标题: 关于LCD19264引脚定义,目前只知道1~8脚是数据,19和20是背光电源 [打印本页]
作者: fang880413    时间: 2019-1-4 16:20
坛里大神有没有这个19264液晶的引脚定义,目前只知道1~8脚是数据,19和20是背光电源。这个和网上的19264引脚不同
居然在万能的淘宝找到了相似的,等有时间照着他的引脚试试
作者: angmall    时间: 2019-1-4 21:16
看看别人的程序吧。
  1. //----------------------------------------------------------------------
  2. /*TVI Electronics, LLC*/
  3. // Module: TGL33B-19264 Series
  4. // Lanuage: C51 Code
  5. // Create: JAVEN
  6. // Date: 2009-06-18
  7. // Drive IC: KS0108/31108
  8. // INTERFACE: 6800_8bit
  9. // MCU: AT89C52
  10. // VDD: 5V
  11. //Б¬ПЯ±н:  CPU=89C52
  12. //RS=P2.0     R/W=P2.1     E=P2.2     CSB=P2.3     CSA=P2.4    RES=P2.5
  13. //SysClock=12MHz           DB0-DB7=P1.0-P1.7       /Reset=InBoard
  14. //***************************************************************************
  15.
  16.
  17.
  18. #include <INTRINS.H>
  19. #include <STDIO.H>
  20. #include <MATH.H>
  21. #include <ABSACC.H>
  22. #include <REG52.H>
  23.
  24. sbit RS  =P2^0;
  25. sbit RW  =P2^1;
  26. sbit E   =P2^2;
  27.
  28. sbit CSB =P2^3;
  29. sbit CSA =P2^4;
  30. sbit RES =P2^5;
  31. sbit int0=P3^2;
  32. bit  log =0;
  33. unsigned char Page;
  34. unsigned char Col;
  35. unsigned char code BMP0[];
  36. unsigned char code BMP1[];
  37. unsigned char code BMP2[];
  38. unsigned char code font[];
  39. unsigned char code Character[];
  40. void BusyL(void);
  41. void BusyM(void);
  42. void BusyR(void);
  43. void Locatexy(void);
  44. void WriteCommandL( unsigned char CommandByte );
  45. void WriteCommandM( unsigned char CommandByte );
  46. void WriteCommandR( unsigned char CommandByte );
  47. unsigned char ReadData( void );
  48. void WriteData( unsigned char DataByte );
  49. void LcmClear( void );
  50. void LcmInit( void );
  51. void LcmPutDots( unsigned char DotByte,unsigned char DotByte1 );
  52. void LcmPutBMP( unsigned char *puts );
  53. void LcmReverseBMP( void );
  54. void Delay(unsigned int MS);
  55. void Display_Chinese();
  56. void Display_16_16(unsigned char F[],unsigned char i);
  57. void Display_8_8(unsigned char C[],unsigned char i);
  58. unsigned char code character[]=
  59.         {0x3f,0x15,0x15,0x15,0x15,0x3f,0x00,0x00,                //ФВ
  60.          0x00,0x00,0x48,0x54,0xfe,0x54,0x24,0x00,                //$
  61.          0x00,0x00,0x3e,0x41,0x79,0x49,0x32,0x00};                 //G
  62.
  63. /***************************/
  64. /*Check Busy L                 */
  65. /***************************/
  66. void BusyL(void)
  67. {unsigned char flag=0xff;
  68. CSB= 0;
  69. CSA= 0;
  70. RS = 0;
  71. RW = 1;
  72. P1 = 0xFF;
  73. while ((flag&0x80)==0x80)
  74. {
  75. E=1;
  76. _nop_();
  77. flag=P1;
  78. E=0;
  79. }
  80. }
  81. /***************************/
  82. /*Check Busy M                 */
  83. /***************************/
  84. void BusyM(void)
  85. { unsigned char flag=0xff;
  86. CSB= 0;
  87. CSA= 1;
  88. RS = 0;
  89. RW = 1;
  90. P1 = 0xFF;
  91. while ((flag&0x80)==0x80)
  92. {
  93. E=1;
  94. _nop_();
  95. flag=P1;
  96. E=0;
  97. }
  98. }
  99. /***************************/
  100. /*Check Busy R                 */
  101. /***************************/
  102. void BusyR(void)
  103. {  unsigned char  flag=0xff;
  104. CSB= 1;
  105. CSA= 0;
  106. RS = 0;
  107. RW = 1;
  108. P1 = 0xFF;
  109. while ((flag&0x80)==0x80)
  110. {
  111. E=1;
  112. _nop_();
  113. flag=P1;
  114. E=0;
  115. }
  116. }
  117.
  118.
  119. /***************************/
  120. /* Locate X Y                */
  121. /***************************/
  122. void Locatexy(void)
  123. {
  124. unsigned char x,y;
  125. switch (Col&0xc0) /*  col.and.0xC0 */
  126. {
  127.   case 0: {BusyL();break;}
  128.   case 0x40: {BusyM();break;}
  129.   case 0x80: {BusyR();break;}
  130. }
  131. x = Col&0x3F|0x40; /* col.and.0x3f.or.Set X Address*/
  132. y = Page&0x07|0xB8; /* row.and.0x07.or.set Page */
  133.
  134. RS = 0;
  135. RW = 0;
  136. P1 = y;
  137. E  = 1;
  138. _nop_();
  139. E  = 0;
  140. _nop_();
  141. RS = 0;
  142. RW = 0;
  143. P1 = x;
  144. E  = 1;
  145. _nop_();
  146. E  = 0;
  147. _nop_();
  148. }
  149. /***************************/
  150. /*Write command 1-64               */
  151. /***************************/
  152. void WriteCommandL( unsigned char CommandByte )
  153. {
  154. BusyL();
  155. P1 = CommandByte;
  156. RS = 0;
  157. RW = 0;
  158. E  = 1;
  159. _nop_();
  160. E  = 0;
  161. _nop_();
  162. }
  163. /***************************/
  164. /*Write command 65-128                */
  165. /***************************/
  166. void WriteCommandM( unsigned char CommandByte )
  167. {
  168. BusyM();
  169. P1 = CommandByte;
  170. RS = 0;
  171. RW = 0;
  172. E  = 1;
  173. _nop_();
  174. E  = 0;
  175. _nop_();
  176. }
  177. /***************************/
  178. /*Write command 129-192             */
  179. /***************************/
  180. void WriteCommandR( unsigned char CommandByte )
  181. {
  182. BusyR();
  183. P1 = CommandByte;
  184. RS = 0;
  185. RW = 0;
  186. E  = 1;
  187. _nop_();
  188. E  = 0;
  189. _nop_();
  190. }
  191.
  192. /***************************/
  193. /*Read data                   */
  194. /***************************/
  195. unsigned char ReadData( void )
  196. {
  197. unsigned char DataByte;
  198. Locatexy();
  199. RS = 1;
  200. RW = 1;
  201. P1 = 0xFF;
  202.   _nop_();
  203. E  = 1;
  204. _nop_();
  205. DataByte = P1;
  206. E  = 0;
  207. _nop_();
  208. CSB=1;
  209. CSA=1;
  210. return DataByte;
  211. }
  212.
  213. /***************************/
  214. /*Write data             */
  215. /***************************/
  216. void WriteData( unsigned char DataByte )
  217. {
  218. Locatexy();
  219. RS = 1;
  220. RW = 0;
  221. P1 = DataByte;
  222. E  = 1;
  223. _nop_();
  224. E  = 0;
  225. _nop_();
  226. CSB=1;
  227. CSA=1;
  228. }
  229.
  230. void LcmClear( void )
  231. {
  232. Page = 0;
  233. Col  = 0;
  234. for(Page=0;Page<8;Page++)
  235.   for(Col=0;Col<192;Col++)
  236.    WriteData(0);
  237. }
  238.
  239. void LcmInit( void )
  240. {          RES=0;
  241.         Delay(10);
  242.     RES=1;
  243. WriteCommandL(0x3f); //DISPALY ON
  244. WriteCommandM(0x3f);
  245. WriteCommandR(0x3f);
  246.
  247. WriteCommandL(0xc0); //SET START ADDRESS
  248. WriteCommandM(0xc0);
  249. WriteCommandR(0xc0);
  250.
  251. WriteCommandL(0x3f); //DISPLAY ON
  252. WriteCommandM(0x3f);
  253. WriteCommandR(0x3f);
  254.
  255. }
  256.
  257. void LcmPutDots( unsigned char DotByte,unsigned char DotByte1 )
  258. {
  259. Page = 0;
  260. Col  = 0;
  261. for(Page=0;Page<8;Page++)
  262. {
  263.   for(Col=0;Col<192;Col++)
  264.   {
  265.    WriteData( DotByte );
  266.    Col++;
  267.    WriteData( DotByte1 );
  268.   }
  269.
  270. }
  271. }
  272.
  273. void LcmPutBMP( unsigned char *puts )
  274. {
  275. unsigned int X=0;
  276. Page = 0;
  277. Col  = 0;
  278. for(Page=0;Page<8;Page++)
  279. {
  280.   for(Col=0;Col<192;Col++)
  281.   {
  282.    WriteData( puts[X] );
  283.    X++;
  284.   }
  285. }
  286. }
  287.
  288. void LcmReverseBMP( void )
  289. {
  290. unsigned char temp;
  291. Page = 0;
  292. Col  = 0;
  293. for(Page=0;Page<8;Page++)
  294. {
  295.   for(Col=0;Col<192;Col++)
  296.   {
  297.    temp = ReadData();
  298.    temp = ReadData();
  299.    temp = ~temp;
  300.    WriteData(temp);
  301.   }
  302. }
  303. }
  304. void Display_8_8(unsigned char C[],unsigned char i)
  305. { unsigned char k,num=0;
  306. num=i*0x08;
  307. for(k=0;k<0x08;k++)
  308. {
  309.   WriteData(C[num+k]);
  310.   Col+=0x01;
  311. }
  312. }
  313. void Display_16_16(unsigned char F[],unsigned char i)
  314. {
  315. unsigned char k=0;
  316. unsigned int        num=0;
  317. num=i*0x20;
  318. for(k=0;k<0x10;k++)
  319. {
  320.   WriteData(F[num+k]);
  321.   Col+=0x01;
  322. }
  323.   Col-=0x10;
  324.   Page+=0x01;
  325.   for(k=16;k<0x20;k++)
  326. {
  327.   WriteData(F[num+k]);
  328.   Col+=0x01;
  329. }
  330.   Page-=0x01;
  331.   Delay(80);
  332. }
  333. void Display_character()
  334. { unsigned char k,c, a=0;
  335. Col  = 0;
  336. for(c=0;c<8;c++)
  337. { Page = c;
  338.         for(k=0;k<24;k++)
  339.         { Display_8_8(character,0);
  340.         }
  341. Col  = 0;
  342. }
  343.   Delay(1500);
  344. for(c=0;c<8;c++)
  345. { Page = c;
  346.         for(k=0;k<24;k++)
  347.         { Display_8_8(character,1);
  348.         }
  349. Col  = 0;
  350. }
  351.   Delay(1500);
  352. for(c=0;c<8;c++)
  353. { Page = c;
  354.         for(k=0;k<24;k++)
  355.         { Display_8_8(character,2);
  356.         }
  357. Col  = 0;
  358. }
  359.   Delay(1500);
  360. }
  361. void Display_Chinese()
  362. {unsigned char a=0;
  363. Page = 0;
  364. Col  = 0;
  365. for(a=0;a<12;a++)
  366. {
  367. Display_16_16(font,a);
  368. }
  369. Page = 2;
  370. Col  = 0;
  371. for(a=12;a<24;a++)
  372. {
  373. Display_16_16(font,a);
  374. }
  375. Page = 4;
  376. Col  = 0;
  377. for(a=24;a<36;a++)
  378. {
  379. Display_16_16(font,a);
  380. }
  381. Page = 6;
  382. Col  = 0;
  383. for(a=36;a<48;a++)
  384. {
  385. Display_16_16(font,a);
  386. }
  387. }
  388.
  389. void Delay(unsigned int MS)
  390. {
  391. unsigned char us,usn;
  392. while(MS!=0)
  393. {
  394.   usn = 2; //for 12M
  395.   while(usn!=0)
  396.   {
  397.    us=0xf6;
  398.    while (us!=0){us--;};
  399.    usn--;
  400.   }
  401.   MS--;
  402. }
  403. while(log);
  404. }
  405. void Step(void) interrupt 0 using 0
  406. { _nop_();
  407.   _nop_();
  408.   _nop_();
  409.   _nop_();
  410.   _nop_();
  411.   _nop_();
  412.   _nop_();
  413.   _nop_();
  414.   _nop_();
  415.   _nop_();
  416.   _nop_();
  417.   _nop_();
  418.   _nop_();
  419.   _nop_();
  420.   _nop_();
  421.   _nop_();
  422.   _nop_();
  423.   _nop_();
  424.   _nop_();
  425.   _nop_();
  426.   _nop_();
  427.   _nop_();
  428.   _nop_();
  429.   _nop_();
  430.   _nop_();
  431.   _nop_();
  432.   _nop_();
  433.   _nop_();
  434.   _nop_();
  435.   _nop_();
  436.   _nop_();
  437.   _nop_();
  438.   _nop_();
  439.   _nop_();
  440.   _nop_();
  441.   _nop_();
  442.   _nop_();
  443.   _nop_();
  444.         if(int0==0)
  445.         log=!log;
  446.     while(!int0);
  447.   return;
  448. }
  449.
  450. void Main( void )
  451. {
  452. Delay(20);
  453. IE=0x81;
  454. IP=0x01;
  455. TCON=0x01;
  456. int0=1;
  457. LcmInit();
  458. LcmClear();
  459. while(1)
  460. {
  461. /*LcmPutDots(0x55,0xaa);
  462. Delay(1000);
  463.   LcmPutDots(0xaa,0x55);
  464.   Delay(1000);
  465.
  466. LcmPutDots(0x55,0x55);
  467. Delay(1000);
  468.   LcmPutDots(0xaa,0xaa);
  469.   Delay(1000);
  470.   LcmPutDots(0xff,0x00);
  471.   Delay(2000);
  472.   LcmPutDots(0x00,0xff);
  473.   Delay(1000);
  474. */
  475.   LcmPutBMP(BMP0);
  476.   Delay(1500);
  477. LcmReverseBMP();
  478.   Delay(1500);
  479.   LcmPutBMP(BMP1);
  480.   Delay(1500);
  481.   LcmReverseBMP();
  482.   Delay(1500);
  483.   LcmPutBMP(BMP2);
  484.   Delay(1500);
  485. LcmReverseBMP();
  486.   Delay(1500);
  487.   LcmClear();
  488.   Display_Chinese();
  489.   Delay(1500);
  490.   Delay(1500);
  491.   Display_character();
  492. }
  493. }
  494.
  495. unsigned char code font[]=
  496. {
  497. /*--  ОДЧЦ:  Йо  --*/
  498. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  499. 0x10,0x61,0x06,0xE0,0x00,0x26,0x22,0x1A,0x02,0xC2,0x0A,0x12,0x32,0x06,0x02,0x00,
  500. 0x04,0xFC,0x03,0x20,0x20,0x11,0x11,0x09,0x05,0xFF,0x05,0x09,0x19,0x31,0x10,0x00,
  501. /*--  ОДЧЦ:  ЫЪ  --*/
  502. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  503. 0x10,0x10,0x10,0xFE,0x10,0x10,0xFE,0x00,0x00,0xFC,0x00,0x00,0x00,0xFE,0x00,0x00,
  504. 0x08,0x08,0x04,0x47,0x24,0x18,0x07,0x00,0x00,0x1F,0x00,0x00,0x00,0x7F,0x00,0x00,
  505. /*--  ОДЧЦ:  Рс  --*/
  506. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  507. 0x10,0x10,0x10,0xFF,0x10,0xF0,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,
  508. 0x40,0x30,0x0E,0x01,0x00,0x3F,0x40,0x40,0x47,0x44,0x44,0x44,0x44,0x47,0x70,0x00,
  509. /*--  ОДЧЦ:  ИХ  --*/
  510. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  511. 0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00,
  512. 0x00,0x00,0x00,0x3F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00,
  513. /*--  ОДЧЦ:  ¶«  --*/
  514. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  515. 0x00,0x04,0x04,0xC4,0xB4,0x8C,0x87,0x84,0xF4,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
  516. 0x00,0x00,0x20,0x18,0x0E,0x04,0x20,0x40,0xFF,0x00,0x02,0x04,0x18,0x30,0x00,0x00,
  517. /*--  ОДЧЦ:  ·Ѕ  --*/
  518. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  519. 0x08,0x08,0x08,0x08,0x08,0x08,0xF9,0x4A,0x4C,0x48,0x48,0xC8,0x08,0x08,0x08,0x00,
  520. 0x40,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x20,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,
  521. /*--  ОДЧЦ:  їЖ  --*/
  522. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  523. 0x10,0x12,0x92,0x72,0xFE,0x51,0x91,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,
  524. 0x04,0x02,0x01,0x00,0xFF,0x00,0x04,0x04,0x04,0x02,0x02,0x02,0xFF,0x01,0x01,0x00,
  525. /*--  ОДЧЦ:  јј  --*/
  526. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  527. 0x08,0x08,0x88,0xFF,0x48,0x28,0x00,0xC8,0x48,0x48,0x7F,0x48,0xC8,0x48,0x08,0x00,
  528. 0x01,0x41,0x80,0x7F,0x00,0x40,0x40,0x20,0x13,0x0C,0x0C,0x12,0x21,0x60,0x20,0x00,
  529. /*--  ОДЧЦ:  УР  --*/
  530. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  531. 0x00,0x04,0x84,0x44,0xE4,0x34,0x2C,0x27,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00,
  532. 0x02,0x01,0x00,0x00,0xFF,0x09,0x09,0x09,0x29,0x49,0xC9,0x7F,0x00,0x00,0x00,0x00,
  533. /*--  ОДЧЦ:  ПЮ  --*/
  534. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  535. 0xFE,0x02,0x32,0x4E,0x82,0x00,0xFE,0x4A,0xCA,0x4A,0x4A,0x4A,0x7E,0x00,0x00,0x00,
  536. 0xFF,0x00,0x02,0x04,0x03,0x00,0xFF,0x40,0x20,0x03,0x0C,0x12,0x21,0x60,0x20,0x00,
  537. /*--  ОДЧЦ:  №«  --*/
  538. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  539. 0x00,0x00,0x80,0x40,0x30,0x0E,0x84,0x00,0x00,0x0E,0x10,0x60,0xC0,0x80,0x80,0x00,
  540. 0x00,0x01,0x20,0x70,0x28,0x24,0x23,0x31,0x10,0x10,0x14,0x78,0x30,0x01,0x00,0x00,
  541. /*--  ОДЧЦ:  Лѕ  --*/
  542. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  543. 0x00,0x10,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x12,0x02,0x02,0xFE,0x00,0x00,
  544. 0x00,0x00,0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x0F,0x00,0x20,0x40,0x3F,0x00,0x00,
  545. /*--  ОДЧЦ:  ґґ  --*/
  546. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  547. 0x40,0x20,0xD0,0x4C,0x43,0x44,0x48,0xD8,0x30,0x10,0x00,0xFC,0x00,0x00,0xFF,0x00,
  548. 0x00,0x00,0x3F,0x40,0x40,0x42,0x44,0x43,0x78,0x00,0x00,0x07,0x20,0x40,0x3F,0x00,
  549. /*--  ОДЧЦ:  ЅЁ  --*/
  550. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  551. 0x00,0x42,0x62,0x5A,0xC6,0x10,0x54,0x54,0x54,0xFF,0x54,0x54,0x7C,0x10,0x10,0x00,
  552. 0x40,0x23,0x14,0x08,0x17,0x28,0x29,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x40,0x00,
  553. /*--  ОДЧЦ:  УЪ  --*/
  554. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  555. 0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x40,0x00,
  556. 0x00,0x00,0x00,0x00,0x20,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  557. /*--  ОДЧЦ:  ¶ю  --*/
  558. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  559. 0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,
  560. 0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x18,0x10,0x00,
  561. /*--  ОДЧЦ:  Бг  --*/
  562. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  563. 0x00,0x0C,0x04,0x55,0x55,0x55,0x85,0x7F,0x85,0x55,0x55,0x55,0x05,0x0C,0x04,0x00,
  564. 0x04,0x04,0x04,0x0A,0x0A,0x09,0x2A,0xCC,0x28,0x19,0x09,0x02,0x06,0x02,0x02,0x00,
  565. /*--  ОДЧЦ:  Бг  --*/
  566. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  567. 0x00,0x0C,0x04,0x55,0x55,0x55,0x85,0x7F,0x85,0x55,0x55,0x55,0x05,0x0C,0x04,0x00,
  568. 0x04,0x04,0x04,0x0A,0x0A,0x09,0x2A,0xCC,0x28,0x19,0x09,0x02,0x06,0x02,0x02,0x00,
  569. /*--  ОДЧЦ:  Иэ  --*/
  570. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  571. 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
  572. 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  573. /*--  ОДЧЦ:  Дк  --*/
  574. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  575. 0x40,0x20,0x10,0x0C,0xE3,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0x02,0x00,0x00,
  576. 0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
  577. /*--  ОДЧЦ:  КЗ  --*/
  578. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  579. 0x80,0x80,0x80,0x80,0xBE,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xBE,0x80,0x80,0x80,0x00,
  580. 0x00,0x40,0x20,0x10,0x0E,0x10,0x20,0x3F,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
  581. /*--  ОДЧЦ:  Т»  --*/
  582. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  583. 0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x00,
  584. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  585. /*--  ОДЧЦ:  јТ  --*/
  586. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  587. 0x00,0x18,0x04,0x14,0x94,0x94,0xD5,0xB6,0x14,0x14,0x94,0x04,0x14,0x0C,0x04,0x00,
  588. 0x00,0x29,0x29,0x15,0x14,0x4A,0x89,0x44,0x3F,0x06,0x09,0x09,0x10,0x30,0x10,0x00,
  589. /*--  ОДЧЦ:  ЧЁ  --*/
  590. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  591. 0x20,0x20,0x24,0x24,0xA4,0x64,0x3C,0x27,0x24,0x24,0xA4,0x24,0x24,0x20,0x20,0x00,
  592. 0x00,0x00,0x00,0x00,0x01,0x01,0x09,0x11,0x29,0x45,0x03,0x01,0x00,0x00,0x00,0x00,
  593. /*--  ОДЧЦ:  ГЕ  --*/
  594. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  595. 0x00,0x00,0xF8,0x01,0x06,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,
  596. 0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,
  597. /*--  ОДЧЦ:  ґУ  --*/
  598. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  599. 0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x80,0x7F,0x80,0x00,0x00,0x00,0x00,0x00,
  600. 0x40,0x20,0x18,0x07,0x80,0x41,0x36,0x18,0x07,0x00,0x01,0x06,0x18,0x70,0x20,0x00,
  601. /*--  ОДЧЦ:  КВ  --*/
  602. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  603. 0x02,0x02,0x82,0xBA,0xAA,0xAA,0xAA,0xFF,0xAA,0xAA,0xAA,0xAA,0xBA,0x02,0x02,0x00,
  604. 0x02,0x02,0x0A,0x0A,0x2A,0x4A,0x8A,0x7F,0x0A,0x0A,0x0A,0x0A,0x1F,0x02,0x02,0x00,
  605. /*--  ОДЧЦ:  Тє  --*/
  606. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  607. 0x10,0x61,0x06,0xE0,0x18,0x84,0xE4,0x1C,0x84,0x65,0xBE,0x24,0xA4,0x64,0x04,0x00,
  608. 0x04,0x04,0xFF,0x00,0x01,0x00,0xFF,0x41,0x21,0x12,0x0C,0x1B,0x61,0xC0,0x40,0x00,
  609. /*--  ОДЧЦ:  ѕ§  --*/
  610. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  611. 0x00,0x00,0x00,0x00,0x7E,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x7E,0x00,0x00,0x00,0x00,
  612. 0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,
  613. /*--  ОДЧЦ:  ЖБ  --*/
  614. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  615. 0x00,0x00,0xFF,0x09,0x49,0x59,0xE9,0x49,0x49,0x49,0xE9,0x59,0x49,0x4F,0x00,0x00,
  616. 0x40,0x30,0x0F,0x82,0x42,0x32,0x0F,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x00,
  617. /*--  ОДЧЦ:  Тє  --*/
  618. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  619. 0x10,0x61,0x06,0xE0,0x18,0x84,0xE4,0x1C,0x84,0x65,0xBE,0x24,0xA4,0x64,0x04,0x00,
  620. 0x04,0x04,0xFF,0x00,0x01,0x00,0xFF,0x41,0x21,0x12,0x0C,0x1B,0x61,0xC0,0x40,0x00,
  621. /*--  ОДЧЦ:  ѕ§  --*/
  622. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  623. 0x00,0x00,0x00,0x00,0x7E,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x7E,0x00,0x00,0x00,0x00,
  624. 0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,
  625. /*--  ОДЧЦ:  ДЈ  --*/
  626. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  627. 0x10,0xD0,0xFF,0x50,0x90,0x04,0xF4,0x54,0x5F,0x54,0x54,0x5F,0xF4,0x04,0x00,0x00,
  628. 0x03,0x00,0xFF,0x00,0x00,0x84,0x85,0x45,0x35,0x0F,0x15,0x25,0x65,0xC4,0x44,0x00,
  629. /*--  ОДЧЦ:  їй  --*/
  630. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  631. 0x10,0x10,0xFF,0x10,0x10,0x00,0x08,0x08,0xFF,0x08,0x08,0x08,0xF8,0x00,0x00,0x00,
  632. 0x08,0x18,0x0F,0x04,0x85,0x41,0x31,0x0D,0x03,0x05,0x09,0x11,0x31,0x61,0x21,0x00,
  633. /*--  ОДЧЦ:  СР  --*/
  634. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  635. 0x02,0xC2,0xF2,0x4E,0xC2,0x02,0x40,0x42,0xFE,0x42,0x42,0x42,0xFE,0x42,0x42,0x00,
  636. 0x01,0x00,0x3F,0x10,0x9F,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
  637. /*--  ОДЧЦ:  ·ў  --*/
  638. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  639. 0x00,0x10,0x3E,0x10,0x10,0xF0,0x9F,0x90,0x90,0x92,0x94,0x1C,0x10,0x10,0x10,0x00,
  640. 0x40,0x20,0x10,0x88,0x87,0x41,0x46,0x28,0x10,0x28,0x27,0x40,0xC0,0x40,0x00,0x00,
  641. /*--  ОДЧЦ:  μД  --*/
  642. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  643. 0x00,0xF8,0x8C,0x8B,0x88,0xF8,0x40,0x30,0x8F,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,
  644. 0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x03,0x26,0x40,0x20,0x1F,0x00,0x00,
  645. /*--  ОДЧЦ:  ёЯ  --*/
  646. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  647. 0x04,0x04,0x04,0x04,0x74,0x54,0x55,0x56,0x54,0x54,0x74,0x04,0x04,0x04,0x04,0x00,
  648. 0x00,0xFF,0x01,0x01,0x3D,0x25,0x25,0x25,0x25,0x25,0x3D,0x41,0x81,0x7F,0x00,0x00,
  649. /*--  ОДЧЦ:  РВ  --*/
  650. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  651. 0x20,0x24,0x2C,0x35,0xE6,0x34,0x2C,0x24,0x00,0xFC,0x24,0x24,0xE2,0x22,0x22,0x00,
  652. 0x21,0x11,0x4D,0x81,0x7F,0x05,0x59,0x21,0x18,0x07,0x00,0x00,0xFF,0x00,0x00,0x00,
  653. /*--  ОДЧЦ:  їЖ  --*/
  654. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  655. 0x10,0x12,0x92,0x72,0xFE,0x51,0x91,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,
  656. 0x04,0x02,0x01,0x00,0xFF,0x00,0x04,0x04,0x04,0x02,0x02,0x02,0xFF,0x01,0x01,0x00,
  657. /*--  ОДЧЦ:  јј  --*/
  658. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  659. 0x08,0x08,0x88,0xFF,0x48,0x28,0x00,0xC8,0x48,0x48,0x7F,0x48,0xC8,0x48,0x08,0x00,
  660. 0x01,0x41,0x80,0x7F,0x00,0x40,0x40,0x20,0x13,0x0C,0x0C,0x12,0x21,0x60,0x20,0x00,
  661. /*--  ОДЧЦ:  Жу  --*/
  662. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  663. 0x80,0x80,0x40,0x40,0x20,0x10,0x08,0xC7,0x8A,0x10,0x20,0x60,0x40,0xC0,0x40,0x00,
  664. 0x40,0x40,0x40,0x7F,0x42,0x40,0x40,0x7F,0x42,0x42,0x42,0x43,0x42,0x60,0x40,0x00,
  665. /*--  ОДЧЦ:  Тμ  --*/
  666. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  667. 0x00,0x10,0x60,0x80,0x00,0xFF,0x00,0x00,0x00,0xFF,0x00,0x80,0x60,0x38,0x10,0x00,
  668. 0x20,0x20,0x20,0x23,0x21,0x3F,0x20,0x20,0x20,0x3F,0x22,0x21,0x20,0x30,0x20,0x00,
  669. /*--  ОДЧЦ:  №«  --*/
  670. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  671. 0x00,0x00,0x80,0x40,0x30,0x0E,0x84,0x00,0x00,0x0E,0x10,0x60,0xC0,0x80,0x80,0x00,
  672. 0x00,0x01,0x20,0x70,0x28,0x24,0x23,0x31,0x10,0x10,0x14,0x78,0x30,0x01,0x00,0x00,
  673. /*--  ОДЧЦ:  Лѕ  --*/
  674. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  675. 0x00,0x10,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x12,0x02,0x02,0xFE,0x00,0x00,
  676. 0x00,0x00,0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x0F,0x00,0x20,0x40,0x3F,0x00,0x00,
  677. /*--  ОДЧЦ:  ЧЁ  --*/
  678. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  679. 0x20,0x20,0x24,0x24,0xA4,0x64,0x3C,0x27,0x24,0x24,0xA4,0x24,0x24,0x20,0x20,0x00,
  680. 0x00,0x00,0x00,0x00,0x01,0x01,0x09,0x11,0x29,0x45,0x03,0x01,0x00,0x00,0x00,0x00,
  681. /*--  ОДЧЦ:  Чў  --*/
  682. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  683. 0x10,0x60,0x01,0x86,0x60,0x08,0x08,0x08,0x09,0xFE,0x08,0x08,0x08,0x08,0x08,0x00,
  684. 0x04,0x04,0xFE,0x01,0x40,0x40,0x41,0x41,0x41,0x7F,0x41,0x41,0x41,0x41,0x40,0x00,
  685. /*--  ОДЧЦ:  УЪ  --*/
  686. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  687. 0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x40,0x00,
  688. 0x00,0x00,0x00,0x00,0x20,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  689. /*--  ОДЧЦ:  Пт  --*/
  690. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  691. 0x00,0x00,0xFC,0x04,0x04,0xE6,0x25,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x00,0x00,
  692. 0x00,0x00,0x7F,0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x0F,0x20,0x40,0x3F,0x00,0x00,
  693. /*--  ОДЧЦ:  УГ  --*/
  694. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  695. 0x00,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,
  696. 0x80,0x40,0x30,0x0F,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x42,0x82,0x7F,0x00,0x00,
  697. /*--  ОДЧЦ:  »§  --*/
  698. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  699. 0x00,0x00,0x00,0xF8,0x88,0x88,0x88,0x89,0x8A,0x8E,0x88,0x88,0x88,0xF8,0x00,0x00,
  700. 0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  701. /*--  ОДЧЦ:  Мб  --*/
  702. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  703. 0x08,0x08,0x88,0xFF,0x48,0x88,0x80,0xBE,0xAA,0xAA,0xAA,0xAA,0xBE,0x80,0x00,0x00,
  704. 0x02,0x41,0x80,0x7F,0x40,0x30,0x1E,0x20,0x20,0x7F,0x44,0x44,0x44,0x44,0x40,0x00,
  705. /*--  ОДЧЦ:  №©  --*/
  706. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  707. 0x40,0x20,0xF8,0x17,0x02,0x10,0x10,0xFE,0x10,0x10,0x10,0xFE,0x10,0x10,0x00,0x00,
  708. 0x00,0x00,0xFF,0x00,0x42,0x22,0x1A,0x0F,0x02,0x02,0x06,0x1B,0x72,0x22,0x02,0x00,
  709. /*--  ОДЧЦ:  ёЯ  --*/
  710. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  711. 0x04,0x04,0x04,0x04,0x74,0x54,0x55,0x56,0x54,0x54,0x74,0x04,0x04,0x04,0x04,0x00,
  712. 0x00,0xFF,0x01,0x01,0x3D,0x25,0x25,0x25,0x25,0x25,0x3D,0x41,0x81,0x7F,0x00,0x00,
  713. /*--  ОДЧЦ:  Ж·  --*/
  714. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  715. 0x00,0x00,0x00,0x00,0x7E,0x22,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,0x00,0x00,
  716. 0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,
  717. /*--  ОДЧЦ:  ЦК  --*/
  718. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  719. 0x00,0x00,0xFE,0x02,0x0A,0xCA,0x4A,0x6A,0x5E,0x49,0x49,0xC9,0x09,0x01,0x00,0x00,
  720. 0x80,0x60,0x1F,0x00,0x80,0x4F,0x20,0x10,0x0F,0x10,0x20,0xEF,0x40,0x00,0x00,0x00,
  721. /*--  ОДЧЦ:  μД  --*/
  722. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  723. 0x00,0xF8,0x8C,0x8B,0x88,0xF8,0x40,0x30,0x8F,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,
  724. 0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x03,0x26,0x40,0x20,0x1F,0x00,0x00,
  725. /*--  ОДЧЦ:  Тє  --*/
  726. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  727. 0x10,0x61,0x06,0xE0,0x18,0x84,0xE4,0x1C,0x84,0x65,0xBE,0x24,0xA4,0x64,0x04,0x00,
  728. 0x04,0x04,0xFF,0x00,0x01,0x00,0xFF,0x41,0x21,0x12,0x0C,0x1B,0x61,0xC0,0x40,0x00,
  729. /*--  ОДЧЦ:  ѕ§  --*/
  730. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  731. 0x00,0x00,0x00,0x00,0x7E,0x2A,0x2A,0x2A,0x2A,0x2A,0x2A,0x7E,0x00,0x00,0x00,0x00,
  732. 0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,0x00,0x7F,0x25,0x25,0x25,0x25,0x7F,0x00,
  733. /*--  ОДЧЦ:  Іъ  --*/
  734. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  735. 0x00,0x04,0xE4,0x44,0x4C,0x74,0x54,0x45,0x46,0x64,0x54,0x4C,0x44,0x64,0x44,0x00,
  736. 0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  737. /*--  ОДЧЦ:  Ж·  --*/
  738. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  739. 0x00,0x00,0x00,0x00,0x7E,0x22,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,0x00,0x00,
  740. 0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,
  741. /*--  ОДЧЦ:  ј°  --*/
  742. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  743. 0x00,0x00,0x02,0x02,0x82,0x7E,0x82,0x02,0x42,0xF2,0x4E,0xC0,0x40,0x00,0x00,0x00,
  744. 0x40,0x20,0x90,0x8C,0x43,0x40,0x21,0x16,0x08,0x08,0x16,0x21,0x60,0xC0,0x40,0x00,
  745. /*--  ОДЧЦ:  ·ю  --*/
  746. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  747. 0x00,0x00,0xFF,0x91,0x91,0xFF,0x00,0x00,0xFF,0xC1,0x41,0x49,0x51,0xCF,0x00,0x00,
  748. 0x40,0x30,0x0F,0x20,0x40,0x3F,0x00,0x00,0x7F,0x21,0x16,0x08,0x36,0x61,0x20,0x00,
  749. /*--  ОДЧЦ:  Ос  --*/
  750. /*--  ЛОМе12;  ґЛЧЦМеПВ¶ФУ|μДμгХуОЄЈєїнxёЯ=16x16   --*/
  751. 0x20,0x10,0x10,0x88,0x84,0x4F,0x52,0xA2,0x22,0x52,0x4A,0x86,0x80,0x80,0x80,0x00,
  752. 0x80,0x81,0x41,0x42,0x22,0x12,0x0E,0x03,0x02,0x42,0x82,0x7E,0x00,0x01,0x00,0x00
  753. };
  754. unsigned char code BMP0[]={
  755. /*--  TVI Electronics, LLC --*/
  756. /*--  192x64  --*/
  757. 0x7F,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x48,
  758. 0x48,0x48,0x48,0x00,0xC0,0xB0,0x88,0xB0,0xC0,0x00,0x30,0x48,0x48,0x90,0x00,0x08,
  759. 0x08,0xF8,0x08,0x08,0x00,0xF8,0x48,0x48,0xC8,0x30,0x00,0x00,0xF8,0x00,0x00,0x30,
  760. 0x48,0x48,0x90,0x00,0x00,0xF8,0x00,0x00,0xF8,0x30,0x40,0x80,0xF8,0x00,0x00,0xF0,
  761. 0x08,0x08,0x48,0xD0,0x00,0x00,0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xF8,0x48,
  762. 0x48,0x48,0x48,0x00,0xF0,0x08,0x08,0x08,0x10,0x00,0x00,0xF8,0x40,0x40,0x40,0xF8,
  763. 0x00,0x00,0xF8,0x30,0x40,0x80,0xF8,0x00,0x00,0xF0,0x08,0x08,0x08,0xF0,0x00,0x00,
  764. 0xF8,0x00,0x00,0x00,0x00,0xF0,0x08,0x08,0x08,0xF0,0x00,0x00,0xF0,0x08,0x08,0x48,
  765. 0xD0,0x00,0x00,0x08,0x30,0xC0,0x30,0x08,0x00,0x00,0x00,0x00,0x00,0xF0,0x08,0x08,
  766. 0x08,0x10,0x00,0x00,0xF0,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  767. 0x00,0xF8,0x00,0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xF8,0x08,0x08,0x08,0xF0,
  768. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x7F,
  769. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x02,
  770. 0x02,0x02,0x02,0x02,0x01,0x00,0x00,0x00,0x01,0x02,0x01,0x02,0x02,0x01,0x00,0x00,
  771. 0x00,0x03,0x00,0x00,0xE0,0x03,0x00,0x00,0xC0,0x43,0x40,0x40,0xC3,0x00,0x00,0x01,
  772. 0x02,0xE2,0x21,0x20,0x20,0x23,0x20,0x20,0xE3,0x00,0x00,0x41,0x43,0x40,0x40,0xC1,
  773. 0x62,0x42,0x42,0x41,0x40,0x40,0x00,0x80,0x80,0x80,0x83,0x80,0xA0,0xC0,0x83,0x82,
  774. 0xC2,0x82,0x02,0x40,0x41,0xC2,0x22,0x22,0x01,0x40,0x80,0x03,0xE0,0x00,0x00,0x83,
  775. 0x80,0xE0,0x83,0x00,0x80,0x81,0xE3,0x80,0x80,0x81,0x02,0x42,0x42,0x41,0x40,0xC0,
  776. 0x63,0x42,0x42,0x42,0x40,0x41,0x02,0xE2,0x22,0x21,0xE0,0x00,0xE1,0xA2,0xA2,0xA2,
  777. 0xE1,0x00,0x00,0x00,0x00,0x03,0xE0,0x00,0x00,0x60,0x80,0x00,0x00,0x01,0x02,0x02,
  778. 0x22,0x21,0x20,0x20,0x21,0xA2,0x22,0x22,0xE1,0x00,0x00,0x02,0x00,0x08,0x06,0x00,
  779. 0x00,0x03,0x02,0x02,0x02,0x00,0x00,0x03,0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x01,
  780. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  781. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  782. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  783. 0x00,0x00,0x00,0xC1,0x3F,0x01,0xFF,0x80,0xBF,0x92,0x92,0x92,0xBF,0xC0,0x00,0x00,
  784. 0x00,0xFF,0x42,0x42,0x42,0x42,0x42,0x42,0xFF,0x00,0x00,0x40,0x44,0x26,0x15,0x84,
  785. 0xFF,0x04,0x0C,0x14,0x24,0x40,0x00,0x80,0x80,0x40,0x30,0x0F,0x82,0x82,0x82,0x7E,
  786. 0x00,0x00,0x00,0x31,0x0D,0xFF,0x05,0x09,0x10,0x12,0x14,0x10,0xFF,0x08,0x00,0x88,
  787. 0x88,0xFF,0x04,0x80,0x8C,0x54,0x27,0x54,0x8C,0x80,0x00,0x08,0x04,0x02,0xFF,0x29,
  788. 0x29,0x29,0xA9,0xFF,0x00,0x00,0x00,0xFF,0x10,0x13,0x1C,0x00,0xFF,0x84,0x5C,0x24,
  789. 0x57,0x88,0x00,0x04,0x82,0xC1,0xA0,0x98,0x86,0x50,0x61,0xC2,0x04,0x04,0x00,0x01,
  790. 0x01,0x3D,0x25,0x25,0x25,0x3D,0x81,0x80,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  791. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  792. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  793. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  794. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  795. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  796. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  797. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  798. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  799. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  800. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  801. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  802. 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  803. 0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  804. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  805. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  806. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x0F,0x01,0x01,0x01,0x01,0x01,
  807. 0x01,0xFD,0xFD,0xCD,0xCD,0xCD,0xCD,0xCD,0xCD,0x01,0x01,0xFD,0xFD,0x8D,0x8D,0x8D,
  808. 0x8D,0x8D,0xFD,0x79,0x01,0x01,0xFD,0xFD,0x3D,0xF1,0x81,0x01,0x81,0xF1,0x3D,0xFD,
  809. 0xFD,0x01,0x01,0x61,0x31,0x19,0xFD,0xFD,0x01,0x01,0xF1,0xF9,0x8D,0x8D,0x8D,0xF9,
  810. 0xF1,0x01,0x31,0x39,0x0D,0x0D,0x8D,0xFD,0x79,0x01,0xF1,0xF9,0xDD,0xCD,0xCD,0xDD,
  811. 0x99,0x01,0x01,0x81,0xE1,0x39,0xFD,0xFD,0x01,0x01,0x81,0x81,0x81,0x81,0x01,0x19,
  812. 0x1D,0x0D,0xCD,0xCD,0xFD,0x39,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xC1,0xE1,
  813. 0x21,0x21,0x61,0x41,0x01,0x01,0x81,0x81,0x81,0x81,0x01,0x01,0x81,0x81,0x81,0x81,
  814. 0x01,0xA1,0xA1,0x01,0x01,0x81,0x81,0x81,0x81,0x01,0x01,0x01,0x81,0x81,0x81,0x81,
  815. 0x01,0x01,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  816. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  817. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  818. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0x80,0x80,0x80,0x80,0x80,
  819. 0x80,0x9F,0x9F,0x98,0x98,0x98,0x98,0x98,0x98,0x80,0x80,0x9F,0x9F,0x81,0x81,0x81,
  820. 0x83,0x87,0x9E,0x9C,0x90,0x80,0x9F,0x9F,0x80,0x81,0x8F,0x9E,0x8F,0x81,0x80,0x9F,
  821. 0x9F,0x80,0x80,0x80,0x80,0x80,0x9F,0x9F,0x80,0x80,0x8C,0x9D,0x99,0x99,0x9D,0x8F,
  822. 0x87,0x80,0x98,0x9C,0x9E,0x9B,0x99,0x98,0x98,0x80,0x87,0x8F,0x98,0x98,0x98,0x8F,
  823. 0x87,0x80,0x87,0x87,0x86,0x86,0x9F,0x9F,0x86,0x80,0x81,0x81,0x81,0x81,0x80,0x86,
  824. 0x8E,0x9C,0x98,0x98,0x8F,0x87,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x89,0x99,
  825. 0x93,0x93,0x9E,0x8E,0x80,0x8F,0x9F,0x92,0x92,0x9B,0x8B,0x80,0x9F,0x9F,0x80,0x80,
  826. 0x80,0x9F,0x9F,0x80,0x8F,0x9F,0x92,0x92,0x9B,0x8B,0x80,0x8B,0x9B,0x96,0x96,0x9D,
  827. 0x8D,0x80,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  828. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  829. 0x00,0x00,0xC0,0x60,0xF0,0xF0,0x00,0x00,0xE0,0xF0,0x10,0x10,0xF0,0xE0,0x00,0x20,
  830. 0x30,0x10,0x10,0xF0,0xE0,0x00,0x00,0xA0,0x70,0xA1,0x01,0xC1,0xE1,0x91,0x91,0xB1,
  831. 0x21,0x01,0x01,0x81,0x61,0xF1,0xF1,0x01,0x01,0x01,0x01,0x01,0xC1,0xC1,0x81,0x41,
  832. 0xC1,0x81,0x01,0xD1,0xD1,0x01,0xC1,0xC1,0x01,0x01,0xC1,0xC1,0x01,0x81,0xC1,0x41,
  833. 0x41,0xC1,0x81,0x01,0xF1,0xF1,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  834. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xF1,
  835. 0xF1,0x11,0x11,0x11,0xF1,0xE1,0x01,0xC1,0xC1,0x01,0x01,0xC1,0xC1,0xC1,0xC1,0x01,
  836. 0x01,0x01,0xC1,0xC1,0x01,0x01,0x01,0x01,0x81,0xC1,0x41,0x81,0xF1,0xF1,0x01,0xD1,
  837. 0xD1,0x01,0x81,0xC1,0x41,0x41,0xC1,0x81,0x01,0xC1,0xC1,0x81,0x41,0xC1,0x81,0x01,
  838. 0xF1,0xF1,0x01,0x81,0x41,0x41,0x41,0xC1,0x81,0xC1,0xC1,0x01,0x01,0x01,0xC1,0xC1,
  839. 0x01,0x01,0x01,0x81,0xC0,0x40,0x40,0xC0,0x80,0x00,0x80,0xC0,0x40,0x40,0xC0,0x80,
  840. 0x00,0xC0,0xC0,0x80,0x40,0xC0,0xC0,0x80,0x40,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,
  841. 0xFE,0x80,0x80,0x80,0x9F,0x9F,0x80,0x00,0x09,0x1B,0x12,0x12,0x0F,0x07,0x00,0x18,
  842. 0x1C,0x16,0x13,0x11,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x10,0x10,0x1F,
  843. 0x0F,0x00,0x06,0x05,0x04,0x1F,0x1F,0x04,0x00,0x00,0x00,0x00,0x7F,0x7F,0x08,0x10,
  844. 0x1F,0x0F,0x00,0x1F,0x1F,0x00,0x18,0x1D,0x07,0x07,0x1D,0x18,0x00,0x0F,0x1F,0x12,
  845. 0x12,0x1B,0x0B,0x00,0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  846. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,
  847. 0x1F,0x11,0x11,0x11,0x1F,0x0E,0x00,0x0F,0x1F,0x10,0x08,0x1F,0x1F,0x40,0x47,0x7F,
  848. 0x38,0x1F,0x07,0x00,0x04,0x04,0x04,0x00,0x0F,0x1F,0x10,0x08,0x1F,0x1F,0x00,0x1F,
  849. 0x1F,0x00,0x09,0x1B,0x13,0x16,0x1E,0x0C,0x00,0x7F,0x7F,0x08,0x10,0x1F,0x0F,0x00,
  850. 0x1F,0x1F,0x00,0x0C,0x1E,0x13,0x11,0x1F,0x1F,0x40,0x47,0x7F,0x38,0x1F,0x07,0x00,
  851. 0x18,0x18,0x00,0x0F,0x1F,0x10,0x10,0x18,0x08,0x00,0x0F,0x1F,0x10,0x10,0x1F,0x0F,
  852. 0x00,0x1F,0x1F,0x00,0x00,0x1F,0x1F,0x00,0x00,0x9F,0x9F,0x80,0x80,0x80,0x80,0xFE,
  853. };
  854. unsigned char code BMP1[]={
  855. /*--  TVI Electronics, LLC --*/
  856. /*--  192x64  --*/
  857. 0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0xE0,0xF0,0x30,0x10,0x18,
  858. 0x18,0x18,0x10,0x30,0x18,0x0C,0x84,0x8F,0xCC,0xCC,0xDC,0xFC,0x70,0x40,0xC0,0xF0,
  859. 0xF8,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  860. 0x00,0x00,0x00,0x00,0x00,0xC0,0xF8,0xFC,0xFF,0xFE,0xE0,0x00,0x00,0x00,0x00,0x00,
  861. 0x00,0x00,0x80,0xE0,0xF0,0xF8,0xFC,0xFC,0xFE,0xFE,0xFC,0xF8,0xF0,0xF0,0x58,0x08,
  862. 0x0C,0x0E,0x0E,0x06,0x04,0x0C,0x0C,0x0C,0x04,0x04,0x1C,0xFC,0xEC,0xC0,0x80,0x00,
  863. 0x80,0x80,0xC0,0xC0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  864. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xFC,
  865. 0xFE,0xFE,0xFF,0xFF,0xBF,0xFF,0xFE,0xC3,0xC3,0xC1,0xC3,0xC3,0xC6,0xC6,0x86,0xC6,
  866. 0xCC,0xF8,0x90,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  867. 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0xFC,0xFC,0xFC,0xFC,0xFC,0xF8,0xE0,
  868. 0x90,0x98,0x08,0x0C,0x08,0x08,0x0C,0x14,0x1C,0x2C,0xE0,0x40,0x00,0x01,0x01,0x07,
  869. 0xE0,0xE0,0xF8,0xF8,0xF8,0xF8,0xF8,0xF0,0xF0,0x78,0x1C,0x3F,0x3F,0xBE,0xBF,0xFF,
  870. 0xDF,0xDD,0x8F,0x87,0x03,0x03,0x07,0x87,0xEF,0xEF,0x7F,0x7F,0xF7,0xF2,0xF3,0xE7,
  871. 0xEF,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x38,0x10,0x00,0x00,
  872. 0x30,0x30,0x38,0x3C,0x3F,0x3D,0x37,0x26,0x3D,0x39,0x7F,0xF8,0x80,0x00,0x00,0x00,
  873. 0x00,0x00,0x03,0x0F,0x9F,0x7F,0x1F,0x0F,0x7F,0x7F,0xFF,0xFF,0xFB,0xFB,0xFB,0xF6,
  874. 0xEE,0x7C,0x18,0x18,0x78,0xFC,0xFC,0xFC,0xFC,0xF4,0xF6,0xF7,0xFD,0xFD,0xF9,0x07,
  875. 0x1F,0x3F,0xFF,0xFF,0xFF,0xFF,0x7F,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  876. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x40,0xE0,0xF0,0x3C,0x1E,0x9B,0xD9,
  877. 0xD9,0x3B,0x03,0x03,0x03,0x03,0x81,0xC7,0x4F,0x7F,0x7F,0xFF,0xFE,0xFE,0x9E,0x1E,
  878. 0x0D,0x07,0x06,0x01,0x03,0x06,0x7C,0xF8,0xFC,0xFC,0xFC,0xFC,0xF8,0xF0,0x00,0x00,
  879. 0x00,0x00,0x00,0x80,0x60,0x30,0x19,0x0F,0x07,0x07,0x07,0x07,0x07,0x03,0x01,0x00,
  880. 0x00,0x01,0x01,0x1F,0x3F,0x7F,0x7F,0xFF,0x7F,0x7F,0x7F,0x33,0x1C,0xE0,0x00,0x00,
  881. 0x07,0x07,0x0F,0x1F,0x1F,0x1F,0xFF,0xFF,0x01,0x00,0xF8,0xFE,0xFF,0xFF,0x0F,0x03,
  882. 0x73,0x11,0x11,0xB3,0x0F,0x00,0x00,0x0F,0x03,0x18,0x04,0x0C,0xC8,0xC0,0xE3,0xFF,
  883. 0xFF,0xFF,0x7F,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,0x00,0x00,0x00,0x00,0x00,
  884. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x61,0x3F,0x7C,0xE8,0xC8,
  885. 0xC8,0xF8,0x3C,0xEF,0xF1,0xF8,0xFC,0xFC,0xFE,0xDE,0x6F,0x2F,0xFF,0xFF,0x3D,0x00,
  886. 0x00,0x00,0x00,0xE0,0xF8,0xF8,0xBD,0x3D,0xFD,0xFB,0xFB,0xF1,0xF1,0xE1,0x00,0x00,
  887. 0x00,0x00,0xFF,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  888. 0x00,0x00,0x00,0xF0,0xFC,0x06,0x03,0x61,0xC0,0x00,0x03,0x07,0x04,0x9A,0x1B,0x1B,
  889. 0x10,0x00,0x00,0x00,0x3C,0x7E,0xCF,0xC7,0xC0,0xE0,0xF0,0xFF,0xFF,0x7F,0x3F,0x00,
  890. 0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFF,0x1F,0x1F,0x1F,0x0F,0x0F,0x03,0x00,0xC0,
  891. 0x70,0x0C,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  892. 0x00,0x00,0x00,0x00,0x00,0x00,0x70,0xFC,0xFE,0x0F,0x07,0xE7,0xEE,0x09,0x1F,0xF0,
  893. 0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x07,0x0F,0x0F,0x0F,0x0F,0x0E,
  894. 0x0E,0x06,0x03,0x01,0x30,0x32,0x33,0x1F,0x1B,0x10,0x10,0x1C,0x0C,0x00,0x00,0x00,
  895. 0x00,0x00,0x00,0x80,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
  896. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x0E,0x1C,0x18,0x11,0x3B,
  897. 0x7F,0xFF,0x60,0xC3,0x87,0x0F,0x0F,0x0F,0x0F,0x8E,0x86,0x8F,0x9C,0x8C,0x80,0x80,
  898. 0x00,0x00,0x00,0x01,0x0C,0x0C,0x1D,0x1C,0x3F,0x3F,0x3F,0x1F,0x1F,0x0F,0x01,0x00,
  899. 0xC0,0xE0,0x7F,0x1F,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFC,
  900. 0xF8,0xE0,0xE0,0xE1,0xC7,0xDC,0xB0,0xE0,0x80,0x01,0x03,0x03,0x01,0x01,0x07,0x0C,
  901. 0x18,0x30,0x20,0x60,0x40,0x40,0x40,0x40,0x41,0x41,0x61,0x20,0x30,0x10,0x00,0x00,
  902. 0x00,0x00,0x00,0x00,0xC0,0x7C,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x7E,0xC7,
  903. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  904. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x07,0x06,0x01,0x01,0xC0,0x60,0x80,
  905. 0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x0F,0x1C,0x38,0x30,0x20,0x60,0x60,0x40,0x40,
  906. 0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x40,0x40,0x00,0x00,0x20,0x20,0x10,0x18,
  907. 0x08,0x0C,0x1E,0x1F,0x3F,0x3F,0xFF,0xFF,0x7F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
  908. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  909. 0x00,0x03,0x0F,0x3C,0xF1,0xC3,0x06,0xE4,0xFC,0x78,0x39,0x11,0x11,0x11,0x31,0x30,
  910. 0x30,0x20,0x20,0x20,0x30,0xF0,0xF0,0x70,0x30,0x70,0xF8,0xF8,0xFC,0xE6,0x06,0x03,
  911. 0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF1,0xFF,0x7F,0xDF,0x87,0xC3,0x7E,
  912. 0x9E,0xE1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFE,0xFC,0xF8,0xF8,
  913. 0xF8,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xE0,0xF0,0xF0,0xF0,0xF0,0x10,0x18,0x18,0x08,
  914. 0x0C,0x0C,0x06,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
  915. 0x03,0x00,0x0C,0x08,0x10,0xB0,0xE0,0xE0,0xE0,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0xE0,
  916. 0x80,0x00,0x00,0xC0,0x40,0xC0,0xE0,0x20,0x30,0x10,0x18,0x0C,0x05,0x06,0x03,0x01,
  917. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xFC,
  918. 0xFE,0xFF,0xFF,0xFF,0xFF,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  919. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  920. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  921. 0x00,0x00,0x00,0x00,0x00,0xFB,0x3F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  922. 0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x0C,0x38,0xE0,0x40,0x01,0x03,0x0F,0x38,0xF0,
  923. 0x40,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x0F,0x1F,0x3F,0x3F,0x7E,0x7E,0x7E,0xFF,
  924. 0xFF,0xE3,0xC9,0x88,0x9A,0xB1,0xC1,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x1F,0x1F,0x3F,
  925. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x07,0x00,0x00,0x00,0x00,
  926. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  927. 0x00,0x00,0xE0,0xFE,0xFF,0xFE,0xFB,0xFC,0xFF,0xFF,0xFF,0xFF,0x3F,0x0F,0x03,0x00,
  928. 0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFC,0xF8,0xF0,0xF0,0xF0,0xE0,0x00,0x00,0x00,
  929. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
  930. 0x07,0xEF,0xFF,0x0F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  931. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,
  932. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,
  933. 0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  934. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x43,0x1E,0x1E,0x1C,0x0C,0x06,0x03,
  935. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  936. 0x00,0x07,0x1F,0x03,0x03,0x03,0x07,0x07,0x07,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
  937. 0x00,0x00,0x01,0x01,0x13,0x1F,0x07,0x07,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
  938. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  939. 0x00,0x00,0x0F,0x1F,0x3F,0xFF,0x7F,0x9F,0x9F,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,
  940. 0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xFF,0x07,0x07,0x07,0x03,0x01,0x00,0x00,0x00,
  941. 0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  942. 0x80,0xBF,0xE1,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0xE4,0xBC,0x88,0x88,0xF8,0xC8,
  943. 0x80,0x80,0x80,0x80,0x80,0xC0,0xC0,0xF8,0xCF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
  944. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x12,0x21,
  945. 0x21,0x1E,0x00,0x1F,0x20,0x20,0x10,0x3F,0x00,0x03,0x8C,0x70,0x0C,0x03,0x00,0x08,
  946. 0x08,0x08,0x00,0x1E,0x21,0x21,0x12,0x3F,0x00,0x3F,0x00,0x12,0x25,0x25,0x29,0x12,
  947. 0x00,0xFF,0x12,0x21,0x21,0x1E,0x00,0x3F,0x00,0x1A,0x25,0x25,0x15,0x3E,0x00,0x03,
  948. 0x8C,0x70,0x0C,0x03,0x00,0x00,0x20,0x00,0x1E,0x21,0x21,0x21,0x12,0x00,0x1E,0x21,
  949. 0x21,0x21,0x1E,0x00,0x3F,0x02,0x01,0x3F,0x01,0x01,0x3E,0x00,0x00,0x00,0x00,0x00,
  950. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  951. 0x00,0x00,0x00,0x00,0x0F,0x19,0x30,0x60,0xC3,0xC6,0xCC,0xD8,0x78,0x30,0x30,0x70,
  952. 0xC0,0x80,0x80,0x80,0xC0,0x40,0x60,0x31,0x0F,0x00,0x00,0x00,0x00,0x80,0x80,0xE0,
  953. };
  954.
  955. unsigned char code BMP2[]={  //ЧЦЅЪμ№Рт
  956. /*--  TVI Electronics, LLC --*/
  957. /*--  192x64  --*/
  958. 0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  959. 0x01,0x01,0x01,0x01,0x01,0x81,0xC1,0xF1,0xF9,0xFD,0xF1,0x01,0x81,0xC1,0x81,0x81,
  960. 0x81,0x81,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  961. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  962. 0x01,0x01,0x01,0x01,0x81,0xF1,0xF9,0xFF,0xFD,0xC1,0x01,0x01,0x01,0x01,0x01,0x01,
  963. 0x01,0x01,0xC1,0xE1,0xF1,0xF9,0xF9,0xFD,0xFD,0xF9,0xF1,0xE1,0xE1,0xB1,0x11,0x19,
  964. 0x1D,0x1D,0x0D,0x09,0x19,0x19,0x19,0x09,0x09,0x39,0xF9,0xD9,0x81,0x01,0x01,0x01,
  965. 0x01,0x81,0x81,0x81,0x81,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  966. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  967. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x81,0x81,
  968. 0x81,0x81,0xC1,0x81,0x01,0xF1,0xFD,0xF9,0xF1,0xC1,0x81,0x01,0x01,0x01,0x01,0x01,
  969. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,
  970. 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  971. 0x00,0x00,0x00,0x00,0x03,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,0xFF,0xFF,0xFF,
  972. 0x03,0x03,0x07,0x07,0x07,0x0F,0x0F,0x0E,0x1E,0x1E,0x1E,0x3C,0x3C,0x3C,0x7C,0x78,
  973. 0x78,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,
  974. 0x60,0x70,0x78,0x7E,0x7B,0x6F,0x4D,0x7B,0x73,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,
  975. 0x00,0x07,0x1F,0x3F,0xFF,0x3F,0x1F,0xFF,0xFF,0xFF,0xFF,0xF7,0xF7,0xF6,0xEC,0xDC,
  976. 0xF8,0x30,0x30,0xF0,0xF8,0xF8,0xF8,0xF8,0xE8,0xEC,0xEF,0xFB,0xFB,0xF3,0x0E,0x3F,
  977. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  978. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0x78,
  979. 0x78,0x7C,0x3C,0x3C,0x3C,0x1E,0x1E,0x1E,0x0E,0x0F,0x0F,0x07,0x07,0x07,0x03,0x03,
  980. 0xFF,0xFF,0xFF,0x01,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x03,0x00,0x00,0x00,0x00,
  981. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
  982. 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x3C,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,
  983. 0xE0,0xE0,0xC0,0xC0,0xC0,0x80,0x81,0x0F,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x7F,0xFF,
  984. 0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  985. 0x00,0x00,0xF8,0xFF,0xFF,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  986. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC3,0x7F,0xF8,0xD0,0x90,0x90,
  987. 0xF0,0x78,0xDE,0xE3,0xF0,0xF8,0xF8,0xFC,0xBC,0xDF,0x5F,0xFF,0xFF,0x7B,0x01,0x01,
  988. 0x00,0x00,0xC0,0xF0,0xF1,0x7B,0x7B,0xFB,0xF7,0xF7,0xE3,0xE3,0xC3,0x01,0x00,0x00,
  989. 0x00,0xFF,0xF9,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  990. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xF8,0x00,0x00,
  991. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,
  992. 0xFF,0x7F,0x00,0x80,0xFF,0xFF,0xFF,0xFF,0x0F,0x81,0x80,0xC0,0xC0,0xC0,0xE0,0xE0,
  993. 0xF0,0xF0,0xF0,0xF8,0xF8,0xF8,0x3C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
  994. 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1F,0x7F,0xF8,0xC1,
  995. 0x01,0x01,0x03,0x03,0x03,0x07,0x07,0x07,0x00,0x07,0x3F,0xFF,0xFF,0x00,0x00,0x3F,
  996. 0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  997. 0xC0,0xFF,0xFF,0x1F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  998. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1C,0x38,0x30,0x23,0x77,0xFF,
  999. 0xFF,0xC0,0x87,0x0F,0x1F,0x1F,0x1F,0x1F,0x1D,0x0C,0x1E,0x39,0x19,0x00,0x00,0x00,
  1000. 0x00,0x00,0x03,0x19,0x19,0x3B,0x38,0x7F,0x7F,0x7F,0x3F,0x3F,0x1F,0x02,0x00,0x80,
  1001. 0xC0,0xFF,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1002. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x1F,0xFF,0xFF,0xC0,
  1003. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xFF,
  1004. 0x3F,0x00,0x00,0xFF,0xFF,0x3F,0x07,0x00,0x07,0x07,0x07,0x03,0x03,0x03,0x01,0x01,
  1005. 0xC1,0xF8,0x7F,0x1F,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
  1006. 0xFF,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x01,0x07,
  1007. 0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x1F,0x3F,0x80,0x00,
  1008. 0x0F,0x0F,0x8E,0x8E,0x8E,0x8E,0x8E,0x8E,0x0E,0x0E,0x0E,0x0E,0x8E,0x8E,0x0E,0x0E,
  1009. 0x0F,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
  1010. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1011. 0x07,0x1E,0x79,0xE3,0x86,0x0C,0xC8,0xF8,0xF1,0x73,0x23,0x23,0x23,0x63,0x61,0x60,
  1012. 0x40,0x40,0x40,0x60,0xE0,0xE0,0xE0,0x60,0xE0,0xF0,0xF0,0xF8,0xCC,0x0C,0x06,0x03,
  1013. 0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1014. 0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x01,0x0F,0x0F,
  1015. 0x0E,0x0E,0x8E,0x8E,0x0E,0x0E,0x0E,0x0E,0x8E,0x8E,0x8E,0x8E,0x8E,0x8E,0x0F,0x0F,
  1016. 0x00,0x80,0x3F,0x1F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,
  1017. 0x07,0x01,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0xFF,
  1018. 0xFF,0x00,0x00,0x00,0x00,0xFF,0xFF,0x88,0x88,0x88,0x88,0x00,0x00,0x64,0xF2,0x9A,
  1019. 0x8A,0xFE,0xFC,0x00,0x00,0x4C,0xDE,0x9A,0xB2,0xF6,0x64,0x00,0x02,0x7F,0xFF,0x82,
  1020. 0x00,0x00,0xFF,0xFF,0x08,0x08,0x18,0x7F,0xE7,0x80,0x00,0x00,0xFE,0xFE,0x00,0x00,
  1021. 0x4C,0xDE,0x9A,0xB2,0xF6,0x64,0x00,0x00,0xFE,0xFE,0x00,0x00,0xFE,0xFE,0x04,0x02,
  1022. 0xFE,0xFC,0x00,0x00,0x7C,0xFE,0x82,0x44,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,
  1023. 0x00,0x00,0x00,0x00,0xFB,0x3F,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1024. 0x00,0x00,0x00,0x00,0x07,0x07,0x0C,0x38,0xE0,0x40,0x01,0x03,0x0F,0x38,0xF0,0x40,
  1025. 0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFE,0x44,0x82,0xFE,0x7C,0x00,0x00,0xFC,0xFE,
  1026. 0x02,0x04,0xFE,0xFE,0x00,0x00,0xFE,0xFE,0x00,0x00,0x64,0xF6,0xB2,0x9A,0xDE,0x4C,
  1027. 0x00,0x00,0xFE,0xFE,0x00,0x00,0x80,0xE7,0x7F,0x18,0x08,0x08,0xFF,0xFF,0x00,0x00,
  1028. 0x82,0xFF,0x7F,0x02,0x00,0x64,0xF6,0xB2,0x9A,0xDE,0x4C,0x00,0x00,0xFC,0xFE,0x8A,
  1029. 0x9A,0xF2,0x64,0x00,0x00,0x88,0x88,0x88,0x88,0xFF,0xFF,0x00,0x00,0x00,0x00,0xFF,
  1030. 0xFF,0x00,0xEC,0x8C,0x8C,0x8C,0x0C,0x0C,0x8C,0x0C,0x0C,0x0C,0x8C,0x0C,0x8C,0x0C,
  1031. 0x0C,0x0C,0x8C,0x0C,0x0C,0x0C,0x0C,0x8C,0x8C,0x8C,0xEC,0x0C,0xAC,0x0C,0x0C,0x0C,
  1032. 0x8C,0x8C,0x8C,0x0C,0x8C,0x8C,0x8C,0x8C,0x0C,0x0C,0xEC,0x0C,0x0C,0x8C,0x8C,0x8C,
  1033. 0x0C,0x0C,0x8C,0x0C,0x0C,0x0C,0x8C,0x0C,0x0C,0x0C,0x0C,0x8C,0x8C,0x0C,0x0C,0x0C,
  1034. 0x8C,0x8C,0x8C,0x0C,0x0D,0x8E,0x8E,0x8E,0x0F,0x8D,0x8C,0x0C,0x00,0x00,0x00,0x00,
  1035. 0x00,0x00,0x00,0x00,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1036. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC3,0xFE,0x3E,0x1C,0x0C,0x06,0x03,0x00,
  1037. 0x00,0x00,0x00,0x00,0x0C,0x8C,0x8D,0x0F,0x8E,0x8E,0x8E,0x0D,0x0C,0x8C,0x8C,0x8C,
  1038. 0x0C,0x0C,0x0C,0x8C,0x8C,0x0C,0x0C,0x0C,0x0C,0x8C,0x0C,0x0C,0x0C,0x8C,0x0C,0x0C,
  1039. 0x8C,0x8C,0x8C,0x0C,0x0C,0xEC,0x0C,0x0C,0x8C,0x8C,0x8C,0x8C,0x0C,0x8C,0x8C,0x8C,
  1040. 0x0C,0x0C,0x0C,0xAC,0x0C,0xEC,0x8C,0x8C,0x8C,0x0C,0x0C,0x0C,0x0C,0x8C,0x0C,0x0C,
  1041. 0x0C,0x8C,0x0C,0x8C,0x0C,0x0C,0x0C,0x8C,0x0C,0x0C,0x8C,0x8C,0x8C,0xEC,0x00,0xFF,
  1042. 0xFF,0x80,0x8F,0x88,0x88,0x88,0x87,0x80,0x87,0x88,0x88,0x88,0x8F,0x80,0xA0,0xA7,
  1043. 0x98,0x87,0x80,0x82,0x82,0x80,0x87,0x88,0x88,0x88,0x8F,0x80,0x8F,0x80,0x80,0x89,
  1044. 0x8A,0x8A,0x84,0x80,0xBF,0x88,0x88,0x88,0x87,0x80,0x8F,0x80,0x80,0x84,0x8A,0x8A,
  1045. 0x8F,0x80,0xA0,0xA7,0x98,0x87,0x80,0x80,0x88,0x80,0x87,0x88,0x88,0x85,0x80,0x87,
  1046. 0x88,0x88,0x88,0x87,0x80,0x8F,0x80,0x80,0x8F,0x80,0x80,0x8F,0x80,0x80,0x80,0x80,
  1047. 0x80,0x80,0x80,0x80,0x81,0x9F,0xB8,0xE0,0xC0,0xC0,0xC2,0xC2,0xC6,0xE6,0xFE,0xC6,
  1048. 0xC0,0xC0,0x80,0x80,0xC0,0xC0,0xE0,0xFC,0x9F,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
  1049. 0x80,0x80,0x80,0x80,0x8F,0x80,0x80,0x8F,0x80,0x80,0x8F,0x80,0x87,0x88,0x88,0x88,
  1050. 0x87,0x80,0x85,0x88,0x88,0x87,0x80,0x88,0x80,0x80,0x87,0x98,0xA7,0xA0,0x80,0x8F,
  1051. 0x8A,0x8A,0x84,0x80,0x80,0x8F,0x80,0x87,0x88,0x88,0x88,0xBF,0x80,0x84,0x8A,0x8A,
  1052. 0x89,0x80,0x80,0x8F,0x80,0x8F,0x88,0x88,0x88,0x87,0x80,0x82,0x82,0x80,0x87,0x98,
  1053. 0xA7,0xA0,0x80,0x8F,0x88,0x88,0x88,0x87,0x80,0x87,0x88,0x88,0x88,0x8F,0x80,0xFF,
  1054. };
S6B0108.pdf
108.51 KB, 下载次数: 43
S6B0107.pdf
141.44 KB, 下载次数: 27
TGL33B-19264_Series.pdf
308.5 KB, 下载次数: 45
TGL33B-19264_Series_DataSheet.pdf
1020.62 KB, 下载次数: 39
作者: fang880413    时间: 2019-1-5 20:03
angmall 发表于 2019-1-4 21:16
看看别人的程序吧。
我照着你的程序和资料里的接线图,屏幕没显示,只有对比度可以调。会不会因为我一开始照着错误的接线图试过导致主控烧了
作者: wulin    时间: 2019-1-6 16:33
fang880413 发表于 2019-1-5 20:03
我照着你的程序和资料里的接线图,屏幕没显示,只有对比度可以调。会不会因为我一开始照着错误的接线图试 ...
这类器件只要电源电压不超过5V,接错线一般不会损坏,甚至电源短时间接反也不一定损坏。
作者: fang880413    时间: 2019-1-6 17:55
接错的时候电流达到500毫安的,有点发热但是不严重,现在我试了好几个例程都点不亮,通电就是整个屏幕显示白色
作者: wc86110    时间: 2019-1-6 20:04
早期液晶屏大都是点阵的,那屏幕显示白色只是背光灯颜色而已。最好是能找到这货的使用手册,再不济就只能顺藤摸瓜画出与接口关联电路来分析引脚定义了
作者: fang880413    时间: 2019-1-6 20:30
wc86110 发表于 2019-1-6 20:04
早期液晶屏大都是点阵的,那屏幕显示白色只是背光灯颜色而已。最好是能找到这货的使用手册,再不济就只能顺 ...
不是背光灯,白色和透明我还是区分得清的
作者: zgs660429    时间: 2019-12-4 23:36
我也说一句КЗ  --*/ /*--  ЛОМе12;  ЛЧЦМеПВФУ|
作者: man1234567    时间: 2019-12-5 09:04
网上很好找到这个的,一般情况下任意接错5V及以下电压不是人品太差不会烧。
作者: 啤酒瓶子老大    时间: 2021-3-27 19:55
留个记号。感谢分享。有空研究一下。
作者: a4681748    时间: 2024-3-24 10:26
看看别人的程序吧。
这个程序中片选只有2个呢,19264应该有3个的。。。
作者: fsj5098    时间: 2024-3-24 19:32
和金鹏液晶19264管脚一致
