程序代码:
//Pass at PROTEUS 8.7,ZhouMi,1881003@qq.com,20181118,11:52
//实验内容和现象:
//(1)配置完整RCC,使能GPIOC、GPIOE和AFIO的时钟的时钟;
//(2)配置NVIC:优先组NVIC_PriorityGroup_1为1,占先式PreemptionPriority为0,副优先SubPriority为0;
//(3)设置端口位PA5(联接KEY1)为GPIO_Mode_IN_FLOATING、PC6(联接LED1)为GPIO_Mode_Out_PP 50MHz;
//(4)LCD显示实验信息,没有学习LCD之前,请忽略;
//(5)配置EXTI:与PA5联接的KEY1中断为EXTI_Line5。
//(6)在stm32f10x_it.c里,配置EXTI9_5_IRQHandler,发生中断时将PC6输出取反驱动LED1指示中断发生了。
//(7)下载运行程序,按下KEY1触发中断EXTI_Line5,LED1指示中断发生了。
// 说明:程序源于STM3210E-EVAL,请看本project的readme.txt
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
