SI4438 Directional硬件SPI STM8S105单片机IAR代码分享
345138275
2018-11-23 19:15
#include "stm8s.h"
#include "data_base.h"
#include "radio.h"
#include "si446x_cmd.h"
#include "gpio.h"
#include "delay.h"
#include "user.h"
uint8_t bRadio_Process();
U8 bMain_IT_Status;
uint8_t RFstate;
extern uint8_t tx_data[];
extern volatile uint16_t tick_timer;
#define EnableMaster 0
Demo程序流程:Master EnableMaster=1,发送tx_data数据包后等待接收端ack数据包,若500ms后未接收到ack数据包超时处理,若接收到ack数据包LED闪烁指示
Slaver EnableMaster=0,接收到tx_data数据包后发送ack数据包,发送完成后LED灯闪烁指示
void main(void)
vInitializeHW();// Initialize the Hardware and Radio
#if EnableMaster
RFstate=RFLR_STATE_TX_INIT;
#else
RFstate=RFLR_STATE_RX_INIT;
#endif
bRadio_Process();
switch(RFstate)
case RFLR_STATE_RX_INIT://接收初始化
GPIO_WriteLow(SI4463_TX_PORT,SI4463_TX_IO);
GPIO_WriteHigh(SI4463_RX_PORT,SI4463_RX_IO);//开关切换到接收通路
vRadio_StartRX(pRadioConfiguration->Radio_ChannelNumber, 0);
tick_timer=0;
RFstate=RFLR_STATE_RX_RUNNING;
break;
case RFLR_STATE_RX_RUNNING://接收处理
bMain_IT_Status = bRadio_Check_Tx_RX();
if(bMain_IT_Status==SI446X_CMD_GET_INT_STATUS_REP_PH_PEND_PACKET_RX_PEND_BIT)
if(EnableMaster)
RFstate=RFLR_STATE_RX_ACK_DONE;
RFstate=RFLR_STATE_RX_DONE;
if(tick_timer>500)
RFstate=RFLR_STATE_RX_TIMEOUT;
break;
case RFLR_STATE_TX_INIT://发射客户数据包初始化
GPIO_WriteHigh(SI4463_TX_PORT,SI4463_TX_IO);
GPIO_WriteLow(SI4463_RX_PORT,SI4463_RX_IO);//开关切换到发送通路
gSampleCode_SendVariablePacket();//打包发送客户数据包
tick_timer=0;
RFstate=RFLR_STATE_TX_RUNNING;
break;
case RFLR_STATE_TX_ACK_INIT://发射ack数据包初始化
vSampleCode_SendAcknowledge();//打包发送ACK数据包
tick_timer=0;
break;
case RFLR_STATE_TX_RUNNING://发射处理
if(bMain_IT_Status==SI446X_CMD_GET_INT_STATUS_REP_PH_PEND_PACKET_SENT_PEND_BIT)
if(EnableMaster)
RFstate=RFLR_STATE_TX_DONE;
RFstate=RFLR_STATE_TX_ACK_DONE;
if(tick_timer>500)
RFstate=RFLR_STATE_TX_TIMEOUT;
break;
case RFLR_STATE_RX_DONE://接收客户数据包完成
if(gSampleCode_StringCompare(customRadioPacket, tx_data,20)==TRUE)
RFstate=RFLR_STATE_TX_ACK_INIT;//收到正确数据包后发射ack数据包
break;
case RFLR_STATE_RX_ACK_DONE://接收ack数据包完成
if(gSampleCode_StringCompare(customRadioPacket, "ACK",3)==TRUE)
GPIO_WriteLow(RF_LED1_PORT,RF_LED1_IO);//LED指示灯闪烁
m928_delay(20);
GPIO_WriteHigh(RF_LED1_PORT,RF_LED1_IO);
m928_delay(100);
break;
case RFLR_STATE_TX_DONE://发射完客户数据包
break;
case RFLR_STATE_TX_ACK_DONE://发射完ack数据包
GPIO_WriteLow(RF_LED1_PORT,RF_LED1_IO);//LED灯闪烁
m928_delay(20);
break;
case RFLR_STATE_TX_TIMEOUT://发射超时
if(EnableMaster)
break;
case RFLR_STATE_RX_TIMEOUT://接收超时
if(EnableMaster)
break;
default:break;
return RFstate;
SI4438 Directional 硬件spi STM8S105 IAR.rar
(10.74 MB, 下载次数: 34)
2018-11-24 02:06 上传
点击文件名下载附件
下载积分: 黑币 -5
