基于51单片机的THM3060开发程序 缺少文件 求帮助
15130116395
2019-5-22 17:01
共享一下网上不好找到的资料,但是 缺少文件无法编译 求指导
#include <stdio.h>
#include "..\at89x52.h"
#include "..\Communication\Comn2.h"
#include "..\command\comd.h"
#include "..\thm3060\thm3060.h"
#include "main.h"
#define EnableInterrupt() EA =1;
#define DisableInterrupt() EA =0;
// FWT (FRAME WATI TIME)为最大静默时间,即读卡器发送完数据后,到开始收到卡片
// 响应,读卡器的最大等待时间 t = FWT * 302 uS
unsigned short FWT = 10; //设置最大等待时间为 3ms
initial_serial();
EnableInterrupt();
THM_Reset();
puts("THM3060 Demo Reader (TDR) Version 1.1\r\nCopyright by \
LEMICRO Technology Co. Ltd 2016.10. All rights reserved.\r\r");
puts("THM3060 working at SPI mode.\r");
printf ("TDR V1.0 >");
deal_with_command();
TypeB_CardRead();
#include "../spi/spi.h"
#include "THM3060.h"
// 通过 SPI 总线写 address 寄存器的值
extern void THM_WriteReg(unsigned char address,unsigned char content)
unsigned char temp_buff[2];
// 写命令 BIT7 =1
temp_buff[0] = address | 0x80;
temp_buff[1] = content;
// SPI 帧
SPI_FRAME_START();
SPI_SendBuff(temp_buff,2);
SPI_FRAME_END();
// 通过 SPI 总线读 address 寄存器的值
extern unsigned char THM_ReadReg(unsigned char address)
unsigned char temp_buff[1];
// SS_N =0;
SPI_FRAME_START();
// 读命令 BIT7 = 0;
temp_buff[0] = address & 0x7F;
SPI_SendBuff(temp_buff,1);
SPI_RecvBuff(temp_buff,1);
//SS_N =1;
SPI_FRAME_END();
return(temp_buff[0]);
// SPI 模式等待接收结束,并读出接收数据,数据存在缓冲区 buffer 中,长度为 len
// 返回值为接收状态
extern unsigned char THM_WaitReadFrame(unsigned short *len, unsigned char *buffer)
unsigned char temp,temp1;
// 等待接收结束
while (1)
temp = THM_ReadReg(RSTAT);
if (temp & 0x80)
break;
// 处理返回状态状态值
if (temp & CERR )
temp = CERR; //碰撞错误
else if (temp & PERR)
temp = PERR; //奇偶校验位错误
else if (temp & FERR)
temp = FERR;
else if (temp & DATOVER)
temp = DATOVER; //数据溢出
else if (temp & TMROVER)
temp = TMROVER; //超时错误
else if (temp & CRCERR)
temp = CRCERR; //CRC 计算错误
temp = FEND; //帧正常结束
//取得接收长度值
*len =((unsigned short)(THM_ReadReg(RSCH)) <<8 ) + THM_ReadReg(RSCL);
//读取接收数据
if (*len != 0x00 )
SPI_FRAME_START();
temp1 = DATA;
SPI_SendBuff( &temp1,1);
SPI_RecvBuff( buffer,*len);
SPI_FRAME_END();
//清除状态标志
THM_WriteReg(RSTAT,0x00);
return (temp);
// 读取接收状态和接收长度
extern unsigned char THM_ReadStat( unsigned short *len)
unsigned char temp;
if (temp & 0x80 == 0)
*len =0;
return 0;
if (temp & CERR )
temp = CERR;
temp = PERR;
temp = FERR;
temp = DATOVER;
temp = TMROVER;
temp = CRCERR;
temp = FEND;
return temp;
//读取接收缓冲区数据
extern void THM_ReadBuff( unsigned short *len,unsigned char * buff)
unsigned char temp;
if (*len != 0x00 )
SPI_FRAME_START();
temp = DATA;
SPI_SendBuff( &temp,1);
SPI_RecvBuff( buff,*len);
SPI_FRAME_END();
// 发送数据子程序
extern void THM_SendFrame(unsigned char *buffer,unsigned short num)
unsigned char temp;
THM_WriteReg(SCNTL, 0x5); //RAMPT_CLR =1,CLK_EN =1
THM_WriteReg(SCNTL, 0x01); // RAMPT_CLK=0;
temp = DATA | 0x80; //写数据寄存器命令
SPI_FRAME_START();
SPI_SendBuff(&temp,1);
SPI_SendBuff(buffer,num); //写入数据
SPI_FRAME_END();
THM_WriteReg(SCNTL, 0x03); // SEND =1 ,开始发送
//打开射频
extern void THM_OpenRF()
THM_WriteReg(SCNTL,0x01);
return;
//关闭射频
extern void THM_CloseRF()
THM_WriteReg(SCNTL,0x00);
return;
extern void THM_ChangeProtBaud(unsigned char prot, unsigned char sndbaud, unsigned char rcvbaud)
THM_WriteReg( PSEL, prot | sndbaud | rcvbaud );
return;
#if 0
unsigned char xdata reqb[] = {0x05,0x00,0x00};
unsigned char xdata revbuff[100] _at_ 0x000;
unsigned short len;
unsigned char temp;
GPIO_DIR = 0x01;
InitSPI();
THM_OpenRF();
THM_SendFrame(reqb,3);
temp =THM_WaitReadFrame(&len,revbuff);
//temp = THM_ReadReg(0x05);
#endif
基于51单片机的THM3060参考程序.7z
(216.39 KB, 下载次数: 51)
2022-3-10 20:29 上传
点击文件名下载附件
