标题: 做一个蓝牙小车程序,pwm中断和串口中断冲突,有大哥帮帮忙吗,看看那里有问题 [打印本页]
作者: 张事坤    时间: 2019-2-25 15:04
有大哥帮帮忙吗,看看那里有问题,51单片机做一个蓝牙小车程序,pwm中断和串口中断冲突,帮忙看看那里有问题, 感谢感谢。
#include <reg52.h>
sbit EN1 = P2^0; //为1 右电机使能
sbit EN2 = P2^1; //为1 左电机使能
sbit IN1 = P2^2; //为1 右电机反转
sbit IN2 = P2^3; //为1 右电机正转
sbit IN3 = P2^4; //为1 左电机正转
sbit IN4 = P2^5; //为1 左电机反转
#define left_motor_en           EN1 = 1           //左电机使能
#define left_motor_stops        EN1 = 0           //左电机停止
#define right_motor_en          EN2 = 1           //右电机使能
#define right_motor_stops       EN2 = 0           //右电机停止
#define left_motor_go           IN1 = 0, IN2 = 1  //左电机正传
#define left_motor_back         IN1 = 1, IN2 = 0  //左电机反转
#define right_motor_go          IN3 = 1, IN4 = 0  //右电机正传
#define right_motor_back        IN3 = 0, IN4 = 1  //右电机反转
double count = 0;//定义占空比,并初始占空比为26%
unsigned char time;
unsigned char pwm_left_val = 0;//左电机占空比值 取值范围0-170,0最快
unsigned char pwm_right_val = 0;//右电机占空比值取值范围0-170 ,0最快
unsigned char pwm_t; //周期
void UART_INIT();  //蓝牙接收初始化
void Che_init();   //小车输出端口定时器初始化
void forward();    //小车前进
void back();       //小车后退
void right();      //小车左转
void left();       //小车右转
void stop();           //小车停止
void delay(unsigned int z);        //延时函数
    while(1);
void UART_INIT()  //蓝牙接收初始化
        SCON = 0X50;
    TMOD = 0x20; //8位自动重装模式
    TH1 = 0xfd;
    TL1 = 0xfd;  //9600波特率
    TR1 = 1;     //启动定时器1
    ES = 1;      //开串口中断
        EA = 1;      //开总中断
void Che_init()         //小车使能输出端口定时器初始化
        TMOD|= 0x02; //8位自动重装模块
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        TR0=1;
        ET0=1;
        EA=1;
    TH0 = 220;
    TL0 = 220;    //11.0592M晶振下占空比最大比值是256,输出100HZ
    TR0 = 1;      //启动定时器0
    ET0 = 1;      //允许定时器0中断
    EA = 1;       //总中断允许
void forward()        //小车前进
        ET0 = 1;
        TR0 = 1;
    left_motor_go;  //左电机前进
    right_motor_go; //右电机前进
                count += 0.1;
void back()        //小车后退
        ET0 = 1;
        TR0 = 1;
        left_motor_back;  //左电机反转
        right_motor_back; //右电机反转
void right()  //小车左转
        ET0 = 1;
        TR0 = 1;
        left_motor_go;    //左电机正传
void left()          //小车右转
        ET0 = 1;
        TR0 = 1;
        right_motor_go;         //右电机正传
void stop()          //小车停止
        ET0 = 0;
        TR0 = 0;
        count = 0;
        left_motor_stops;   //左电机停止
        right_motor_stops;        //右电机停止
void timer0() interrupt 1  //定时器0中断
        TR0 = 0; //设置定时器初值期间,关闭定时器
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        //TR0=1;
        time++;
        //count += 0.1;
        if(time<count)
                EN1 = 1;  //输出高电平
                EN2 = 1;  //输出高电平
                EN1 = 0;  //输出低电平
                EN2 = 0;  //输出低电平
        if(time>=1000)
                time=0;
        pwm_t++;
        if(pwm_t == 255)
           EN1 = 0;
           EN2 = 0;
           pwm_t = 0;
        if(pwm_left_val == pwm_t)
            EN1 = 1;
        if(pwm_right_val == pwm_t)
                EN2 = 1;*/
void UART_SER() interrupt 4  //串口中断
        if(RI)
            RI = 0;//清除接收标志
        switch(SBUF)
                case 'a':          //前进
                                forward();
                                break;
            case 'b':          //后退
                                back();
                                break;
            case 'l':          //左转
                                right();
                                break;
                        case 'r':          //右转
                                left();
                                break;
            case 's':          //停止
                                stop();
                                break;
                        default:     //否则全部停止
                                stop();
                                break;
        unsigned int x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
作者: 笨笨兔    时间: 2019-2-25 16:44
程序没看,只是想问一下:
你是怎么确认的PWM中断和串口中断有冲突呢?
作者: 张事坤    时间: 2019-2-25 21:27
笨笨兔 发表于 2019-2-25 16:44
程序没看,只是想问一下:
只有pwm在动作 蓝牙串口不工作,卡在前进的while()中了,要的效果是,小车前进pwm从0到最大
作者: yaoji123    时间: 2019-2-26 08:01
中断嵌套,优级高占先,定时器0高于定时器1,定时器0定时值太小,很快就中断,造成始终定时器中断,PWM有动作,串口无法中断接收。
作者: HC6800-ES-V2.0    时间: 2019-2-26 08:20
卡这里了:
                count += 0.1;
这里死循环,当然卡住了嘛。
作者: 笨笨兔    时间: 2019-2-26 08:36
你在串口中断里直接处理SBUF,那么定时器0中断怎么进去呢?
我认为是你的程序结构或框架问题,改变思路试一试吧;
串口中断里把SBUF保存起来,在while()处理那个数据,可能会好些吧。
一般情况下,中断里面,做最少的事情,只做必要的。需要处理,把标志位保存即可,剩下的事情让主程序去干!
作者: 张事坤    时间: 2019-2-26 15:04
yaoji123 发表于 2019-2-26 08:01
中断嵌套,优级高占先,定时器0高于定时器1,定时器0定时值太小,很快就中断,造成始终定时器中断,PWM有动 ...
大哥 ,能改成pwm从0到最大吗
作者: 不成佛便成魔    时间: 2019-3-9 16:55
张事坤 发表于 2019-2-26 15:04
大哥 ,能改成pwm从0到最大吗
这是可以的,如果不正常你再把周期改小一点
作者: 刀刀见红    时间: 2019-3-9 22:13
你是怎么确认的PWM中断和串口中断有冲突,建议分开调试检查
作者: 7358655    时间: 2019-3-9 23:05
赞同HC6800-ES-V2.0
                count += 0.1;
这里死循环,只要小车前进,程序没有跳出死循环语句,程序就一直跳不出,别的程序别想工作。
作者: 黑黑—坤    时间: 2019-3-10 00:55
感觉你定时器时间太短了
作者: 菜用鸡    时间: 2019-3-10 08:11
上次我做过这个小车,后来发现串口接受一点问题都没有,就是定时器中断只进入一次,第二次就进不去,不懂你现在是不是这个问题?
作者: wulin    时间: 2019-3-10 08:58
你定时器中断设定10us,完成一次定时中断内容需要300us,怎么可能正常工作。何况在前进程序中使用死循环,结果是同归于尽,大家一起死。
作者: 我是你爸爸丶    时间: 2019-4-2 13:33
                 count += 0.1;
前进程序干嘛要加while ,可以删掉的。
还有你那定时至少100us啊,10us太短暂。
另外你你这个程序框架设计给我的感觉有点不简洁。
count += 0.1;这个你想表达什么意思呢
定义变量可以像我这么定义,用数组比较简洁。
#define Left_moto_Stop    {P1_0=0;P1_1=0,P1_2=0;}    //左电机停转
#define Left_moto_go      {P1_0=1;P1_1=1,P1_2=0;}    //左电机正转
#define Left_moto_back    {P1_0=1;P1_1=0,P1_2=1;}          //左电机反转
#define Right_moto_Stop   {P1_3=0;P1_4=0,P1_5=0;}           //右电机停转
#define Right_moto_go     {P1_3=1;P1_4=1,P1_5=0;}           //右电机正转
#define Right_moto_back   {P1_3=1;P1_4=0,P1_5=1;}           //右电机反转
引脚定义自己改
