sbit RS = P2^5;//Pin4(2)脉搏检测处理程序
sbit RW = P2^6; //Pin5
sbit E = P2^7;//Pin6
#define ulong unsigned long
uchar data TimeNum[]=" ";
uchar data Test1[]=" ";
void DelayUs(unsigned char us)//delay us
unsigned char uscnt;
uscnt=us>>1;/* Crystal frequency in 12MHz*/
while(--uscnt);
void DelayMs(unsigned char ms)//delay Ms
while(--ms)
DelayUs(250);
DelayUs(250);
DelayUs(250);
DelayUs(250);
void WriteCommand(unsigned char c)
DelayMs(5);//short delay before operation
E=0;
RS=0;
RW=0;
_nop_();
E=1;
P1=c;
E=0;
void WriteData(unsigned char c)
DelayMs(5); //short delay before operation
E=0;
RS=1;
RW=0;
_nop_();
E=1;
P1=c;
E=0;
RS=0;
void ShowChar(unsigned char pos,unsigned char c)
unsigned char p;
if (pos>=0x10)
p=pos+0xb0; //是第二行则命令代码高4位为0xc
p=pos+0x80; //是第二行则命令代码高4位为0x8
WriteCommand (p);//write command
WriteData (c); //write data
void ShowString (unsigned char line,char *ptr)
unsigned char l,i;
l=line<<4;
for (i=0;i<16;i++)
ShowChar (l++,*(ptr+i));//循环显示16个字符
void InitLcd()
DelayMs(15);
WriteCommand(0x38); //display mode
WriteCommand(0x06); //显示光标移动位置
WriteCommand(0x0c); //显示开及光标设置
WriteCommand(0x01); //显示清屏
unsigned int i,n,ci,dd[11],jj,j,k,tmp;
bit w=0;
uchar bh;
ulong time;
sbit spd = P2^0;
external0() interrupt 0//外部中断服务程序
w=~w;
if(w==0)
EX0=0;
ET0=1;
TH0=0x0;
TL0=0x0;
n=0;
time=n*65536+TH0*256+TL0;
dd[jj]=30000000/time; //计算脉搏时间
jj++;
if(jj>10)
jj=0;
for(j=0;j<11;j++)
for(k=0;k<11-j;k++)
if(dd[k]>dd[k+1])
tmp=dd[k];
dd[k]=dd[k+1];
dd[k+1]=tmp;
if(dd[5]>50&&dd[5]<200)ci=((dd[4]+dd[5]+dd[6])/3)+11;
TH0=0x0;
TL0=0x0;
n=0;
void timer0(void) interrupt 1
n++;
void main(void)
InitLcd();//
DelayMs(15);
IT0=1; //INT0下降沿中断
EX0=1; //允许INT1中断
TMOD=0x1;
TH0=0x0;
TL0=0x0;
TR0=1;
ET0=1;
EA=1;
if(n>10)
n=0;
jj=0;
ci=0;
TimeNum[0]='N';
TimeNum[1]='O' ;
TimeNum[2]=' ' ;
TimeNum[3]='I' ;
TimeNum[4]='N' ;
TimeNum[5]='P' ;
TimeNum[6]='U' ;
TimeNum[7]='T' ;
TimeNum[8]=' ' ;
ShowString(0,TimeNum);
ShowString(1,Test1);
if(w==0&&EX0==0)
delay();
EX0=1;
TimeNum[0]=' ';
TimeNum[1]=' ' ;
TimeNum[2]=' ' ;
TimeNum[3]=' ' ;
TimeNum[4]=' ' ;
TimeNum[5]=' ' ;
if(ci/100>0)TimeNum[6]=ci/100+'0' ; else TimeNum[6]=' ' ;
if(ci/100==0&&ci%100/10>0)TimeNum[7]=ci%100/10+'0' ; else TimeNum[7]=' ' ;
TimeNum[8]=ci%10+'0' ;
if(ci>100)spd=0;else spd=1;
