STM32 VESC DC _ BLDC _ FOC本杰明控制器C源码
107535230
2019-1-26 00:08
VESC DC _ BLDC _ FOC本杰明控制器C源码,分享大家
Copyright 2016 Benjamin Vedder benjamin@vedder.se
This file is part of the VESC firmware.
The VESC firmware is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
The VESC firmware is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "ch.h"
#include "hal.h"
#include "stm32f4xx_conf.h"
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <stdlib.h>
#include "mc_interface.h"
#include "mcpwm.h"
#include "mcpwm_foc.h"
#include "ledpwm.h"
#include "comm_usb.h"
#include "ledpwm.h"
#include "terminal.h"
#include "hw.h"
#include "app.h"
#include "packet.h"
#include "commands.h"
#include "timeout.h"
#include "comm_can.h"
#include "ws2811.h"
#include "led_external.h"
#include "encoder.h"
#include "servo.h"
#include "servo_simple.h"
#include "utils.h"
#include "nrf_driver.h"
#include "rfhelp.h"
#include "spi_sw.h"
* Timers used:
* TIM7: servo
* TIM1: mcpwm
* TIM2: mcpwm
* TIM12: mcpwm
* TIM8: mcpwm
* TIM3: servo_dec/Encoder (HW_R2)/servo_simple
* TIM4: WS2811/WS2812 LEDs/Encoder (other HW)
* DMA/stream Device Function
* 1, 2 I2C1 Nunchuk, temp on rev 4.5
* 1, 7 I2C1 Nunchuk, temp on rev 4.5
* 1, 1 UART3 HW_R2
* 1, 3 UART3 HW_R2
* 2, 2 UART6 Other HW
* 2, 7 UART6 Other HW
* 2, 4 ADC mcpwm
* 1, 0 TIM4 WS2811/WS2812 LEDs CH1 (Ch 1)
* 1, 3 TIM4 WS2811/WS2812 LEDs CH2 (Ch 2)
// Private variables
static THD_WORKING_AREA(periodic_thread_wa, 1024);
static THD_WORKING_AREA(timer_thread_wa, 128);
static THD_FUNCTION(periodic_thread, arg) {
(void)arg;
chRegSetThreadName("Main periodic");
for(;;) {
if (mc_interface_get_state() == MC_STATE_RUNNING) {
ledpwm_set_intensity(LED_GREEN, 1.0);
} else {
ledpwm_set_intensity(LED_GREEN, 0.2);
mc_fault_code fault = mc_interface_get_fault();
if (fault != FAULT_CODE_NONE) {
for (int i = 0;i < (int)fault;i++) {
ledpwm_set_intensity(LED_RED, 1.0);
chThdSleepMilliseconds(250);
ledpwm_set_intensity(LED_RED, 0.0);
chThdSleepMilliseconds(500);
} else {
if (mc_interface_get_state() == MC_STATE_DETECTING) {
commands_send_rotor_pos(mcpwm_get_detect_pos());
disp_pos_mode display_mode = commands_get_disp_pos_mode();
switch (display_mode) {
case DISP_POS_MODE_ENCODER:
commands_send_rotor_pos(encoder_read_deg());
break;
case DISP_POS_MODE_PID_POS:
commands_send_rotor_pos(mc_interface_get_pid_pos_now());
break;
case DISP_POS_MODE_PID_POS_ERROR:
commands_send_rotor_pos(utils_angle_difference(mc_interface_get_pid_pos_set(), mc_interface_get_pid_pos_now()));
break;
default:
break;
if (mc_interface_get_configuration()->motor_type == MOTOR_TYPE_FOC) {
case DISP_POS_MODE_OBSERVER:
commands_send_rotor_pos(mcpwm_foc_get_phase_observer());
break;
case DISP_POS_MODE_ENCODER_OBSERVER_ERROR:
commands_send_rotor_pos(utils_angle_difference(mcpwm_foc_get_phase_observer(), mcpwm_foc_get_phase_encoder()));
break;
default:
break;
chThdSleepMilliseconds(10);
// chThdSleepMilliseconds(40);
// volatile const mc_configuration *conf = mc_interface_get_configuration();
// float vq = mcpwm_foc_get_vq();
// float iq = mc_interface_get_tot_current_directional();
// float linkage = conf->foc_motor_flux_linkage;
// float speed = ((2.0 * M_PI) / 60.0) * mc_interface_get_rpm();
// if (iq < -6.0) {
// float res = vq / (linkage * speed * iq);
// res *= 2.0 / 3.0;
// static float res_filtered = 0.0;
// UTILS_LP_FAST(res_filtered, res, 0.02);
// commands_printf("Res: %.4f", (double)res_filtered);
// commands_printf("Max: %.2f Min: %.2f",
// (double)mc_interface_get_configuration()->lo_current_motor_max_now,
// (double)mc_interface_get_configuration()->lo_current_motor_min_now);
static THD_FUNCTION(timer_thread, arg) {
(void)arg;
chRegSetThreadName("msec_timer");
for(;;) {
packet_timerfunc();
chThdSleepMilliseconds(1);
int main(void) {
halInit();
chSysInit();
// Initialize the enable pins here and disable them
// to avoid excessive current draw at boot because of
// floating pins.
#ifdef HW_HAS_DRV8313
INIT_BR();
#endif
chThdSleepMilliseconds(1000);
hw_init_gpio();
LED_RED_OFF();
LED_GREEN_OFF();
conf_general_init();
ledpwm_init();
mc_configuration mcconf;
conf_general_read_mc_configuration(&mcconf);
mc_interface_init(&mcconf);
commands_init();
comm_usb_init();
app_configuration appconf;
conf_general_read_app_configuration(&appconf);
app_set_configuration(&appconf);
#ifdef HW_HAS_PERMANENT_NRF
conf_general_permanent_nrf_found = nrf_driver_init();
if (conf_general_permanent_nrf_found) {
rfhelp_restart();
} else {
nrf_driver_stop();
// Set the nrf SPI pins to the general SPI interface so that
// an external NRF can be used with the NRF app.
spi_sw_change_pins(
HW_SPI_PORT_NSS, HW_SPI_PIN_NSS,
HW_SPI_PORT_SCK, HW_SPI_PIN_SCK,
HW_SPI_PORT_MOSI, HW_SPI_PIN_MOSI,
HW_SPI_PORT_MISO, HW_SPI_PIN_MISO);
#endif
timeout_init();
timeout_configure(appconf.timeout_msec, appconf.timeout_brake_current);
#if CAN_ENABLE
comm_can_init();
#endif
#if WS2811_ENABLE
ws2811_init();
#if !WS2811_TEST
led_external_init();
#endif
#endif
#if SERVO_OUT_ENABLE
#if SERVO_OUT_SIMPLE
servo_simple_init();
#else
servo_init();
#endif
#endif
// Threads
chThdCreateStatic(periodic_thread_wa, sizeof(periodic_thread_wa), NORMALPRIO, periodic_thread, NULL);
chThdCreateStatic(timer_thread_wa, sizeof(timer_thread_wa), NORMALPRIO, timer_thread, NULL);
#if WS2811_TEST
unsigned int color_ind = 0;
const int num = 4;
const uint32_t colors[] = {COLOR_RED, COLOR_GOLD, COLOR_GRAY, COLOR_MAGENTA, COLOR_BLUE};
const int brightness_set = 100;
for (;;) {
for (int i = 0;i < brightness_set;i++) {
ws2811_set_brightness(i);
for(int i = -num;i <= WS2811_LED_NUM;i++) {
ws2811_set_led_color(i - 1, COLOR_BLACK);
ws2811_set_led_color(i + num, colors[color_ind]);
ws2811_set_led_color(0, COLOR_RED);
ws2811_set_led_color(WS2811_LED_NUM - 1, COLOR_GREEN);
chThdSleepMilliseconds(50);
ws2811_set_brightness(brightness_set - i);
color_ind++;
if (color_ind >= sizeof(colors) / sizeof(uint32_t)) {
color_ind = 0;
static int asd = 0;
asd++;
if (asd >= 3) {
asd = 0;
for (unsigned int i = 0;i < sizeof(colors) / sizeof(uint32_t);i++) {
ws2811_set_all(colors[i]);
chThdSleepMilliseconds(2);
chThdSleepMilliseconds(100);
#endif
for(;;) {
if (encoder_is_configured()) {
// comm_can_set_pos(0, encoder_read_deg());
bldc-master.7z
(760.42 KB, 下载次数: 122)
2019-1-26 00:39 上传
点击文件名下载附件
VESC DC _ BLDC _ FOC控制器
下载积分: 黑币 -5
admin
2019-1-26 00:41
mcu_mpu
2019-9-18 14:39
好东西,学习了。
