8×8LED点阵屏仿电梯数字滚动显示单片机C程序
q1249969321
2018-12-24 11:00
#include<reg52.h>
#include<absacc.h>
#include <ctype.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#include <intrins.h>
功能:5*7点阵表
uchar code biao[11][8]=
{0x70,0x88,0x98,0xA8,0xC8,0x88,0x70,0x00}, // -0-
{0x20,0x60,0x20,0x20,0x20,0x20,0x70,0x00}, // -1-
{0x70,0x88,0x08,0x30,0x40,0x80,0xF8,0x00}, // -2-
{0xF8,0x08,0x10,0x30,0x08,0x88,0x70,0x00}, // -3-
{0x10,0x30,0x50,0x90,0xF8,0x10,0x10,0x00}, // -4-
{0xF8,0x80,0xF0,0x08,0x08,0x88,0x70,0x00}, // -5-
{0x38,0x40,0x80,0xF0,0x88,0x88,0x70,0x00}, // -6-
{0xF8,0x08,0x10,0x20,0x40,0x40,0x40,0x00}, // -7-
{0x70,0x88,0x88,0x70,0x88,0x88,0x70,0x00}, // -8-
{0x70,0x88,0x88,0x78,0x08,0x10,0xE0,0x00}, // -9-
{0x20,0x70,0xa8,0x20,0x20,0x20,0x20,0x00} // -↑-
功能:扫描表
//uchar code sao[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar code sao[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
功能:串口初始化,波特率9600 方式0 8 UART
void Init_Com(void)
SCON = 0x00; //方式0
功能:延时
//1
void DELAY_25mS(void)
unsigned int x = 45438;
while (--x)
_nop_();
//2
delay(uchar ms)
{ // 延时子程序
uchar i;
while(ms--)
for(i = 0; i<250; i++)
_nop_();
_nop_();
_nop_();
_nop_();
//3
delay1(t)
while(t--)
功能:显示子程序
xian()
uchar a;
for(a=0;a<8;a++)
SBUF =biao[0][a]; //串口发第一个显示字
while(!TI);
TI=0;
SBUF =biao[1][a]; //串口发第二个显示字
while(!TI);
TI=0;
SBUF =biao[3][a]; //串口发第三个显示字
while(!TI);
TI=0;
P1=sao[a]; //
delay1(100);
P1=0xff;
主程序
功能:实现接收数据并把接收到的数据发送出去
uchar ii;
Init_Com();
//SBUF = dis_7[0]; //发送数据
//while(!TI);
//TI=0;
xian();
admin
2018-12-24 16:25
补全原理图或者详细说明一下电路连接即可获得100+黑币
ssk7793
2018-12-24 16:44
代码中没看到io口定义,一堆头文件,楼主却没有上传附件
aoppol
2020-10-16 21:29
乱写一通
