这个LcdShowDat为什么没有调用呀,搞不懂呀
单片机好难啊!
2018-12-24 15:13
void delay_ms(unsigned int d);
void ScanKeyboard();
void LcdShowStr(unsigned char x,unsigned char y,unsigned char*str);
void LcdShowDat(unsigned char x,unsigned char y,unsigned char dat);
unsigned char cnt=0,w=0,key=0;
unsigned char code KeyCode[]=
{0xe7,0xd7,0xb7,0x77,0xeb,0xdb,0xbb,0x7b,0xed,0xdd,0xdb,0xbd,0x7d,0xee,0xde,0xbe,0x7e};
unsigned char temp;
unsigned char str[]="hello";
TMOD=0X01;
TH0=0X4C;
TL0=0X00;
IE=0X82;
TR0=1;
InitLcd1602();
LcdShowStr(2,0,str);
while(1);
temp=w;
LcdShowDat(4,1,temp);
void LcdWaitReady()
unsigned char sta;
LCD1602_DB=0XFF;
LCD1602_RS=0;
LCD1602_RW=1;
do{
LCD1602_E=1;
sta=LCD1602_DB;
LCD1602_E=0;
while(sta&0x80);
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS=0;
LCD1602_RW=0;
LCD1602_DB=cmd;
LCD1602_E=1;
LCD1602_E=0;
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_DB=dat;
LCD1602_E=1;
LCD1602_E=0;
void LcdSetCursor(unsigned char x,unsigned char y)
unsigned char addr;
if(y==0)
addr=0x00+x;
addr=0x40+x;
LcdWriteCmd(addr|0x80);
LcdSetCursor(x,y);
while(*str!='\0')
LcdWriteDat(*str++);
LcdSetCursor(x,y);
LcdWriteDat(dat);
void InitLcd1602()
LcdWriteCmd(0x38);
LcdWriteCmd(0x0c);
LcdWriteCmd(0x06);
LcdWriteCmd(0x01);
void ScanKeyboard()
unsigned char scan1,scan2,keyboard;
unsigned char i;
P2=0xf0;
scan1=P2;
if((scan1&0xf0)!=0xf0)
delay_ms(10);
scan1=P2;
P2=0xf0;
scan2=P2;
keyboard=scan1|scan2;
while((P2&0x0f)!=0x0f)
for(i=0;i<=15;i++)
if(keyboard==KeyCode[i])
key=i;
void clock()interrupt 1
unsigned char key,i;
cnt++;
TH0=0X4C;
TL0=0X00;
ScanKeyboard();
if(key==1)
w=0x20;
if(key==2)
for(i=0;cnt<=20;i++)
w=0x61+0x01;
if(i==3)
i=0;
w=0x61;
unsigned char i;
while(d--)
for(i=0;i<=110;i++);
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?_LCDSHOWDAT?ABC
robinsonlin
2018-12-24 17:52
主程序最后一个语句不是么?
另外,你这个程序能跑起来么? 真的有点佩服。建议你还是先初步了解一下单片机的教程,你框架结构有很大的问题。 中断里面处理了太多事,还没有等中断恢复,第二次中断就该响应了。
地瓜你干啥呢
2018-12-24 17:54
子程序调用函数是不是有问题,是不是涉及到是否修改数值问题。三种传值方式
