标题: SHT3x温湿度传感器pdf资料手册下载 [打印本页]
作者: dpj121    时间: 2019-5-29 18:31
SHT温湿度传感器数据手册摘要:
Datasheet SHT3x-DIS
Humidity and Temperature Sensor
  Fully calibrated, linearized, and temperature compensated digital output
  Wide supply voltage range, from 2.4 V to 5.5 V
  I2C Interface with communication speeds up to 1 MHz and two user selectable addresses
  Typical accuracy of  1.5 %RH and  0.2 °C for SHT35
  Very fast start-up and measurement time
  Tiny 8-Pin DFN package
完整的pdf格式文档51黑下载地址:
SHT3x_DIS.pdf (910.44 KB, 下载次数: 16)
