标题: STM32单片机+SX1278官方源码分享 [打印本页]
作者: shw7610    时间: 2019-5-17 16:52
自带收发功能,支持SX1272/1276/1278
  1. #include <string.h>
  2. #include <stdint.h>
  3. #include <stdbool.h>
  4. #include "platform.h"
  5. #include "led.h"
  6. #if USE_UART
  7. #include "uart.h"
  8. #endif
  9. #include "radio.h"
  10. #define BUFFER_SIZE                                 9 // Define the payload size here
  11. static uint16_t BufferSize = BUFFER_SIZE;                        // RF buffer size
  12. static uint8_t Buffer[BUFFER_SIZE];                                        // RF buffer
  13. static uint8_t EnableMaster = true;                                 // Master/Slave selection
  14. tRadioDriver *Radio = NULL;
  15. const uint8_t PingMsg[] = "PING";
  16. const uint8_t PongMsg[] = "PONG";
  17. /*
  18. * Manages the master operation
  19. */
  20. void OnMaster( void )
  21. {
  22.     uint8_t i;
  23.     switch( Radio->Process( ) )
  24.     {
  25.     case RF_RX_TIMEOUT:
  26.         // Send the next PING frame
  27.         Buffer[0] = 'P';
  28.         Buffer[1] = 'I';
  29.         Buffer[2] = 'N';
  30.         Buffer[3] = 'G';
  31.         for( i = 4; i < BufferSize; i++ )
  32.         {
  33.             Buffer[i] = i - 4;
  34.         }
  35.         Radio->SetTxPacket( Buffer, BufferSize );
  36.         break;
  37.     case RF_RX_DONE:
  38.         Radio->GetRxPacket( Buffer, ( uint16_t* )&BufferSize );
  39.         if( BufferSize > 0 )
  40.         {
  41.             if( strncmp( ( const char* )Buffer, ( const char* )PongMsg, 4 ) == 0 )
  42.             {
  43.                 // Indicates on a LED that the received frame is a PONG
  44.                 LedToggle( LED_GREEN );
  45.                 // Send the next PING frame
  46.                 Buffer[0] = 'P';
  47.                 Buffer[1] = 'I';
  48.                 Buffer[2] = 'N';
  49.                 Buffer[3] = 'G';
  50.                 // We fill the buffer with numbers for the payload
  51.                 for( i = 4; i < BufferSize; i++ )
  52.                 {
  53.                     Buffer[i] = i - 4;
  54.                 }
  55.                 Radio->SetTxPacket( Buffer, BufferSize );
  56.             }
  57.             else if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
  58.             { // A master already exists then become a slave
  59.                 EnableMaster = false;
  60.                 LedOff( LED_RED );
  61.             }
  62.         }
  63.         break;
  64.     case RF_TX_DONE:
  65.         // Indicates on a LED that we have sent a PING
  66.         LedToggle( LED_RED );
  67.         Radio->StartRx( );
  68.         break;
  69.     default:
  70.         break;
  71.     }
  72. }
  73. /*
  74. * Manages the slave operation
  75. */
  76. void OnSlave( void )
  77. {
  78.     uint8_t i;
  79.     switch( Radio->Process( ) )
  80.     {
  81.     case RF_RX_DONE:
  82.         Radio->GetRxPacket( Buffer, ( uint16_t* )&BufferSize );
  83.         if( BufferSize > 0 )
  84.         {
  85.             if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
  86.             {
  87.                 // Indicates on a LED that the received frame is a PING
  88.                 LedToggle( LED_GREEN );
  89.                // Send the reply to the PONG string
  90.                 Buffer[0] = 'P';
  91.                 Buffer[1] = 'O';
  92.                 Buffer[2] = 'N';
  93.                 Buffer[3] = 'G';
  94.                 // We fill the buffer with numbers for the payload
  95.                 for( i = 4; i < BufferSize; i++ )
  96.                 {
  97.                     Buffer[i] = i - 4;
  98.                 }
  99.                 Radio->SetTxPacket( Buffer, BufferSize );
  100.             }
  101.         }
  102.         break;
  103.     case RF_TX_DONE:
  104.         // Indicates on a LED that we have sent a PONG
  105.         LedToggle( LED_RED );
  106.         Radio->StartRx( );
  107.         break;
  108.     default:
  109.         break;
  110.     }
  111. }
  112. /*
  113. * Main application entry point.
  114. */
  115. int main( void )
  116. {
  117.     BoardInit( );
  118.     Radio = RadioDriverInit( );
  119.     Radio->Init( );
  120.     Radio->StartRx( );
  121.     while( 1 )
  122.     {
  123.         if( EnableMaster == true )
  124.         {
  125.             OnMaster( );
  126.         }
  127.         else
  128.         {
  129.             OnSlave( );
  130.         }
  131. #if( PLATFORM == SX12xxEiger ) && ( USE_UART == 1 )
  132.         UartProcess( );
  133.         {
  134.             uint8_t data = 0;
  135.             if( UartGetChar( &data ) == UART_OK )
  136.             {
  137.                 UartPutChar( data );
  138.             }
  139.         }
  140. #endif
  141.     }
  142. #ifdef __GNUC__
  143.     return 0;
  144. #endif
  145. }
全部资料51hei下载地址:
semtech驱动源码SX12xxDrivers-2.0.0.7z (577.25 KB, 下载次数: 109)
作者: zailushang...    时间: 2020-12-17 11:08
这是stm32的程序
作者: 993347045    时间: 2021-11-3 00:04
十分感谢分享代码,学习了~~~
