标题: 有没有哪位大佬,小哥哥,小姐姐帮我看看,我这个为什么分进一时也进一,哪里出错.... [打印本页]
作者: 1017871553    时间: 2018-10-18 09:06
#include<reg52.h>
typedef unsigned char u8;
typedef unsigned int  u16;
#define DATA P0
sbit seg_sel = P1^4;
sbit bit_sel = P1^5;
sbit K0=P1^0;
sbit K1=P1^1;
sbit K2=P1^2;
u8        s=0,min=0,h=0,ms=0;
u8 n=0;
u8        run_flag;                //?run_flag?1,??????
u8  temp_buf[5][3];
u8  arr_pt;
u8 code seg_tab[]={                                                        //¿ØÖÆêyÂë1üÏÔê¾
                          0xc0,0xf9,0xa4,0xb0,
                          0x99,0x92,0x82,0xf8,
                          0x80,0x90};
u8 code bit_tab[]={                                                        //¿ØÖÆμú¼¸Î»éá˸
                          0x10,0x20,0x40,0x80,
                          0x01,0x02,0x04,0x08
void delay(unsigned int y) //Ñóê±oˉêy
        unsigned int x,z;
        for(x=y; x>0; x--)
                for(z=110; z>0; z--);
void display_led(u8 which_bit, u8 which_number)
        bit_sel = 1;//Q[7..0]=D[7..0]
        DATA = bit_tab[which_bit];
        bit_sel = 0;//BIT[7..0]=0x80
        seg_sel = 1;//Q[7..0]=D[7..0]
        DATA = seg_tab[which_number];
        seg_sel = 0;
void display(u8 which_bit, u8 which_number)
        u8 x,y;
        x = which_number/10;                        //·Öàëê®Î»
        y = which_number%10;                        //·Öàë¸öλ
        if (which_bit == 1)
                display_led(1, x);
                delay(2);
                display_led(0, y);
                delay(2);
        if (which_bit == 2)
                display_led(4, x);
                delay(2);
                display_led(3, y);
                delay(2);
        if (which_bit == 3)
                display_led(7, x);
                delay(2);
                display_led(6, y);
                delay(2);
void reflash (void)
        display(1, s);
        display(2, min);
        display(3, h);
void main (void)
        TMOD = 0x01;               //¶¨ê±¼ÆêyÆ÷T01¤×÷·½ê½
        TH0 = (65535-10000) / 256;
        TL0 = (65535-10000) % 256;
        EA = 1;        //¿a·Å×üÖD¶Ï
        ET0 = 1;        //¶¨ê±Æ÷0μÄòç3öÖD¶Ï
        TR0 = 1;
        while (1)
                reflash();
void t0_server(void) interrupt 1
        ms++;
        if (ms >= 100)
                ms = 0;
                s++;
                if (s >= 59)
                        s = 0;
                        min++;
                        if (min >= 59)
                                min = 0;
                                h++;
                        if        (h >= 24)
                                h=0;
难受
难受
作者: panzishi123456    时间: 2018-10-18 09:35
时进1那里没用花括号括起来
作者: angmall    时间: 2018-10-18 09:56
你的程序有缺陷,给你改了一下,你试试。
        ms++;
        if (ms >= 100)
                ms = 0;
                s++;
                if (s >= 59)
                        s = 0;
                        min++;
                        if (min >= 59)
                                min = 0;
                                h++;
                        if        (h >= 24)
                                h=0;
作者: 1017871553    时间: 2018-10-19 09:00
谢谢大家
