标题: 这个怎么外接12864啊 [打印本页]
作者: 路人君    时间: 2018-8-24 14:32
标题: 这个怎么外接12864啊
#include <reg52.h>
#include <stdio.h>
#include <math.h>
#include <intrins.h>
#define KeyPort P0
#define DataPort P0
  sbit ADDO = P1^6;
  sbit ADSK = P1^7;
unsigned int num;
unsigned int dnf;
float i;
unsigned int priceV;
  LCD12864引脚接口
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
unsigned char temp[16];
unsigned char lol[16];
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned char t)
while(t--)
     //大致延时1mS
     DelayUs2x(245);
         DelayUs2x(245);
                    检测忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙则等待
    E=0;
                   写命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    写数据
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延时程序
   PSB=1;                 //设置为8BIT并口工作模式
   DelayMs(1);            //延时
   RES=0;                 //复位
   DelayMs(1);            //延时
   RES=1;                 //复位置高
   DelayMs(10);
   Write_Cmd(0x30);       //选择基本指令集
   DelayUs2x(50);         //延时大于100us
   Write_Cmd(0x30);       //选择8bit数据流
   DelayUs2x(20);         //延时大于37us
   Write_Cmd(0x0c);       //开显示(无游标、不反白)
   Write_Cmd(0x01);       //清除显示,并且设定地址指针为00H
   DelayMs(15);           //延时大于10ms
   Write_Cmd(0x06);       //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
                   显示字符串
x:横坐标值,范围0~8
y:纵坐标值,范围1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char *s)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                   延时函数
void delay(uchar z)
        uchar x;
        for(;z>0;z--)
                for(x=22;x>0;x--);
unsigned long ReadCount(void)
unsigned long Count; unsigned char i;
ADSK=0;        //使能AD(PD_SCK 置低)
Count=0;
while(ADDO);        //AD转换未结束则等待,否则开始读取
for (i=0;i<24;i++)
ADSK=1;        //PD_SCK 置 高 ( 发 送 脉 冲 )
Count=Count<<1; //下降沿来时变量Count左移一位,右侧补零
ADSK=0;        //PD_SCK 置低
if(ADDO) Count++;
ADSK=1;
Count=Count^0x800000;//第25个脉冲下降沿来时,转换数据
ADSK=0;
return(Count);
按键扫描函数,返回扫描键值
unsigned char KeyScan(void)  //键盘扫描函数,使用行列反转扫描法
unsigned char cord_h,cord_l;//行列值中间变量
KeyPort=0x0f;            //行线输出全为0
cord_h=KeyPort&0x0f;     //读入列线值
if(cord_h!=0x0f)    //先检测有无按键按下
  DelayMs(10);        //去抖
  if((KeyPort&0x0f)!=0x0f)
    KeyPort=cord_h|0xf0;  //输出当前列线值
    cord_l=KeyPort&0xf0;  //读入行线值
    while((KeyPort&0xf0)!=0xf0);//等待松开并输出
    return(cord_h+cord_l);//键盘最后组合码值
  }return(0xff);     //返回该值
          按键值处理函数,返回扫键值
           可以根据需要改变返回值
                          | 1 | 2 | 3 | + |
                          | 4 | 5 | 6 | - |
                          | 7 | 8 | 9 | * |
                          | 0 | . | = | / |
unsigned char KeyPro(void)
switch(KeyScan())
        case 0x77:return  1  ;break;//1
        case 0x7b:return  2  ;break;//2
        case 0x7d:return  3  ;break;//3
        case 0xb7:return  4  ;break;//4
        case 0xbb:return  5  ;break;//5
    case 0xbd:return  6  ;break;//6
    case 0xd7:return  7  ;break;//7
        case 0xdb:return  8  ;break;//8
    case 0xdd:return  9  ;break;//9
    case 0xe7:return 10 ;break;//*
    case 0x7e:return 11;break;//A  设置单价
    case 0xbe:return 12 ;break;//B         去皮
    case 0xde:return 13 ;break;//C  附加功能
    case 0xee:return 14 ;break;//D    重置
        case 0xed:return 15 ;break;//#
    case 0xeb:return 16  ;break;//0
  default:return 0;break;
              主程序
main()
int priceV;
char v=0;
unsigned long   weight   ;
unsigned long   heavy  ;
float                     heavy1 ;
float           poi;
int d1,d2;
        ClrScreen();
    Init_ST7920();   //初始化
heavy= ReadCount();        DelayMs(100);
while (1)
for( v=0;v<6;v++)
  {        weight += ReadCount();     }
  weight =weight/7;
heavy1= weight-heavy  ;
heavy1= (float)heavy1/1834.5;
        DelayMs(150);        DelayMs(150);
if(heavy1>10000)heavy1=0;
d1 = weight / 1000;        d2 = weight % 1000;
num=KeyPro();
poi=priceV*heavy1*10;
        switch(num)
        case 1:        priceV*=10; priceV+=1;            break;                // 1
        case 2:        priceV*=10; priceV+=2;                break;                 // 2
        case 3:        priceV*=10; priceV+=3;                break;                 // 3
        case 4:        priceV*=10; priceV+=4;                break;                 // 4
        case 5:        priceV*=10; priceV+=5;                break;                 // 5
        case 6:        priceV*=10; priceV+=6;                break;                 // 6
        case 7:        priceV*=10; priceV+=7;                break;                 // 7
        case 8: priceV*=10; priceV+=8;                break;                 // 8
        case 9: priceV*=10; priceV+=9;                break;                 // 9
        case 16: priceV*=10;                         break;
        case 15: priceV=0;                        break;                  // 0
        case 11: heavy= ReadCount();        break;
        case 12: i+=poi;                    break;
    case 13: i=0;                       break;
                sprintf(temp,"重量:%5.2f g       " ,heavy1 );
                LCD_PutString(0,1, temp);
                sprintf(lol,"单价:%4d 元/g   ",priceV);
                LCD_PutString(0,2, lol);
                sprintf(lol,"总价:%4.1f 元/g  ",poi/10);
                LCD_PutString(0,3, lol);
//                sprintf(lol,"共计:%4.1f 元/g  ",i/10);
//            LCD_PutString(0,4, lol);
                sprintf(temp," %4d%-d          ",d1,d2);
            LCD_PutString(0,4, temp);
                DelayMs(200);
if(heavy1>503)
   ClrScreen();
   sprintf(lol,"警告警告警告警告");
            LCD_PutString(0,1, lol);
                DelayMs(200);
现在不会外接12864
作者: sxhwdz    时间: 2018-8-24 17:29
  LCD12864引脚接口
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
就按这个接呀
作者: HC6800-ES-V2.0    时间: 2018-8-25 08:08
程序有问题吧?!
你的P0被改名两次:
#define KeyPort P0
#define DataPort P0
作者: 726434632    时间: 2018-8-25 09:18
HC6800-ES-V2.0 发表于 2018-8-25 08:08
程序有问题吧?!
你的P0被改名两次:
#define KeyPort P0
按键跟12864的数据口复用了吧
