求助! hanjia.c(75): error C141: syntax error near 'void', expected '__asm'
277563114
2019-2-9 21:32
#include "reg51.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/* define constants */
#define FOSC 11059200L
#define T1MS (65536-FOSC/12/1000) //1ms timer calculation method in 12T mode
/* define SFR */
sbit TEST_LED = P1^0; //work LED, flash once per second
sbit pwm1 = P1^1;
sbit pwm2 = P1^2;
sbit pwm3 = P1^3;
sbit pwm4 = P1^4;
sbit k1=P1^5;
sbit k2=P1^6;
sbit k3=P1^7;
sbit k4=P2^0;
/* define variables */
WORD count; //1000 times counter
WORD a,b,c;
WORD time;
WORD p1,p2,p3,p4;
/* Timer0 interrupt routine */
void tm0_isr() interrupt 1 using 1
TL0 = T1MS; //reload timer0 low byte
TH0 = T1MS >> 8; //reload timer0 high byte
if (count++ == 100) //1ms * 1000 -> 1s
count = 0; //reset counter
TEST_LED = ! TEST_LED; //work LED flash
if (count<=p1)
pwm1=0;
else{pwm1=1;}
if (count<=p2)
pwm2=0;
else{pwm2=1;}
if (count<=p3)
pwm3=0;
else{pwm3=1;}
if (count<=p4)
pwm4=0;
else{pwm4=1;}
/* main program */
while (1){
if (k1==0)
for(a=0;a++;a<10000)
if(a<5000)
if(k1==1)
for(b=0;b++;b<10000)
if(k1==0)
p1=80;
p2=60;
p3=90;
p4=80;
TMOD = 0x01; //set timer0 as mode1 (16-bit)
TL0 = T1MS; //initial timer0 low byte
TH0 = T1MS >> 8; //initial timer0 high byte
TR0 = 1; //timer0 start running
ET0 = 1; //enable timer0 interrupt
EA = 1; //open global interrupt switch
count = 0; //initial counter
b=10000;
a=10000;
a=10000;
b=10000;
if(a>4999)
if(k3==0&&k1==0)
p1=100;
p2=60;
p3=90;
p4=80;
if(k1==0)
p1=100;
p2=80;
p3=80;
p4=100;
if (k3==0)
p1=100;
p2=0;
p3=0;
p4=100;
p1=100;
p2=0;
p3=0;
p4=0;TMOD = 0x01; //set timer0 as mode1 (16-bit)
if (k2==0)
p1=50;
p2=100;
p3=0;
p4=0;
if (k3==0)
p1=0;
p1=40;
p1=100;
p1=0;
if (k4==0)
p1=0;
p2=30;
p3=0;
p4=100;
} //loop
wulin
2019-2-9 21:33
要养成规范书写的习惯。void tm0_isr() interrupt 1 using 1函数最后一行少了一个花括号,void main()函数最后一行多了一个花括号。
angmall
2019-2-10 07:31
给你改了,对比一下就知道哪里错了。
#include "reg51.h"
/* define SFR */
sbit pwm1 = P1^1;
sbit pwm2 = P1^2;
sbit pwm3 = P1^3;
sbit pwm4 = P1^4;
sbit k1=P1^5;
sbit k2=P1^6;
sbit k3=P1^7;
sbit k4=P2^0;
WORD a,b,c;
WORD time;
WORD p1,p2,p3,p4;
if (count<=p1)
pwm1=0;
else{pwm1=1;}
if (count<=p2)
pwm2=0;
else{pwm2=1;}
if (count<=p3)
pwm3=0;
else{pwm3=1;}
if (count<=p4)
pwm4=0;
else{pwm4=1;}
} //<----------------- 这里错了 少这个
/* main program */
while (1){
if (k1==0)
if(a<5000)
if(k1==1)
if(k1==0)
p1=80;
p2=60;
p3=90;
p4=80;
TMOD |= 0x01; //set timer0 as mode1 (16-bit)
b=10000;
a=10000;
a=10000;
b=10000;
if(a>4999)
if(k3==0&&k1==0)
p1=100;
p2=60;
p3=90;
p4=80;
if(k1==0)
p1=100;
p2=80;
p3=80;
p4=100;
if (k3==0)
p1=100;
p2=0;
p3=0;
p4=100;
p1=100;
p2=0;
p3=0;
p4=0;TMOD |= 0x01; //set timer0 as mode1 (16-bit)
if (k2==0)
p1=50;
p2=100;
p3=0;
p4=0;
if (k3==0)
p1=0;
p1=40;
p1=100;
p1=0;
if (k4==0)
p1=0;
p2=30;
p3=0;
p4=100;
} //loop
} //loop <------- //main 这里错了
//} <--------------- 这里错了
HC6800-ES-V2.0
2019-2-10 09:10
非常简单的错误:main()之前的函数少了一个},main()最后多了一个}而已。
看你的程序,好乱,出这样的错,很正常!!!!!
xuyaqi
2019-2-10 09:46
大括弧问题,把最下边 } 移到 main 上面就可以啦。
suuy79
2019-2-10 10:05
中断程序少了一个“}”,在void main前面+“}”即可解决
sxinyuanxu
2022-2-12 22:51
void main前面+“}”即可解决,我也遇到相同的问题 解决了
