标题: STM32F302的TIM1时钟问题,用8MHz内部HSI老是设置不到72MHz作为TIM1的计数频率值 [打印本页] 作者: 过往云烟 时间: 2018-8-30 20:52 标题: STM32F302的TIM1时钟问题,用8MHz内部HSI老是设置不到72MHz作为TIM1的计数频率值 我看了STM32F10x系列的数据手册,一样的,用内部HSI是没有办法到达72MHz。因为在RCC配置寄存器中
Bit 16 PLLSRC: PLL entry clock source
Set and cleared by software to select PLL clock source. This bit can be written only when
PLL is disabled.
0: HSI/2 selected as PLL input clock
1: HSE/PREDIV selected as PLL input clock (refer to Section 8.4.12: Clock configuration
register 2 (RCC_CFGR2) on page 115
