Error[Lp011]: section placement failed IAR报错怎么解决?
Aretiades
2018-9-18 17:54
使用IAR出现这个问题,自己查了下有的说是RAM不够了, 但是不知道怎么解决,有大神指导指导的嘛
unable to allocate space for sections/blocks with a total estimated minimum size of 0x4418 bytes (max
align 0x8) in <[0x00000000-0x00000000], [0x08000000-0x08003fff], [0x20000000-0x200007ff]> (total uncommitted
space 0x4741).
Uncommitted:
[0x00000000-0x00000000]: 0x1
[0x08000000-0x08003fff]: 0x3f40
[0x20000000-0x200007ff]: 0x800
Needed:
[0x08000000-0x08003fff]: 0x3f42 min, align 0x4 (size: 0x4001)
[0x20000000-0x200007ff]: 0x4d3 min, align 0x8 (size: 0x801)
Error while running Linker
Total number of errors: 1
Total number of warnings: 0
zhaohj95
2018-9-19 10:09
试试增加stack & heap大小
Aretiades
2018-9-20 11:24
谢谢,已经解决了,是flash空间不够了,我把优化等级调高了就可以了
dashiz
2018-10-30 21:57
我也碰到类似问题,请问怎么调优先等级?
xieming258
2019-5-5 10:51
今天我也遇到了同样的问题,按照楼主说的方法,还是不行,请楼主赐教,谢谢!
