STM32不连续IO口矩阵键盘程序源码
zlkj
2018-8-27 21:46
STM32不连续IO口矩阵键盘程序源码
不连续IO口矩阵键盘
#include "pkey.h"
#include "delay.h"
#include "sys.h"
void HardwareInit(void);
int main(void)
HardwareInit();
GetKeyVal();
uart_init(9600); //串口,便于观察
Key_Config(); //按键初始化
delay_init(); //延时函数
#include "pkey.h"
#include "delay.h"
#include "sys.h"
** PB5-PB8,列,输出。 PB10-PB14,行,输入
void Key_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
/********4行输出*********/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11| GPIO_Pin_12 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/********4列输入*********/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_Init(GPIOD, &GPIO_InitStructure);
int KeyScan(void)
uchar KeyVal;
GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x1C00)); //不管其余12位0xf0ff,先让PC10到PC12全部输出高。
GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x8000)); //不管其余12位0xf0ff,先让PA15输出高。
if(((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004))==0x0000) //如果PB12到PB15全为零则没有按键按下
return -1;
delay_ms(5); //延时5ms去抖动
return -1;
GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0000)); //不管其余12位0xf0ff,先让PC10到PC12全部输出高。
switch((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004)) //第一行,由低到高,同理,不赘述
case 0x0004: KeyVal=13; break;
case 0x0008: KeyVal=12; break;
case 0x0010: KeyVal=11; break;
case 0x0020: KeyVal=10; break;
while((GPIOB->IDR & 0x0038)|(GPIOD->IDR & 0x0004) > 0); //等待按键释放
GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0400)); //不管其余12位0xf0ff,先让PC10到PC12全部输出高。
GPIO_Write(GPIOA, (GPIOA->ODR & 0x7FFF | 0x0000)); //不管其余12位0xf0ff,先让PA15输出高。
case 0x0004: KeyVal=14; break;
case 0x0008: KeyVal=9; break;
case 0x0010: KeyVal=6; break;
case 0x0020: KeyVal=3; break;
GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x0800)); //不管其余12位0xf0ff,先让PC10到PC12全部输出高。
case 0x0004: KeyVal=0; break;
case 0x0008: KeyVal=8; break;
case 0x0010: KeyVal=5; break;
case 0x0020: KeyVal=2; break;
GPIO_Write(GPIOC, (GPIOC->ODR & 0xE3FF | 0x1000)); //不管其余12位0xf0ff,先让PC10到PC12全部输出高。
case 0x0004: KeyVal=15; break;
case 0x0008: KeyVal=7; break;
case 0x0010: KeyVal=4; break;
case 0x0020: KeyVal=1; break;
// printf("%#x\n ",(GPIOB->IDR & 0x0038));
// printf("%#x\n ",(GPIOD->IDR & 0x0004));
// //printf("%#x\n ",(GPIOD->IDR & 0x0004)|(GPIOB->IDR & 0x0038));
return KeyVal;
按键表盘为: 0 1 2 3
4 5 6 7
8 9 10 11
12 13 14 15
void GetKeyVal(void)
int num;
num = KeyScan();
switch(num)
case 0: printf("0\n"); break;
case 1: printf("1\n"); break;
case 2: printf("2\n"); break;
case 3: printf("3\n"); break;
case 4: printf("4\n"); break;
case 5: printf("5\n"); break;
case 6: printf("6\n"); break;
case 7: printf("7\n"); break;
case 8: printf("8\n"); break;
case 9: printf("9\n"); break;
case 10: printf("10\n"); break;
case 11: printf("11\n"); break;
case 12: printf("12\n"); break;
case 13: printf("13\n"); break;
case 14: printf("14\n"); break;
case 15: printf("15\n"); break;
不连续IO口矩阵键盘.rar
(281.38 KB, 下载次数: 11)
2018-8-27 22:57 上传
点击文件名下载附件
下载积分: 黑币 -5
admin
2018-8-27 22:58
补全原理图或者详细说明一下电路连接即可获得100+黑币
