标题: l298n驱动电机c程序及接线图 [打印本页]
作者: a@a@a@    时间: 2019-2-14 15:06
#include<reg51.h>
#define sen_port P1
sbit SEN1=P1^0;
sbit SEN2=P1^1;
sbit EN1=P2^2;
sbit IN1=P2^3;
sbit IN2=P2^4;
sbit EN2=P2^5;
sbit IN3=P2^6;
sbit IN4=P2^7;
void delay(int n)               //延时子程序
  unsigned char i,j,k;
  for(i=n;i>0;i--)
  for(j=100;j>0;j--)
  for(k=200;k>0;k--);
unsigned char sensor_inp()
        unsigned char sensor;
        sensor = sen_port;
        sensor &= 0x03;
        P0 = sensor;
        return sensor;
void forward()                //two motos are runing forward
        IN1=1;
        IN2=0;
        IN3=1;
        IN4=0;
        EN1=1;
        EN2=1;
void backward()                //two motos are runing backward
        IN1=0;
        IN2=1;
        IN3=0;
        IN4=1;
        EN1=1;
        EN2=1;
void turn_left()        //left moto is runing, but right moto is brake
        IN1=1;
        IN2=0;
        IN3=0;
        IN4=0;
        EN1=1;
        EN2=1;
void rotate_left()        //right moto is runing forward, and left moto is running backward
        IN1=1;
        IN2=0;
        IN3=0;
        IN4=1;
        EN1=1;
        EN2=1;
void turn_right()        //right moto is runing, but left moto is brake
        IN1=0;
        IN2=0;
        IN3=1;
        IN4=0;
        EN1=1;
        EN2=1;
void rotate_right()        //left moto is running forward, and right moto is running backward
        IN1=0;
        IN2=1;
        IN3=1;
        IN4=0;
        EN1=1;
        EN2=1;
void free()                        //two motos is free
        IN1=0;
        IN2=0;
        IN3=0;
        IN4=0;
        EN1=0;
        EN2=0;
void stop()                        //two motos stop
        IN1=1;
        IN2=1;
        IN3=1;
        IN4=1;
        EN1=1;
        EN2=1;
void main(void)
        delay(10);
        P0=0x55;
//                P0=P1;
//        delay(100); forward();
//                delay(100); stop();
        delay(100); backward();
                delay(100); stop();
        delay(100); turn_left();
                delay(100); stop();
        delay(100); turn_right();
                delay(100); stop();
        delay(100); rotate_left();
                delay(100); stop();
        delay(100); rotate_right();
                delay(100); stop();
        delay(100); stop();
        delay(20);        forward();
        delay(20);        backward();
        delay(20);
l298n一般有3种接线方法
方式1:双电源板载5v供电(两电源须共地)
方式2:双电源单片机5v供电(拔掉跳线帽)
方式3:单电源板载5v供电(插上跳线帽)
方式2
方式2
方式3
方式3
方式1
方式1
L298N_电机驱动模块_程序书(1).doc
722.5 KB, 下载次数: 26, 下载积分: 黑币 -5
作者: admin    时间: 2019-2-14 23:44
作者: 1174051618    时间: 2019-2-18 11:27
可以的
作者: zhjjj    时间: 2019-10-21 14:53
电压给几伏、?
