
                                        auto_flag = 1;
                                        stop_run();
                                        Delay(2000);
                                        GPIO_SetBits(GPIOC,GPIO_Pin_0);
                                        start_run();
                                        auto_flag = 0;
                                        stop_run();
                                        Delay(2000);
                                        start_run();
开始发送pwm
        TIM_Cmd(TIM3, ENABLE);
关闭发送pwm
void stop_run(void)
正传
void start_scan1(void)
        if(stop_flag == 0)
                if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_12)==0)
                        Delay(200);
                                start_run();
                                stop_flag = 1;
                                while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_12));
反转
void start_scan2(void)
        if(stop_flag == 0)
                if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_13)==0)
                        Delay(200);
                                start_run();
                                stop_flag =1;
                                while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_13));
停止
void stop_scan(void)
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_15)==0)
                Delay(200);
                        stop_run();
                        Delay(1500);
                        stop_flag = 0;
                        while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_15));
调速
void change_speed(void)
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==0)
                Delay(200);
                        if(speed_cal == 750)
                                speed_cal = 375;
                                speed_cal = 750;
                        TIM3->ARR = speed_cal;
                        pwm();
                        //TIM_Cmd(TIM3, ENABLE);
                        while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14));
自动旋转
void auto_run(void)
        if(stop_flag == 0)
                if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11)==0)
                        Delay(200);
                                if(auto_flag1 == 0)
                                        auto_flag1 =1;
int main(void)
  RCC_Configuration();
  GPIO_pwm_Configuration();
  GPIO_key_Configuration();
  GPIO_type_Configuration();
  TIM3_NVIC_Configuration();
  pwm();
  while (1)
                auto_run();
                if(auto_flag1 ==0)
                        start_scan1();
                        start_scan2();
                        stop_scan();
                        change_speed();
                        if(flag == 0)
                                flag = 1;
                                start_run();
                                Delay(200);
                                        stop_run();
                                        auto_flag1 =0;
