标题: LED点阵数字倒计时 [打印本页]
作者: 痛苦的猪    时间: 2018-11-1 23:04
标题: LED点阵数字倒计时
LED点阵数字倒计时
#include <REG51.H>
//--重定义函数变量--//
#define uint  unsigned int
#define ulong unsigned long
//--定义SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
//---全局变量声明--//
ulong column;   //点阵列
ulong row;      //点阵行
ulong dt;
//--点阵显示数组--//
uchar code tab0[] =
{0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00,0x08,
0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00,0x80,
0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,0x00,
0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,0x00};
//--10字模--//
uchar code tab1[] =
{0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8,66, 8, 66,
8,66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--//
uchar code tab2[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66,66, 66, 66,
66,66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--//
uchar code tab3[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 66, 66, 36,
66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24,60, 0, 0, 0, 0};
//--07字模--//
uchar code tab4[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34,66, 16, 66, 16,
66,8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--//
uchar code tab5[] =
{0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2,66, 2, 66, 26, 66,
38,66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--//
uchar code tab6[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2,66, 2, 66, 26, 66,
38,66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--//
uchar code tab7[] =
{0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40,66, 36, 66, 36, 66,
34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120,0, 0, 0, 0};
//--03字模--//
uchar code tab8[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 32, 66, 24, 66,
32,66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--//
uchar code tab9[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 66, 66, 32, 66,
32,66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--//
uchar code tab10[] =
{0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8,66, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0,0};
//--00字模--//
uchar code tab11[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66,66, 66, 66, 66, 66, 66,
66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0,0, 0, 0};
//--GO--//
uchar code tab12[] =
{0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65,1, 65, 1, 65, 1, 65, 113,
65,33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函数声明--//
void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
*          : main
* 函数功能                : 主函数
void main(void)
         intk, i, ms;
         i= 60;                                             //显示时间
                   //--显示10--//
                   for(ms= i; ms > 0; ms--)
                            for(k= 0; k < 16; k++)
                            HC595SendData(~tab1[2*k+1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   HC595SendData(0xff,0xff,0,0);
                   //--显示09--//
                                     HC595SendData(~tab2[2*k+1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示08--//
                                     HC595SendData(~tab3[2*k+1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示07--//
                                     HC595SendData(~tab4[2*k+1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示06--//
                                     HC595SendData(~tab5[2*k+1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
             //--显示05--//
                            for(k= 0; k < 16; k++)        //
                                     HC595SendData(~tab6[2*k+1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
             //--显示04--//
                                     HC595SendData(~tab7[2*k+1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示03--//
                                     HC595SendData(~tab8[2*k+1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示02--//
                                     HC595SendData(~tab9[2*k+1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示01--//
                                     HC595SendData(~tab10[2*k+1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   //--显示00--//
                                     HC595SendData(~tab11[2*k+1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);
                   //--清屏--//
                   HC595SendData(0xff,0xff,0,0);        //清屏
             //--一直显示G0--//
                                     HC595SendData(~tab12[2*k+1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);
*          : HC595SendData
* 函数功能                : 通过595发送四个字节的数据
*              : BT3:第四个595输出数值
*                 * BT2: 第三个595输出数值
*                  * BT1:第二个595输出数值
*                  * BT0:第一个595输出数值
         uchari;
         //--发送第一个字节--//
         for(i=0;i<8;i++)
                   MOSIO= BT3 >> 7 ; //从高位到低位
                   BT3<<= 1;
                   S_CLK= 0;
                   S_CLK= 1;
         //--发送第一个字节--//
         for(i=0;i<8;i++)
                   MOSIO= BT2 >>7;            //从高位到低位
                   BT2<<= 1;
                   S_CLK= 0;
                   S_CLK= 1;
         //--发送第一个字节--//
         for(i=0;i<8;i++)
                   MOSIO= BT1 >> 7;           //从高位到低位
                   BT1<<= 1;
                   S_CLK= 0;
                   S_CLK= 1;
         //--发送第一个字节--//
         for(i=0;i<8;i++)
                   MOSIO= BT0 >> 7;           //从高位到低位
                   BT0<<= 1;
                   S_CLK= 0;
                   S_CLK= 1;
         //--输出--//
         R_CLK= 0; //set dataline low
         R_CLK= 1; //片选
作者: admin    时间: 2018-11-1 23:17
补全原理图或者详细说明一下电路连接即可获得100+黑币
