keil编译的error C141
760626361
2018-12-28 14:39
keil编译的error C141
#ifndef _LED_H_
#define _LED_H_
sbit L298N_DT1=P1^2; //L298N驱动,左轮正转
sbit L298N_DT2=P1^3; //左轮反转
sbit L298N_OT1=P1^4; //右轮正转
sbit L298N_OT2=P1^5; //右轮反转
sbit BUZZ=P2^3; //蜂鸣器
#define left_EX P3^7 //左探头
#define Right_EX P3^6 //右探头
#define Left_PWM P1^6 //左PWM
#define Right_PWM P1^7 //右PWM
#define Left_Go {P1^2=1,P1^3=0;} //左轮正转
#define Left_Back {P1^2=0,P1^3=1;} //左轮反转
#define Left_Stop {P1^2=0,P1^3=0;} //左轮停转
#define Right_Go {P1^4=1,P1^5=0;} //右轮正转
#define Right_Back {P1^4=0,P1^5=1;} //右轮反转
#define Right_Stop {P1^4=0,P1^5=0;} //右轮停转
unsigned char Left_val_PWM=0; //定义变量
unsigned char Left_val_Push=0; //左占空比
unsigned char Right_val_PWM=0;
unsigned char Right_val_Push=0; //右占空比
bit Right_stop=1;
bit Left_stop=1;
unsigned int time=0;
void delay(int i)
{ //延时函数
while(i--);
//全速前进
void run(void)
Left_val_Push=12; //速度调节,12级
Right_val_Push=12;
Left_Go ; //左右前转
Right_Go ;
//全速后退
void back(void)
Left_val_Push=12;
Right_val_Push=12;
Left_Back; //左右后转
Right_Back;
//左转
void leftrun(void)
Left_val_Push=5; //左轮慢
Right_val_Push=15; //右轮快
Left_Back; //左轮后转
Right_Go; //右轮前转
//右转
void rightrun(void)
Left_val_Push=15; //左轮快
Right_val_Push=5; //右轮慢
Left_Go; //左轮前转
Right_Back; //右轮后转
//停止
void stop(void)
Left_Stop; //左轮停止
Right_Stop; //右轮停止
//左电机PWM调速
void Left_PWM_out(void)
if(Left_Stop)
if(Left_val_Push>=Left_val_PWM)
Left_PWM=1;
Left_PWM=0;
if(Left_val_PWM>=20)
Left_val_Push=0;
Left_PWM=0;
//右电机调速
void Right_PWM_out(void)
if(Right_Stop)
if(Right_val_Push>=Right_val_PWM)
Right_PWM=1;
Right_PWM=0;
if(Right_val_PWM>=20)
Right_val_Push=0;
Right_PWM=0;
//中断
void timer0()interrupt 1 using 2
TH0=0XFc; //1Ms定时
TL0=0X18;
time++;
Left_val_PWM++;
Right_val_PWM++;
Left_PWM_out();
Right_PWM_out();
#endif
CARHEAD.H(42): error C141: syntax error near '='
CARHEAD.H(43): error C141: syntax error near '='
CARHEAD.H(50): error C141: syntax error near '='
CARHEAD.H(51): error C141: syntax error near '='
CARHEAD.H(58): error C141: syntax error near '='
CARHEAD.H(59): error C141: syntax error near '='
CARHEAD.H(66): error C141: syntax error near '='
CARHEAD.H(67): error C141: syntax error near '='
CARHEAD.H(72): error C141: syntax error near '='
CARHEAD.H(73): error C141: syntax error near '='
CARHEAD.H(79): error C141: syntax error near '{'
CARHEAD.H(83): error C141: syntax error near '='
CARHEAD.H(87): error C141: syntax error near '='
CARHEAD.H(94): error C141: syntax error near '='
CARHEAD.H(101): error C141: syntax error near '{'
CARHEAD.H(105): error C141: syntax error near '='
CARHEAD.H(109): error C141: syntax error near '='
CARHEAD.H(116): error C141: syntax error near '='
Target not created
