标题: 串口通信 [打印本页]
作者: 12233344421    时间: 2018-11-21 20:32
标题: 串口通信
#include <REG52.H>
sbit LED = P1^0;
unsigned char UART_buff;
bit New_rec = 0, Send_ed = 1, Money = 0;
void main (void)
    SCON = 0x50;   //串口方式1, 8-n-1, 允许接收.
    TMOD = 0x20;   //T1方式2
    TH1 = 0xFD;    //9600bps@11.0592MHz
    TL1 = 0xFD;
    TR1 = 1;
    ES  = 1;       //开中断.
    EA  = 1;
    while(Money == 0);    //等着交费,呵呵,等着接收$.
    while(1)  {
      if ((New_rec == 1) && (Send_ed == 1))  {  //如果收到新数据及发送完毕
        SBUF = UART_buff; //那就发送.
        New_rec = 0;
        Send_ed = 0;
void ser_int (void) interrupt 4
    if(RI == 1) {  //如果收到.
      RI = 0;      //清除标志.
      New_rec = 1;
      UART_buff = SBUF;  //接收.
      if(UART_buff == '1')  LED = 1;
      if(UART_buff == '0')  LED = 0;
      if(UART_buff == '$')  Money = 1;
    else  {        //如果送毕.
      TI = 0;      //清除标志.
      Send_ed = 1;
