void quit()
mysql_close(&mysql);
printf("数据库已关闭 \n");
exit(1);
int main()
mysql_init(&mysql);
if (!mysql_real_connect(&mysql,"localhost", "root", NULL, "test",0,NULL,0))
printf( "Error connecting to database: %s",mysql_error(&mysql));
printf("Connected...\n");
int choice;
menu();
printf("\n\t请选择:");
scanf("%d",&choice);
switch(choice)
case 1:show();break;
case 2:insert();break;
case 3:delete();break;
case 4:search();break;
case 5:updata();break;
case 0:quit();
return 0;
}作者: bouna 时间: 2020-3-19 20:23
where is the database ?作者: bouna 时间: 2020-3-23 20:09
thank you so much
