89c51单片机控制,DHT11在1602上显示 为什么数据传不到1602上
20171594i51
2019-3-19 14:57
#include<reg52.h>
#include<intrins.h>
#define DATA P0
sbit rs=P1^0;
sbit rw=P1^1;
sbit en=P2^5;
uchar str1[]={" "},str2[]={" "};
uchar shduh_s,shdul_s,wenduh_s,wendul_s,jiaoyan_s;
uchar shduh,shdul,wenduh,wendul,jiaoyan;
uchar RH_data,RL_data,TH_data,TL_data,CK_data;
uchar FLAG,k,count,temp,comdata;
sbit wshbzh=P1^7;
void delay(xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=50;j>0;j--);
void Delay_10us(void)
uchar i;
i--;
i--;
i--;
i--;
i--;
i--;
void minling(uchar comd)
rs=0;
rw=0;
DATA=comd;
delay(5);
en=1;
delay(5);
en=0;
void writedata(uchar write)
rs=1;
rw=0;
DATA=write;
delay(5);
en=1;
delay(5);
en=0;
void writechar(uchar x,y,Data)
if (x==0)
minling(0x80+y-1);
minling(0xC0+y-1);
writedata(Data);
void lcdinit()
minling(0x02);
minling(0x06);
minling(0x0c);
minling(0x38);
minling(0x01);
void writestring(uchar x,uchar y,uchar *s)
if (x == 1)
minling(0x80 + y-1);
minling(0xC0 + y-1);
while (*s)
writedata( *s);
s ++;
void COM()
uchar i;
for(i=0;i<8;i++)
FLAG=2;
while((!wshbzh)&&FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
temp=0;
if(wshbzh) temp=1;
FLAG=2;
while((wshbzh)&&FLAG++);
if(FLAG==1)
break;
comdata<<=1;
comdata|=temp; //0
void RH()
wshbzh=0;
delay(200);
wshbzh=1;
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
wshbzh=1;
if(!wshbzh) //T !
FLAG=2;
FLAG=2;
COM();
shduh_s=comdata;
COM();
shdul_s=comdata;
COM();
wenduh_s=comdata;
COM();
wendul_s=comdata;
COM();
jiaoyan_s=comdata;
wshbzh=1; //????
temp=(shduh_s+shdul_s+wenduh_s+wendul_s);
if(temp==jiaoyan_s)
shduh=shduh_s;
shdul=shdul_s;
wenduh=wenduh_s;
wendul=wendul_s;
jiaoyan=jiaoyan_s;
int main()
rs=0;
rw=0;
en=0;
lcdinit();
writestring(1,1,"shidu:");
writestring(2,1,"wendu:");
writestring(1,10,"%");
writestring(2,10,"C");
RH();
RH_data=shduh;
RL_data=shdul;
TH_data=wenduh;
TL_data=wendul;
CK_data=jiaoyan;
str1[0]=(char)(0x30+RH_data/10);
str1[1]=(char)(0x30+RH_data%10);
str2[0]=(char)(0x30+TH_data/10);
str2[1]=(char)(0x30+TH_data%10);
writechar(1,8,str1[0]);
writechar(1,9,str1[1]);
writechar(2,8,str2[0]);
writechar(2,9,str2[1]);
delay(2000);
xuyaqi
2019-3-19 17:25
先实现能正确读出DHT11的数据,再实现到1602显示。
lfc315
2019-3-19 18:10
writechar(2,9,str2[1]); ,这个语句不是把内容发到1602上显示吧?
