[原创]31行代码搞定LCD1602显示Proteus仿真程序(C&汇编)基于编址技术
psuxaog
2018-10-10 20:26
单片机LCD1602显示仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
(14.25 KB, 下载次数: 77)
下载附件
2018-10-10 20:25 上传
typedef unsigned int uint;
typedef unsigned char uchar;
uchar xdata LCD_CW _at_ 0xfcfc;
uchar xdata LCD_DW _at_ 0xfdfd;
uchar xdata LCD_CR _at_ 0xfefe;
#define WHILE_BUSY while(LCD_CR & 0x80)
void print(uchar *str,uchar addr)
WHILE_BUSY;//不能少!!!
LCD_CW = 0x80 | addr;
while(*str!='\0')
WHILE_BUSY;
LCD_DW=*str;
str++;
LCD_CW=0x0c;
WHILE_BUSY;
LCD_CW=0x38;
print("LCD Disp Program",0x00);//0x00~0x0f表示第一行0到15字符
print("Happy New Year! ",0x41);//0x40~0x4f表示第二行0到15字符
while(1);
LCD_CW EQU 0FCFCH
LCD_DW EQU 0FDFDH
LCD_CR EQU 0FEFEH
ORG 0000H
LJMP LCD_INIT
ORG 0030H
LCD_INIT:
MOV SP,#60H
MOV R3,#0CH
CALL LCD_WCMD
MOV R3,#38H
CALL LCD_WCMD
MOV R1,#HELLO
MOV R3, #80H
CALL LCD_WCMD
CALL PRINT
MOV R3, #0C1H
MOV R1,#HELLO
CALL LCD_WCMD
CALL PRINT
LJMP $
PRINT:
PRINT_LOOP:
MOV A,R1
MOVC A,@A+DPTR
MOV R3, A
CALL LCD_WDAT
INC R1
JNZ PRINT_LOOP
RET
LCD_WDAT:
MOV A, 'D'
MOV DPTR,#LCD_DW
MOVX @DPTR,A
CALL WHILE_BUSY
RET
LCD_WCMD:
MOV A, R3
MOV DPTR,#LCD_CW
MOVX @DPTR, A
CALL WHILE_BUSY
RET
WHILE_BUSY:
MOV DPTR,#LCD_CR
MOVX A, @DPTR
MOV 29H,A
JB 29H.7, WHILE_BUSY
RET
HELLO:
DB "HAPPY NEW YEAR! ",0
END
以上是两种语言编写,可选用一种
基于编址技术的LCD1602显示程序.rar
(92.93 KB, 下载次数: 14)
2018-10-10 20:25 上传
点击文件名下载附件
下载积分: 黑币 -5
