标题: Maxwell R17.1 coupling to Simulink example [打印本页] 作者: superlllllllll 时间: 2019-4-16 22:06 标题: Maxwell R17.1 coupling to Simulink example Maxwell R17.1 coupling to Simulink example
利用maxwell和simulink进行联合仿真例程,感兴趣的可以下载看一下。
Maxwell 2D/3D R17.1 coupling to Simulink R2014b 64-bit Example
1. Open ANSYS electronic desktop
2. Open an RMxprt example, such as: ../bldc/ws1.aedt
3. Run the RMxprt simulation so that we can create Maxwell designs.
4. Right click on “Setup1”, then click “Create Maxwell Design…” to create both 2D and 3D designs
