MLX90614的MSP430G2553驱动程序
程序员35
2019-1-30 14:21
//MLX90614 Pin Config
//GND-----1.5.....I/O supply the MLX90614
//SCL-----2.0
//SCL-----2.1
//POW-----2.2.....I/O supply the MLX90614
#include <msp430g2553.h> // System define for the micro that I am using
unsigned int A4,A5,A6,A7,A8;
unsigned char dis_code[10] = {48,49,50,51,52, //段码表
//0 1 2 3 4 对应内容
53,54,55,56,57};
//5 6 7 8 9
void Delay(unsigned int n);
void start_bit();
void stop_bit();
void send_bit(unsigned char bit_out);
unsigned char receive_bit();
unsigned char slave_ack();
void TX_byte(unsigned char TX_buffer);
unsigned char RX_byte(unsigned char ack_nack);
unsigned char PEC_cal(unsigned char pec[],int n);
unsigned long int MEM_READ( unsigned char slave_addR, unsigned char cmdR );
void CALTEMP(unsigned long int TEMP);
void mlx90614_POW_0() { P1OUT &= ~0x20;} // define P1.5 ---> POW
void mlx90614_POW_1() { P1OUT |= 0x20;}
void mlx90614_GND_0() { P2OUT &= ~0x04;} // define P2.2 ---> GND
void mlx90614_GND_1() { P2OUT |= 0x04;}
void mlx90614_SCL_0() { P2OUT &= ~0x01;} // define P2.0 ---> SCL
void mlx90614_SCL_1() { P2OUT |= 0x01;}
void mlx90614_SDA_0() { P2OUT &= ~0x02;} // define P2.1 ---> SDA
void mlx90614_SDA_1() { P2OUT |= 0x02;}
#define _SDA_OUTPUT P2DIR |=0x02; //Set SDA as Output
#define _SDA_INPUT P2DIR &=~0x02; //Set SDA as Input
#define SDA ((P2IN & BIT1)>>1) //define input pin
#define RXD BIT1
#define TXD BIT2
void SendByte(unsigned char Data);
void UartTXdata(void);
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop Watch dog timer
BCSCTL1 = CALBC1_16MHZ; // Set DCO to 16 MHz
DCOCTL = CALDCO_16MHZ;
P1DIR = 0xFF; // All P1.x outputs
P1OUT = 0; // All P1.x reset
P2DIR = 0xFF; // All P2.x outputs
P2OUT = 0; // All P2.x reset
P1SEL = RXD + TXD ; // Select TX and RX functionality for P1.1 & P1.2
P1SEL2 = RXD + TXD ; //
UCA0CTL1 |= UCSSEL_2; // Have USCI use System Master Clock: AKA core clk 1MHz
UCA0BR0 = 131; // 16MHz 9600, see user manual
UCA0BR1 = 6; //
UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // Start USCI state machine
mlx90614_GND_0(); //powr supply
mlx90614_POW_1();
while(1) // While 1 is equal to 1 (forever)
unsigned long int DATA;
DATA=MEM_READ(0x5a,0x07);
CALTEMP(DATA);
//Delay(1); //delay 340nS
//Delay(10); //delay 4uS
//Delay(60); //delay 20uS
//Delay(100); //delay 34uS
//SendByte(0x55);
SendByte('T');
SendByte(':');
SendByte(32);
SendByte(dis_code[A4]);
SendByte(dis_code[A5]);
SendByte(dis_code[A6]);
SendByte('.');
SendByte(dis_code[A7]);
SendByte(dis_code[A8]);
SendByte('\n');
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
Delay(32000);
while ((UCA0STAT & UCBUSY));
UCA0TXBUF = Data;
// USER CODE BEGIN (MAIN_General,10)
unsigned int i;
for(i=0;i<n;i++)
_NOP();
//Name: start_bit
void start_bit()
_SDA_OUTPUT; //Set SDA as output
Delay(5);
mlx90614_SDA_1();
//Delay(30);
mlx90614_SCL_1();
Delay(30);
mlx90614_SDA_0();
Delay(30);
mlx90614_SCL_0();
Delay(30);
//Name: stop_bit
void stop_bit()
Delay(5);
//mlx90614_SCL_0();
mlx90614_SDA_0();
Delay(30);
mlx90614_SCL_1();
Delay(30);
mlx90614_SDA_1();
//Name: send_bit
Delay(5);
if(bit_out==0) {mlx90614_SDA_0();}else{mlx90614_SDA_1();}
Delay(5);
mlx90614_SCL_1();
Delay(30);
mlx90614_SCL_0();
Delay(30);
//Name: receive_bit
unsigned char bit_in;
_SDA_INPUT; //Set SDA as input
Delay(5);
mlx90614_SCL_1();
Delay(5);
if(SDA==1){bit_in=1;}else{bit_in=0;}
Delay(10);
mlx90614_SCL_0();
Delay(30);
return bit_in;
//Name: slave_ack
//1 - ACK
//0 -NACK
unsigned char ack;
ack=0;
Delay(5);
mlx90614_SCL_1();
Delay(10);
if(SDA==1){ack=0;}else{ack=1;}
Delay(10);
mlx90614_SCL_0();
Delay(30);
return ack;
//Name: TX_byte
unsigned char Bit_counter;
unsigned char bit_out;
for(Bit_counter=8;Bit_counter;Bit_counter--)
if(TX_buffer&0x80){bit_out=1;}else{bit_out=0;}
send_bit(bit_out); //Send the current bit on SMBus
TX_buffer<<=1; //Get next bit to check
//Name: RX_byte
//Parameters: unsigned char ack_nack (acknowledgment bit)
//0 - Master device sends ACK
//1 - Master device sends NACK
unsigned char RX_buffer;
if(receive_bit()==1) //Read a bit from the SDA line
RX_buffer<<=1; //If the bit is HIGH save 1 in RX_buffer
RX_buffer|=0x01;
else //If the bit is LOW save 0 in RX_buffer
RX_buffer<<=1;
RX_buffer&=0xfe;
send_bit(ack_nack); //Sends acknowledgment bit
return RX_buffer;
//CALCULATE THE PEC PACKET
unsigned char crc[6];
unsigned char Bitposition=47;
unsigned char shift;
unsigned char i;
unsigned char j;
unsigned char temp;
do{
crc[5]=0; //Load CRC value 0x000000000107
crc[4]=0;
crc[3]=0;
crc[2]=0;
crc[1]=0x01;
crc[0]=0x07;
Bitposition=47; //Set maximum bit position at 47
shift=0; //Find first 1 in the transmitted bytes
i=5; //Set highest index (package byte index)
j=0; //Byte bit index, from lowest
while((pec[i]&(0x80>>j))==0 && (i>0))
Bitposition--;
if(j<7){ j++;}
else {j=0x00;i--;}
}//the position of highest "1" bit in Bitposition is calculated
shift=Bitposition-8; //Get shift value for CRC value
while(shift)
for(i=5;i<0xFF;i--)
if((crc[i-1]&0x80) && (i>0)) //Check if the MSB of the byte lower is "1"
{ //Yes - current byte + 1
temp=1; //No - current byte + 0
} //So that "1" can shift between bytes
else { temp=0;}
crc[i]<<=1;
crc[i]+=temp;
shift--;
//Exclusive OR between pec and crc
for(i=0;i<=5;i++) { pec[i]^=crc[i]; }
while(Bitposition>8);
return pec[0];
//READ DATA FROM RAM/EEPROM
unsigned long int MEM_READ(unsigned char slave_addR, unsigned char cmdR)
unsigned char DataL; //
unsigned char DataH; //Data packets from MLX90614
unsigned char PEC; //
unsigned long int Data; //Register value returned from MLX90614
unsigned char Pecreg; //Calculated PEC byte storage
unsigned char arr[6]; //Buffer for the sent bytes
unsigned char ack_nack;
unsigned char SLA;
SLA=(slave_addR<<1);
begin:
start_bit(); //Send start bit
TX_byte(SLA); //Send slave address, write
if(slave_ack()==0){stop_bit();goto begin;} //Send command
TX_byte(cmdR);
if(slave_ack()==0){stop_bit();goto begin;}//Send Repeated start bit
start_bit(); //Send slave address, read
TX_byte(SLA+1);
DataL=RX_byte(0); //
//Read two bytes data
DataH=RX_byte(0); //
PEC=RX_byte(ack_nack); //Read PEC from MLX90614
if(ack_nack==1) //Master sends ack or nack
//This depends on the pec calculation,
//if the PEC is not correct, send nack and goto begin
{stop_bit();goto begin;} //Send stop bit
stop_bit();
arr[5]=(SLA);
arr[4]=cmdR;
arr[3]=(SLA+1);
arr[2]=DataL;
arr[1]=DataH;
arr[0]=0;
Pecreg=PEC_cal(arr,6); //Calculate CRC
if(PEC==Pecreg){ ack_nack=0;}
else{ ack_nack=1;}
Data=(DataH*256)+DataL;
return Data;
//Name: CALTEMP
//Temperature data is T=(Data)*0.02-273.15
unsigned long int T;
unsigned int a,b;
T=TEMP*2;
if(T>=27315)
T=T-27315;
a=T/100;
b=T-a*100;
if(a>=100){A4=a/100;a=a%100;A5=a/10;a=a%10;A6=a;}
else if(a>=10){A4=0;A5=a/10;a=a%10;A6=a;}
else {A4=0;A5=0;A6=a;}
if(b>=10){A7=b/10;b=b%10;A8=b;}
else{A7=0;A8=b;}
T=27315-T;
a=T/100;
b=T-a*100;
A4=9;
if(a>=10){A5=a/10;a=a%10;A6=a;}
else{A5=0;A6=a;}
if(b>=10){ A7=b/10;b=b%10;A8=b;}
else{A7=0;A8=b;}
程序员35
2019-1-30 14:22
第一次玩这个,请大神多多指教
admin
2019-1-30 16:09
