WIFI EDP协议 连接中国移动云
xiazhanyongyuan
2019-5-23 21:08
WIFI EDP协议 连接中国移动云
#define MAIN_Fosc 22118400L
#include "STC15Fxxxx.H"
#define Baudrate1 115200UL
#define Baudrate2 115200UL
u8 code Connect_Com[]={0X10,0X32,0X00,0X03,0X45,0X44,0X50,0X01,0X40,0X01,0X2C,0X00,0X09,0X35,0X31,0X38,0X39,0X38,0X38,0X32,0X37,
0X31,0X00,0X1C,0X63,0X52,0X6E,0X67,0X4F,0X50,0X4B,0X3D,0X33,0X6C,0X4D,0X65,0X78,0X32,0X41,0X75,0X45,0X69,0X32,0X41,0X37,0X63,0X6D,0X58,0X58,0X38,0X63,0X3D,0xff};
u8 code Save_Data []={0X80,0X63,0X00,0X01,0X00,0X5F,0X7B,0X0A,0X09,0X22,0X64,0X61,0X74,0X61,0X73,0X74,0X72,0X65,0X61,0X6D,0X73,0X22,0X3A,0X09,0X5B,0X7B,0X0A,0X09,0X09,0X09,0X22,0X69,
0X64,0X22,0X3A,0X09,0X22,0X74,0X65,0X6D,0X70,0X65,0X72,0X61,0X74,0X75,0X72,0X65,0X22,0X2C,0X0A,0X09,0X09,0X09,0X22,0X64,0X61,0X74,0X61,0X70,0X6F,0X69,
0X6E,0X74,0X73,0X22,0X3A,0X09,0X5B,0X7B,0X0A,0X09,0X09,0X09,0X09,0X09,0X22,0X76,0X61,0X6C,0X75,0X65,0X22,0X3A,0X09,0X38,0X30,0X0A,0X09,0X09,0X09,0X09,0X7D,0X5D,0X0A,
0X09,0X09,0X7D,0X5D,0X0A,0X7D,0xff};
unsigned char code WIFI_Heartbeat[]={0XC0,0X00,0XFF};
bit B_TX1_Busy;
bit B_TX2_Busy;
bit Heartbeat_Flag;
bit Heartbeat_Detection;
u8 Res_Char;
void PrintString1(u8 *puts);
void PrintString2(u8 *puts);
void PrintString_baowen(u8 *puts);
void UART1_config(u8 brt);
void UART2_config(u8 brt);
void WIFI_Init();
void Delay3000ms();
void Delay10000ms();
void Heartbeat_Response()
unsigned char j;
if(Heartbeat_Flag==1)
Heartbeat_Flag=0;
for(j=0;j<3 && Heartbeat_Flag !=1;j++)
PrintString_baowen(WIFI_Heartbeat);
Delay3000ms();
Delay3000ms();
break;
Heartbeat_Flag=0;
WIFI_Init();
Delay3000ms();
PrintString_baowen(Connect_Com);
Delay3000ms();
void main(void)
P0M1 = 0; P0M0 = 0;
P1M1 = 0; P1M0 = 0;
P2M1 = 0; P2M0 = 0;
P3M1 = 0; P3M0 = 0;
P4M1 = 0; P4M0 = 0;
P5M1 = 0; P5M0 = 0;
P6M1 = 0; P6M0 = 0;
P7M1 = 0; P7M0 = 0;
UART1_config(1);
UART2_config(2);
EA = 1;
WIFI_Init();
Delay3000ms();
while (1)
for (; *puts != 0; puts++)
SBUF = *puts;
B_TX1_Busy = 1;
while(B_TX1_Busy);
S2BUF = *puts;
B_TX2_Busy = 1;
while(B_TX2_Busy);
for (; *puts != 0xff; puts++)
S2BUF = *puts;
B_TX2_Busy = 1;
while(B_TX2_Busy);
void SetTimer2Baudraye(u16 dat)
AUXR &= ~(1<<4);
AUXR &= ~(1<<3);
AUXR |= (1<<2);
TH2 = dat / 256;
TL2 = dat % 256;
IE2 &= ~(1<<2);
AUXR |= (1<<4);
if(brt == 2)
AUXR |= 0x01;
SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate1);
TR1 = 0;
AUXR &= ~0x01;
AUXR |= (1<<6);
TMOD &= ~(1<<6);
TMOD &= ~0x30;
TH1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) / 256);
TL1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) % 256);
ET1 = 0;
INT_CLKO &= ~0x02;
TR1 = 1;
SCON = (SCON & 0x3f) | 0x40;
ES = 1;
REN = 1;
P_SW1 &= 0x3f;
B_TX1_Busy = 0;
if(brt == 2)
SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate2);
S2CON &= ~(1<<7);
IE2 |= 1;
S2CON |= (1<<4);
P_SW2 &= ~0x01;
B_TX2_Busy = 0;
void UART1_int (void) interrupt UART1_VECTOR
if(RI)
RI = 0;
if(TI)
TI = 0;
B_TX1_Busy = 0;
void UART2_int (void) interrupt UART2_VECTOR
if((S2CON & 1) != 0)
S2CON &= ~1;
Res_Char=S2BUF;
SBUF=Res_Char;
if(Res_Char==0XD0)
Heartbeat_Detection=1;
if((Res_Char==0X00) && (Heartbeat_Detection==1))
Heartbeat_Flag=1;
Heartbeat_Detection=0;
if((S2CON & 2) != 0)
S2CON &= ~2;
B_TX2_Busy = 0;
void Delay10000ms()
unsigned char i, j, k;
_nop_();
_nop_();
i = 165;
j = 59;
k = 28;
do
do
while (--k);
} while (--j);
} while (--i);
void Delay3000ms()
_nop_();
_nop_();
i = 127;
j = 18;
k = 107;
do
do
while (--k);
} while (--j);
} while (--i);
void WIFI_Init()
PrintString2("+++");
Delay10000ms();
PrintString2("AT\r\n");
Delay10000ms();
PrintString2("AT+CWMODE=3\r\n");
Delay10000ms();
PrintString2("AT+RST\r\n");
Delay10000ms();
PrintString2("AT+CWJAP=\"iPhoneSE\",\"12345678\"\r\n");
Delay10000ms();
Delay10000ms();
Delay10000ms();
PrintString2("AT+CIPSTART=\"TCP\",\"183.230.40.39\",876\r\n");
Delay10000ms();
Delay10000ms();
Delay10000ms();
PrintString2("AT+CIPMODE=1\r\n");
Delay10000ms();
PrintString2("AT+CIPSEND\r\n");
Delay10000ms();
