标题: 想问下我这stm8s的关于外部中断的程序哪里不对?外部中断部分没运行 [打印本页]
作者: lwf1    时间: 2018-8-31 20:26
#include "iostm8s103f3.h"
#include "intrinsics.h"
typedef unsigned char uchar;
typedef unsigned int  uint;
#define K1  PD_IDR_IDR6
#define LED PA_ODR_ODR2
void delay(uint i)
  while(i--);
void LED_Init()
  PA_DDR_DDR2 = 1;
  PA_CR1_C12  = 1;
  LED = 0;
void KEY_Init()
  PD_DDR_DDR6 = 0;
  PD_CR1_C16  = 1;
  PD_CR2_C26  = 1;
void EXTI_Init()
  EXTI_CR1_PDIS = 2;
  __enable_interrupt();
int main( void )
  LED_Init();
  KEY_Init();
    EXTI_Init();
__interrupt void EXTI_PORTD_IRQHandler(void)
  if(K1 == 0)
    delay(1000);
    if(K1 == 0)
      LED = ~LED;
    while(!K1);
