标题: 单片机长短按键的实现代码 含注释 [打印本页]
作者: zhao-daocheng    时间: 2018-11-13 15:46
  1. #include <reg52.h>
  2. sbit BUZZ  = P1^6;
  3. sbit ADDR3 = P1^3;
  4. sbit ENLED = P1^4;
  5. sbit KEY_IN_1  = P2^4;
  6. sbit KEY_IN_2  = P2^5;
  7. sbit KEY_IN_3  = P2^6;
  8. sbit KEY_IN_4  = P2^7;
  9. sbit KEY_OUT_1 = P2^3;
  10. sbit KEY_OUT_2 = P2^2;
  11. sbit KEY_OUT_3 = P2^1;
  12. sbit KEY_OUT_4 = P2^0;
  13. unsigned char code LedChar[] = {  //数码管显示字符转换表
  14.     0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  15.     0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  16. };
  17. unsigned char LedBuff[7] = {  //数码管+独立LED显示缓冲区
  18.     0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
  19. };
  20. unsigned char code KeyCodeMap[4][4] = { //矩阵按键编号到标准键盘键码的映射表
  21.     { 0x31, 0x32, 0x33, 0x26 }, //数字键1、数字键2、数字键3、向上键
  22.     { 0x34, 0x35, 0x36, 0x25 }, //数字键4、数字键5、数字键6、向左键
  23.     { 0x37, 0x38, 0x39, 0x28 }, //数字键7、数字键8、数字键9、向下键
  24.     { 0x30, 0x1B, 0x0D, 0x27 }  //数字键0、ESC键、  回车键、 向右键
  25. };
  26. unsigned char KeySta[4][4] = {  //全部矩阵按键的当前状态
  27.     {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
  28. };
  29. unsigned long pdata KeyDownTime[4][4] = {  //每个按键按下的持续时间,单位ms
  30.     {0, 0, 0, 0},  {0, 0, 0, 0},  {0, 0, 0, 0},  {0, 0, 0, 0}
  31. };
  32. bit enBuzz = 0;     //蜂鸣器使能标志
  33. bit flag1s = 0;     //1秒定时标志
  34. bit flagStart = 0;  //倒计时启动标志
  35. unsigned char T0RH = 0;  //T0重载值的高字节
  36. unsigned char T0RL = 0;  //T0重载值的低字节
  37. unsigned int  CountDown = 0;  //倒计时计数器
  38. void ConfigTimer0(unsigned int ms);
  39. void ShowNumber(unsigned long num);
  40. void KeyDriver();
  41. void main()
  42. {
  43.     EA = 1;       //使能总中断
  44.     ENLED = 0;    //选择数码管和独立LED
  45.     ADDR3 = 1;
  46.     ConfigTimer0(1);  //配置T0定时1ms
  47.     ShowNumber(0);    //上电显示0
  48.
  49.     while (1)
  50.     {
  51.         KeyDriver();  //调用按键驱动函数
  52.         if (flagStart && flag1s) //倒计时启动且1秒定时到达时,处理倒计时
  53.         {
  54.             flag1s = 0;
  55.             if (CountDown > 0)   //倒计时未到0时,计数器递减
  56.             {
  57.                 CountDown--;
  58.                 ShowNumber(CountDown); //刷新倒计时数显示
  59.                 if (CountDown == 0)    //减到0时,执行声光报警
  60.                 {
  61.                     enBuzz = 1;        //启动蜂鸣器发声
  62.                     LedBuff[6] = 0x00; //点亮独立LED
  63.                 }
  64.             }
  65.         }
  66.     }
  67. }
  68. /* 配置并启动T0,ms-T0定时时间 */
  69. void ConfigTimer0(unsigned int ms)
  70. {
  71.     unsigned long tmp;  //临时变量
  72.
  73.     tmp = 11059200 / 12;      //定时器计数频率
  74.     tmp = (tmp * ms) / 1000;  //计算所需的计数值
  75.     tmp = 65536 - tmp;        //计算定时器重载值
  76.     tmp = tmp + 28;           //补偿中断响应延时造成的误差
  77.     T0RH = (unsigned char)(tmp>>8);  //定时器重载值拆分为高低字节
  78.     T0RL = (unsigned char)tmp;
  79.     TMOD &= 0xF0;   //清零T0的控制位
  80.     TMOD |= 0x01;   //配置T0为模式1
  81.     TH0 = T0RH;     //加载T0重载值
  82.     TL0 = T0RL;
  83.     ET0 = 1;        //使能T0中断
  84.     TR0 = 1;        //启动T0
  85. }
  86. /* 将一个无符号长整型的数字显示到数码管上,num-待显示数字 */
  87. void ShowNumber(unsigned long num)
  88. {
  89.     signed char i;
  90.     unsigned char buf[6];
  91.
  92.     for (i=0; i<6; i++)   //把长整型数转换为6位十进制的数组
  93.     {
  94.         buf[i] = num % 10;
  95.         num = num / 10;
  96.     }
  97.     for (i=5; i>=1; i--)  //从最高位起,遇到0转换为空格,遇到非0则退出循环
  98.     {
  99.         if (buf[i] == 0)
  100.             LedBuff[i] = 0xFF;
  101.         else
  102.             break;
  103.     }
  104.     for ( ; i>=0; i--)    //剩余低位都如实转换为数码管显示字符
  105.     {
  106.         LedBuff[i] = LedChar[buf[i]];
  107.     }
  108. }
  109. /* 按键动作函数,根据键码执行相应的操作,keycode-按键键码 */
  110. void KeyAction(unsigned char keycode)  //按键动作函数,根据键码执行相应动作
  111. {
  112.     if (keycode == 0x26)       //向上键,倒计时设定值递增
  113.     {
  114.         if (CountDown < 9999)  //最大计时9999秒
  115.         {
  116.             CountDown++;
  117.             ShowNumber(CountDown);
  118.         }
  119.     }
  120.     else if (keycode == 0x28)  //向下键,倒计时设定值递减
  121.     {
  122.         if (CountDown > 1)     //最小计时1秒
  123.         {
  124.             CountDown--;
  125.             ShowNumber(CountDown);
  126.         }
  127.     }
  128.     else if (keycode == 0x0D)  //回车键,启动倒计时
  129.     {
  130.         flagStart = 1;         //启动倒计时
  131.     }
  132.     else if (keycode == 0x1B)  //Esc键,取消倒计时
  133.     {
  134.         enBuzz = 0;            //关闭蜂鸣器
  135.         LedBuff[6] = 0xFF;     //关闭独立LED
  136.         flagStart = 0;         //停止倒计时
  137.         CountDown = 0;         //倒计时数归零
  138.         ShowNumber(CountDown);
  139.     }
  140. }
  141. /* 按键驱动函数,检测按键动作,调度相应动作函数,需在主循环中调用 */
  142. void KeyDriver()
  143. {
  144.     unsigned char i, j;
  145.     static unsigned char pdata backup[4][4] = {  //按键值备份,保存前一次的值
  146.         {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1},  {1, 1, 1, 1}
  147.     };
  148.     static unsigned long pdata TimeThr[4][4] = {  //快速输入执行的时间阈值
  149.         {1000, 1000, 1000, 1000},  {1000, 1000, 1000, 1000},
  150.         {1000, 1000, 1000, 1000},  {1000, 1000, 1000, 1000}
  151.     };
  152.
  153.     for (i=0; i<4; i++)  //循环扫描4*4的矩阵按键
  154.     {
  155.         for (j=0; j<4; j++)
  156.         {
  157.             if (backup[i][j] != KeySta[i][j])     //检测按键动作
  158.             {
  159.                 if (backup[i][j] != 0)            //按键按下时执行动作
  160.                 {
  161.                     KeyAction(KeyCodeMap[i][j]);  //调用按键动作函数
  162.                 }
  163.                 backup[i][j] = KeySta[i][j];      //刷新前一次的备份值
  164.             }
  165.             if (KeyDownTime[i][j] > 0)            //检测执行快速输入
  166.             {
  167.                 if (KeyDownTime[i][j] >= TimeThr[i][j])
  168.                 {                                 //达到阈值时执行一次动作
  169.                     KeyAction(KeyCodeMap[i][j]);  //调用按键动作函数
  170.                     TimeThr[i][j] += 200; //时间阈值增加200ms,以准备下次执行
  171.                 }
  172.             }
  173.             else   //按键弹起时复位阈值时间
  174.             {
  175.                 TimeThr[i][j] = 1000;  //恢复1s的初始阈值时间
  176.             }
  177.         }
  178.     }
  179. }
  180. /* 按键扫描函数,需在定时中断中调用 */
  181. void KeyScan()
  182. {
  183.     unsigned char i;
  184.     static unsigned char keyout = 0;   //矩阵按键扫描输出索引
  185.     static unsigned char keybuf[4][4] = {  //矩阵按键扫描缓冲区
  186.         {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF},
  187.         {0xFF, 0xFF, 0xFF, 0xFF},  {0xFF, 0xFF, 0xFF, 0xFF}
  188.     };
  189.     //将一行的4个按键值移入缓冲区
  190.     keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
  191.     keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
  192.     keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
  193.     keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
  194.     //消抖后更新按键状态
  195.     for (i=0; i<4; i++)  //每行4个按键,所以循环4次
  196.     {
  197.         if ((keybuf[keyout][i] & 0x0F) == 0x00)
  198.         {   //连续4次扫描值为0,即4*4ms内都是按下状态时,可认为按键已稳定的按下
  199.             KeySta[keyout][i] = 0;
  200.             KeyDownTime[keyout][i] += 4;  //按下的持续时间累加
  201.         }
  202.         else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
  203.         {   //连续4次扫描值为1,即4*4ms内都是弹起状态时,可认为按键已稳定的弹起
  204.             KeySta[keyout][i] = 1;
  205.             KeyDownTime[keyout][i] = 0;   //按下的持续时间清零
  206.         }
  207.     }
  208.     //执行下一次的扫描输出
  209.     keyout++;        //输出索引递增
  210.     keyout &= 0x03;  //索引值加到4即归零
  211.     switch (keyout)  //根据索引,释放当前输出引脚,拉低下次的输出引脚
  212.     {
  213.         case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
  214.         case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
  215.         case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
  216.         case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
  217.         default: break;
  218.     }
  219. }
  220. /* LED动态扫描刷新函数,需在定时中断中调用 */
  221. void LedScan()
  222. {
  223.     static unsigned char i = 0;  //动态扫描索引
  224.
  225.     P0 = 0xFF;             //关闭所有段选位,显示消隐
  226.     P1 = (P1 & 0xF8) | i;  //位选索引值赋值到P1口低3位
  227.     P0 = LedBuff[i];       //缓冲区中索引位置的数据送到P0口
  228.     if (i < 6)             //索引递增循环,遍历整个缓冲区
  229.         i++;
  230.     else
  231.         i = 0;
  232. }
  233. /* T0中断服务函数,完成数码管、按键扫描与秒定时 */
  234. void InterruptTimer0() interrupt 1
  235. {
  236.     static unsigned int tmr1s = 0;  //1秒定时器
  237.
  238.     TH0 = T0RH;   //重新加载重载值
  239.     TL0 = T0RL;
  240.     if (enBuzz)   //蜂鸣器发声处理
  241.         BUZZ = ~BUZZ;  //驱动蜂鸣器发声
  242.     else
  243.         BUZZ = 1;      //关闭蜂鸣器
  244.     LedScan();   //LED扫描显示
  245.     KeyScan();   //按键扫描
  246.     if (flagStart)  //倒计时启动时处理1秒定时
  247.     {
  248.         tmr1s++;
  249.         if (tmr1s >= 1000)
  250.         {
  251.             tmr1s = 0;
  252.             flag1s = 1;
  253.         }
  254.     }
  255.     else  //倒计时未启动时1秒定时器始终归零
  256.     {
  257.         tmr1s = 0;
  258.     }
  259. }
长短按键连续按键功能实现.rar (40.77 KB, 下载次数: 47)
作者: yasi666    时间: 2019-9-18 15:15
谢谢了
作者: 欢迎新会员    时间: 2019-9-29 16:55
51黑有你更精彩
作者: 中恒电子asus    时间: 2019-10-5 16:10
51黑有你更精彩
