AVR单片机简单计算器的Proteus仿真实现+源码
曹文涛
2018-12-24 11:26
AVR单片机简单计算器的实现仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
(17.11 KB, 下载次数: 104)
下载附件
2018-12-24 16:01 上传
(12.74 KB, 下载次数: 91)
下载附件
2018-12-24 16:01 上传
#include "mega16.h"
#include "1602.h"
#include "key.h"
float k1,k2; //记录最终输入运算的两个数
uint one,two,three,four; //记录每次输入的数字
uint flag; //计数标志位
uint flag1,flag2; //第一个数 第二个数 完成标志位
uint flag3;//记录加减乘除标志位
long Result; //最后运算的结果
init(); //液晶初始化
// write_com(0x80+15);
// write_date('0');
Init_Keypad(); //键盘初始化
flag1 = 1;
Key_Event(); //扫描键盘
if(key_Flag == 1)
key_Flag = 0;
if(key_val <= 10) //小于10 则为需要的数字
if(flag1) //flag1为1 表示正在输入第一个数字
switch(flag)
case 0:
flag = 1;
one = key_val%10;
write_com(0x80+6);
write_date(tab[key_val]);
k1 = (float)one;
break;
case 1:
flag = 2;
two = key_val%10;
write_com(0x80+7);
k1 = (float)(one*10 + two);
break;
case 2:
flag = 3;
three = key_val%10;
write_com(0x80+8);
k1 = (float)(one*100 + two * 10 + three);
break;
case 3:
flag = 4;
four = key_val%10;
write_com(0x80+9);
k1 = (float)(one*1000 + two * 100 + three*10 + four);
break;
case 4:
flag = 0;
break;
if(flag2) //flag2为1 表示正在输入第2个数字
switch(flag)
case 0:
flag = 1;
one = key_val%10;
write_com(0x80+12);
k2 = (float)one;
break;
case 1:
flag = 2;
two = key_val%10;
write_com(0x80+13);
k2 = (float)(one*10 + two);
break;
case 2:
flag = 3;
three = key_val%10;
write_com(0x80+14);
k2 = (float)(one*100 + two * 10 + three);
break;
case 3:
flag = 4;
four = key_val%10;
write_com(0x80+15);
k2 = (float)(one*1000 + two * 100 + three*10 + four);
break;
case 4:
flag = 0;
break;
else if(key_val>=13 || key_val <= 16) //判断运算符
flag1 = 0;
flag2 = 1;
flag = 0;
switch(key_val)
case 13:
write_com(0x80+11);
write_date('+');
flag3 = 1;
break;
case 14:
write_com(0x80+11);
write_date('-');
flag3 = 2;
break;
case 15:
write_com(0x80+11);
write_date('*');
flag3 = 3;
break;
case 16:
write_com(0x80+11);
write_date('/');
flag3 = 4;
break;
if(key_val == 12) //等于
switch(flag3)
case 1:
Result = k1 + k2;
write_com(0xc0);
write_date(tab[Result/100000]);
write_date(tab[Result%100000/10000]);
write_date(tab[Result%10000/1000]);
write_date(tab[Result%1000/100]);
write_date(tab[Result%100/10]);
write_date(tab[Result%10]);
break;
case 2:
Result = k1 - k2;
write_com(0xc0);
if(Result < 0)
write_date('-');
Result = 0 - Result;
break;
case 3:
Result = k1 * k2;
write_com(0xc0);
break;
case 4:
//write_com(0x80+11);
//write_date('/');
Result = k1*100 / k2;
write_com(0xc0);
//write_date(tab[Result/100000]);
//write_date(tab[Result%100000/10000]);
write_date('.');
…………限于本文篇幅 余下代码请从51黑下载附件…………
mega16 计算器.zip
(135.42 KB, 下载次数: 78)
2018-12-24 11:25 上传
点击文件名下载附件
下载积分: 黑币 -5
曹文涛
2018-12-24 11:30
在做课设的时候一个小的参考资料
2875007399
2019-6-14 17:35
谢谢分享。正需要
微尘。。
2020-5-14 14:46
对课程设计太友好了!
2273457901
2020-12-21 08:09
楼主可以加小数点嘛
