搬运车+GY-31传感器TCS23颜色参考单片机源码
hao17568185487
2019-5-12 16:47
之前做比赛的时候通关网络搜集了一些 然后根据自己的车 做了部分修改 算是一个整合吧 基于51单片机
#include<iom128v.h>
#include<macros.h>
#include<BIT.h>
#include"LCD12864.c"
#pragma interrupt_handler timer0:iv_TIMER0_OVF
#pragma interrupt_handler int0:iv_INT0
#define PSB _PA3
#define REST _PA4
#define LED_B _PG1
#define S2 _PE0
#define S3 _PE1
#define buzzer _PG0
uchar table0[]="颜色识别";
uchar table1[]="红色: ";
uchar table2[]="绿色: ";
uchar table3[]="蓝色: ";
uint red,gree,blue,time_count,int_count;
uchar red_value,gree_value;
void delay(uint tt)
uchar j;
for(;tt>0;tt--)
for(j=100;j>0;j--);
void timer_Init()
TCCR0=0x07;
TCNT0=0x64;
// TIMSK|=BIT(0);
void interrupt0_Init()
// EIMSK|=BIT(0);
EICRA=0x02;
DDR_PD0=0;
// _PD0=1;
void PORT_INIT()
DDR_PA0=1;
DDR_PA1=1;
DDR_PA2=1;
DDR_PA3=1;
DDR_PA4=1;
DDRC=0xff;
DDR_PE0=1;
DDR_PE1=1;
DDR_PG0=1;
DDR_PG1=1;
PSB=0;
REST=1;
LED_B=1;
void color_Recognition()
S2=1;
S3=1;
EIMSK|=BIT(0);
TIMSK|=BIT(0);
PORT_INIT();
timer_Init();
interrupt0_Init();
LCD_12864_Init();
SREG|=BIT(7);
// PutStr(0,2,table0);
PutStr(1,1,table1);
PutStr(2,1,table2);
PutStr(3,1,table3);
delay(5000);
buzzer=1;
delay(200);
buzzer=0;
color_Recognition();
while(1);
void timer0()
uchar ge,shi,bai,qian;
float temp;
TIMSK&=~BIT(0);
time_count++;
TCNT0=0x64;
if(time_count==1)
bai=int_count/100;
shi=int_count%100/10;
ge=int_count%10;
Write_command_12864(0x95);
Write_data_12864(0x30+bai);
Write_data_12864(0x30+shi);
Write_data_12864(0x30+ge);
red=int_count;
S2=1;
S3=1;
if(time_count==2)
bai=int_count/100;
ge=int_count%10;
Write_command_12864(0x8d);
gree=int_count;
S2=0;
S3=1;
if(time_count==3)
bai=int_count/100;
ge=int_count%10;
Write_command_12864(0x9d);
blue=int_count;
S2=0;
S3=0;
if(time_count==40)
time_count=0;
temp=(float)red/blue;
red_value=temp*1000;
temp=(float)gree/blue;
gree_value=temp*1000;
qian=red_value/1000;
bai=red_value%1000/100;
shi=red_value%100/10;
ge=red_value%10;
Write_command_12864(0x81);
Write_data_12864(0x30+qian);
qian=gree_value/1000;
bai=gree_value%1000/100;
shi=gree_value%100/10;
ge=gree_value%10;
Write_command_12864(0x85);
int_count=0;
TIMSK|=BIT(0);
void int0()
int_count++;
(5.75 KB, 下载次数: 35)
下载附件
2019-5-17 05:51 上传
GY-31颜色模块发送资料.7z
(4 MB, 下载次数: 14)
2019-5-17 05:52 上传
点击文件名下载附件
下载积分: 黑币 -5
