求助,帮忙完善程序 缺少使用矩阵键盘控制单价,然后计算物品金额并累加
路人君
2018-8-22 17:37
因为刚才有乱码,所以我重发一下,还是刚才的问题,缺少一个通过矩阵键盘控制单价,以及计算物品金额并实现金额累加并显示......
#include <reg52.h>
#include <stdio.h>
#include <math.h>
#include <intrins.h>
#define DataPort P0
#define KeyPort P1
unsigned char KeyScan(void);//键盘扫描
unsigned char KeyPro(void);
sbit ADDO = P3^6;
sbit ADSK = P3^7;
sbit rest = P3^5;
unsigned int num;
unsigned int poi;
unsigned int dnf;
unsigned int i;
LCD12864引脚接口
sbit RS = P2^4;
sbit RW = P2^5;
sbit E = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define KeyPort P1
unsigned char temp[16];
unsigned char lol[16];
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned char t)
while(t--)
//大致延时1mS
DelayUs2x(245);
DelayUs2x(245);
检测忙位
void Check_Busy()
RS=0;
RW=1;
E=1;
DataPort=0xff;
while((DataPort&0x80)==0x80);//忙则等待
E=0;
写命令
void Write_Cmd(unsigned char Cmd)
Check_Busy();
RS=0;
RW=0;
E=1;
DataPort=Cmd;
DelayUs2x(5);
E=0;
DelayUs2x(5);
写数据
void Write_Data(unsigned char Data)
Check_Busy();
RS=1;
RW=0;
E=1;
DataPort=Data;
DelayUs2x(5);
E=0;
DelayUs2x(5);
液晶屏初始化
void Init_ST7920()
DelayMs(40); //大于40MS的延时程序
PSB=1; //设置为8BIT并口工作模式
DelayMs(1); //延时
RES=0; //复位
DelayMs(1); //延时
RES=1; //复位置高
DelayMs(10);
Write_Cmd(0x30); //选择基本指令集
DelayUs2x(50); //延时大于100us
Write_Cmd(0x30); //选择8bit数据流
DelayUs2x(20); //延时大于37us
Write_Cmd(0x0c); //开显示(无游标、不反白)
Write_Cmd(0x01); //清除显示,并且设定地址指针为00H
DelayMs(15); //延时大于10ms
Write_Cmd(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
显示字符串
x:横坐标值,范围0~8
y:纵坐标值,范围1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char *s)
switch(y)
case 1: Write_Cmd(0x80+x);break;
case 2: Write_Cmd(0x90+x);break;
case 3: Write_Cmd(0x88+x);break;
case 4: Write_Cmd(0x98+x);break;
default:break;
while(*s>0)
Write_Data(*s);
s++;
DelayUs2x(50);
清屏
void ClrScreen()
Write_Cmd(0x01);
DelayMs(15);
延时函数
void delay(uchar z)
uchar x;
for(;z>0;z--)
for(x=22;x>0;x--);
unsigned long ReadCount(void)
unsigned long Count; unsigned char i;
ADSK=0; //使能AD(PD_SCK 置低)
Count=0;
while(ADDO); //AD转换未结束则等待,否则开始读取
for (i=0;i<24;i++)
ADSK=1; //PD_SCK 置 高 ( 发 送 脉 冲 )
Count=Count<<1; //下降沿来时变量Count左移一位,右侧补零
ADSK=0; //PD_SCK 置低
if(ADDO) Count++;
ADSK=1;
Count=Count^0x800000;//第25个脉冲下降沿来时,转换数据
ADSK=0;
return(Count);
//jjjjjjjjj
unsigned char KeyScan(void) //键盘扫描函数,使用行列反转扫描法
unsigned char cord_h,cord_l;//行列值中间变量
KeyPort=0x0f; //行线输出全为0
cord_h=KeyPort&0x0f; //读入列线值
if(cord_h!=0x0f) //先检测有无按键按下
DelayMs(10); //去抖
if((KeyPort&0x0f)!=0x0f)
KeyPort=cord_h|0xf0; //输出当前列线值
cord_l=KeyPort&0xf0; //读入行线值
while((KeyPort&0xf0)!=0xf0);//等待松开并输出
return(cord_h+cord_l);//键盘最后组合码值
}return(0xff); //返回该值
按键值处理函数,返回扫键值
switch(KeyScan())
case 0x7e:return 0;break;//0 按下相应的键显示相对应的码值
case 0x7d:return 1;break;//1
case 0x7b:return 2;break;//2
case 0x77:return 3;break;//3
case 0xbe:return 4;break;//4
case 0xbd:return 5;break;//5
case 0xbb:return 6;break;//6
case 0xb7:return 7;break;//7
case 0xde:return 8;break;//8
case 0xdd:return 9;break;//9
case 0xdb:return 10;break;//a
case 0xd7:return 11;break;//b
case 0xee:return 12;break;//c
case 0xed:return 13;break;//d
case 0xeb:return 14;break;//e
case 0xe7:return 15;break;//f
default:return 0xff;break;
主程序
main()
char v=0;
unsigned long weight ;
unsigned long heavy ;
float heavy1 ;
int d1,d2;
ClrScreen();
Init_ST7920(); //初始化
heavy= ReadCount(); DelayMs(100);
while (1)
for( v=0;v<2;v++)
{ weight += ReadCount(); }
weight =weight/3;
heavy1= weight-heavy ;
heavy1= (float)heavy1/2286.3;
DelayMs(150); DelayMs(150);
if(heavy1>10000)heavy1=0;
d1 = weight / 1000; d2 = weight % 1000;
//int num=KeyPro();
dnf=heavy1;
num=1;
poi=num*dnf;
i=poi;
sprintf(temp,"重量:%5.2f g " ,heavy1 );
LCD_PutString(0,1, temp);
sprintf(temp,"单价:%4d 元/g ",num);
LCD_PutString(0,2, temp);
sprintf(lol,"总价:%4d 元/g",poi);
LCD_PutString(0,3, lol);
sprintf(temp," %4d%-d ",d1,d2);
LCD_PutString(0,4, temp);
DelayMs(200);
if(!rest)
{DelayMs(10);
if(!rest)
while(!rest);
{ heavy= ReadCount();} }
路人君
2018-8-22 18:31
想到一个解决方案,我设置两个按键,然后一个负责记录当前总价,一个负责输出共计金额,然后这样的程序应该怎么写呢
