标题: 用51单片机控制直流电机的启停、转向,用PWM控制转速 [打印本页]
作者: 19960601    时间: 2018-11-28 01:21
51单片机控制直流小电机的转速转向以及启停
待机界面
待机界面
停机状态
停机状态
正转
正转
反转
反转
PWM直流电机.zip
77.54 KB, 下载次数: 366, 下载积分: 黑币 -5
源文件和仿真
作者: admin    时间: 2018-11-28 01:53
楼主的源码:
  1. #include"reg51.h"
  2. #include"LCD1602.h"
  3. sbit zheng         =         P3^0;
  4. sbit fan          =         P3^1;
  5. sbit K1                =        P1^0;
  6. sbit K2                =        P1^1;
  7. sbit K3                =        P1^2;
  8. sbit K4                =        P1^3;
  9. unsigned int t=50,tim=0,num=0;
  10. unsigned char flag=0,sec=0,dir=0,disp=0;
  11. void delay_ms(unsigned int tim)
  12. {
  13.         unsigned int i,j;
  14.         for(i=0;i<tim;i++);
  15.                 for(j=0;j<120;j++);
  16. }
  17. void key_control()
  18. {
  19.          if(K1==0&&flag==1)
  20.          {
  21.                  delay_ms(100);
  22.                 //while(!K1);
  23.                 if(t<100)        t++;
  24.          }
  25.          if(K2==0&&flag==1)
  26.          {
  27.                  delay_ms(100);
  28.                 //while(!K2);
  29.                 if(t>0)          t--;
  30.          }
  31.          if(K3==0)
  32.          {
  33.                  delay_ms(10);
  34.                 while(!K3);
  35.                 flag=1-flag;
  36.          }
  37.          if(K4==0)
  38.          {
  39.                  delay_ms(10);
  40.                 while(!K4);
  41.                 dir=1-dir;
  42.          }
  43. }
  44. void Display()
  45. {
  46.         if(flag==1)
  47.         {
  48.                 if((100-t)/100==0)
  49.                         LCDDispChar(6,1,' ');
  50.                 else
  51.                         LCDDispNum(6,1,(100-t)/100);
  52.                 if((100-t)/100==0&&(100-t)%100/10==0)
  53.                         LCDDispChar(7,1,' ');
  54.                 else
  55.                         LCDDispNum(7,1,(100-t)%100/10);
  56.
  57.                 LCDDispNum(8,1,(100-t)%10);
  58.                 LCDDispChar(9,1,'%');
  59.                 LCDDispString(11,1,"On ");
  60.                 if(dir)
  61.                 {
  62.                         LCDDispChar(14,1,'Z');
  63.                         LCDDispChar(15,1,'z');
  64.                 }
  65.                 else
  66.                 {
  67.                         LCDDispChar(14,1,'F');
  68.                         LCDDispChar(15,1,'z');
  69.                 }
  70.         }
  71.         else
  72.         {
  73.                 LCDDispChar(6,1,' ');
  74.                 LCDDispChar(7,1,'-');
  75.                    LCDDispChar(8,1,'-');
  76.                 LCDDispChar(9,1,'-');
  77.                 LCDDispChar(14,1,' ');
  78.                 LCDDispChar(15,1,' ');
  79.                 LCDDispString(11,1,"Off");
  80.         }
  81. }
  82. void Display_Speed()
  83. {
  84.         if(num/100==0)
  85.                 LCDDispChar(7,2,' ');
  86.         else
  87.                 LCDDispNum(7,2,num/100);
  88.         if(num/100==0&&num%100/10==0)
  89.                 LCDDispChar(8,2,' ');
  90.         else
  91.                 LCDDispNum(8,2,num%100/10);
  92.         LCDDispNum(9,2,num%10);
  93. }
  94. void Timer_Init()
  95. {
  96.         TMOD = 0x11;
  97.         TH0  = 0x3c;
  98.         TL0  = 0xb0;
  99.         ET0  = 1;
  100.         TR0  = 1;
  101.
  102.         EX0  = 1;
  103.         IT0  = 1;
  104.
  105.         TH1  = (65536-1000)/256;
  106.         TL1  = (65536-1000)%256;
  107.         ET1  = 1;
  108.         TR1  = 1;
  109.         EA   = 1;
  110. }
  111. void main()
  112. {
  113.         LCDInit();
  114.         LCDDispString(0,1,"Duty :");
  115.         LCDDispString(0,2,"Speed:       r/s");
  116.         Timer_Init();
  117.         while(1)
  118.         {
  119.                 key_control();
  120.                 Display();
  121.                 if(disp)
  122.                 {
  123.                         disp=0;
  124.                         Display_Speed();
  125.                         num=0;
  126.                 }
  127.         }
  128. }
  129. void Interrupt1() interrupt 0
  130. {
  131.         num++;
  132. }
  133. void Timer1() interrupt 3
  134. {
  135.         TH1  = (65536-1000)/256;
  136.         TL1  = (65536-1000)%256;
  137.         if(flag)
  138.         {
  139.                 tim++;
  140.                 if(dir)
  141.                 {
  142.                         fan=0;
  143.                         if(t<=tim)
  144.                                 zheng=1;
  145.                         else
  146.                                 zheng=0;
  147.                         if(tim==101)
  148.                         {
  149.                                 tim=0;
  150.                                 zheng=~zheng;
  151.                         }
  152.                 }
  153.                 else
  154.                 {
  155.                         zheng=0;
  156.                         if(t<=tim)
  157.                                 fan=1;
  158.                         else
  159.                                 fan=0;
  160.                         if(tim==101)
  161.                         {
  162.                                 tim=0;
  163.                                 fan=~fan;
  164.                         }
  165.                 }
  166.         }
  167.         else
  168.         {
  169.                 zheng=1;
  170.                 fan  =1;
  171.         }
  172. }
  173. void Timer0() interrupt 1
  174. {
  175.         TH0  = 0x3c;
  176.         TL0  = 0xb0;
  177.         sec++;
  178.         if(sec==20)
  179.         {
  180.                 sec=0;
  181.                 disp=1;
  182.         }
  183. }
作者: sunnywu503    时间: 2018-11-28 02:19
楼上提取楼主的代码对我这样的没钱穷新人下载学习!很厚道!大赞!!!!!!!!谢谢啦!
作者: sunnywu503    时间: 2018-11-28 02:26
能继续贴上“LCD1602.H”的代码就好了。
作者: dujinhui    时间: 2018-11-28 10:42
作者: sunnywu503    时间: 2018-11-28 13:12
当下没有L298N集成在手,想用手头的ULN2003A驱动步进电机( 5V 4相5线步进电机 28YBJ-48 28BYJ48 减速步进电机),如下图原理:
请问楼主,我用这个程序使用AT89C52+ULN2003A驱动这个5V的:28YBJ-48 28BYJ48 减速步进电机,可以不?
作者: Wikkings_Bob    时间: 2019-5-18 23:44
学习了!
作者: 虾兵0蟹将    时间: 2019-5-27 10:02
要是能有函数注解就完美了
作者: 虾兵0蟹将    时间: 2019-5-28 17:25
这个好,我正需要,谢谢楼主
作者: 1781318012    时间: 2019-12-6 15:11
注解在详细一些就好了,谢谢楼主
作者: lindeijun1    时间: 2020-2-22 10:42
谢谢楼主分享!!!
作者: hui281036983    时间: 2020-2-22 22:20
作者: 7788李    时间: 2022-6-15 12:06
这个代码是不完整的吗?
