1602液晶 求高手帮忙指点一下程序哪出错了?
何电明单片机
2012-3-9 12:10
#include
#define uint unsigned int #define uchar unsigned char sbit rs=P2^4; sbit en=P2^5; sbit rw=P2^6; uchar num; uchar code table[]="I LOVE YOU"; void delay_1ms(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void write_com(uchar com) { rs=0; rw=0; en=0; delay_1ms(1); P0=com; delay_1ms(2); en=1; delay_1ms(2); en=0; } void write_data(uchar date) { rs=1; rw=0; en=0; delay_1ms(1); P0=date; delay_1ms(2); en=1; delay_1ms(2); en=0; } void init() { write_com(0x38); delay_1ms(1); write_com(0x0C); delay_1ms(1); write_com(0x06); delay_1ms(1); write_com(0x01); delay_1ms(1); } mian() { init(); write_com(0x80); for(num=0;num<8;num++) { write_data(table[num]); delay_1ms(2); } }
何电明单片机
2012-3-9 12:14
#include
志在四方
2012-3-10 09:49
液晶初始化函数先给液晶15ms的反应时间吧 在write_com(0x38); 前面加delay_1ms(15);
