卡尔曼滤波算法程序,输入随机数,Q和R自己选
suisex
2019-1-7 17:00
卡尔曼滤波算法,自己,输入为随机数,Q和R要自己选
主函数:
#include "kalman.h"
#include "stdio.h"
#include "stdlib.h"
void main(void)
KalmanCountData k;
//定义一个卡尔曼运算结构体
Kalman_Filter_Init(&k);
//讲运算变量初始化
int n;
int a;
srand((unsigned)time(NULL)); // 初始化随机种子,使rand()产生的随机数每次不一样
for(a = 0;a<1000;a++)
//测试1000次
//m,n为1到100的随机数
n = 1+ rand() %100;
//卡尔曼滤波,传递2个测量值以及运算结构体
Kalman_Filter(&k,n);
//打印结果
printf("第%d次迭代\n 输入:%d, 输出滤波值为:%f\r\n",a+1,n,k.Filter_Value);
kalman.h:
typedef struct //定义结构体
float Filter_Value; //K-1时刻的系滤波值
float A; //系统参数,一维模型中通常选为1
float H; //系统测量参数,一维模型选择为1
float Kg; //卡尔曼增益
float Q; //过程噪声偏差
float R; //测量噪声偏差
float P; //估计误差协方差
} KalmanCountData;
void Kalman_Filter_Init(KalmanCountData * Kalman_Struct) //卡尔曼滤波器初始化
Kalman_Struct->A = 1;
Kalman_Struct->H = 1;
Kalman_Struct->P = 3; //后验状态估计值方差的初始值
Kalman_Struct->Q = 0.1; //过程噪声偏差,实验测的 ,要填的!
Kalman_Struct->R = 10; //测量噪声偏差,要填的!
Kalman_Struct->Filter_Value = 0; //初始化设置k-1时刻的系统滤波后的值为0
double Kalman_Filter(KalmanCountData* Kalman_Struct, double Last_Measurement){
double PredictValue = Kalman_Struct->Filter_Value*Kalman_Struct->A; //先验估计的预测值
Kalman_Struct->P = Kalman_Struct->A*Kalman_Struct->P*Kalman_Struct->A+Kalman_Struct->Q; //求协方差
double prevalve = Kalman_Struct->Filter_Value; //记录上一次(k-1)的值
Kalman_Struct->Kg = Kalman_Struct->P*Kalman_Struct->H/(Kalman_Struct->H*Kalman_Struct->P*Kalman_Struct->H + Kalman_Struct->R);
卡尔曼增益Kg = P(k|k-1) H’ / (H P(k|k-1) H’ + R)
Kalman_Struct->Filter_Value = PredictValue + (Last_Measurement-PredictValue) * Kalman_Struct->Kg;
修正结果,更新预测值;X(k|k) = X(k|k-1) + (Z(k) - H* X(k|k-1)) * Kg
Kalman_Struct->P = (1 - Kalman_Struct->Kg * Kalman_Struct->H) * Kalman_Struct->P;
//更新后验估计的协方差,P(k|k) = (1 - Kg * H) * P(k|k-1)
return Kalman_Struct->Filter_Value;
Kalman.zip
2019-1-7 17:00 上传
点击文件名下载附件
下载积分: 黑币 -5
89.46 KB, 下载次数: 38, 下载积分: 黑币 -5
yangzai
2019-11-12 11:10
您好,这个程序中您说的过程测量噪声是实验测的,能给点测量方法吗,最近在做卡尔曼滤波算法对系统误差测量一筹莫展。
yangzai
2019-11-12 11:15
您好,我想请问一下系统测量误差实验测得的可以分享一下实验测量的步骤吗?
