stm32 f1 超声波程序
反反规范
2019-6-5 19:46
stm32 f1 超声波程序
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "led.h"
#include "key.h"
硬件连接
串口1:RX PA10 TX PA9
超声波:Trig PB11 ECHG PB10
备注:以下代码非原创,只是经过修改适配成STM32F103C8T6
若侵权,请告知。
//超声波硬件接口定义
#define HCSR04_PORT GPIOB
#define HCSR04_CLK RCC_APB2Periph_GPIOB
#define HCSR04_TRIG GPIO_Pin_11
#define HCSR04_ECHO GPIO_Pin_10
//超声波计数
u16 msHcCount = 0;
//定时器4设置
void hcsr04_NVIC()
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//IO口初始化 及其他初始化
void Hcsr04Init()
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
GPIO_InitStructure.GPIO_Pin = HCSR04_ECHO;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
TIM_DeInit(TIM2);
TIM_TimeBaseStructure.TIM_Period = (1000-1);
TIM_TimeBaseStructure.TIM_Prescaler =(72-1);
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_ClearFlag(TIM4, TIM_FLAG_Update);
TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
hcsr04_NVIC();
TIM_Cmd(TIM4,DISABLE);
//打开定时器4
static void OpenTimerForHc()
TIM_SetCounter(TIM4,0);
msHcCount = 0;
TIM_Cmd(TIM4, ENABLE);
//关闭定时器4
static void CloseTimerForHc()
TIM_Cmd(TIM4, DISABLE);
//定时器4终中断
void TIM4_IRQHandler(void)
if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM4, TIM_IT_Update );
msHcCount++;
//获取定时器4计数器值
u32 GetEchoTimer(void)
u32 t = 0;
t = msHcCount*1000;
t += TIM_GetCounter(TIM4);
TIM4->CNT = 0;
delay_ms(50);
return t;
//通过定时器4计数器值推算距离
float Hcsr04GetLength(void )
u32 t = 0;
int i = 0;
float lengthTemp = 0;
float sum = 0;
while(i!=5)
TRIG_Send = 1;
delay_us(20);
TRIG_Send = 0;
while(ECHO_Reci == 0);
OpenTimerForHc();
i = i + 1;
while(ECHO_Reci == 1);
CloseTimerForHc();
t = GetEchoTimer();
lengthTemp = ((float)t/58.0);//cm
sum = lengthTemp + sum ;
lengthTemp = sum/5.0;
return lengthTemp;
//测试主函数
int main(void)
float length;
delay_init(); //延时函数初始化
NVIC_Configuration(); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
uart_init(9600); //串口初始化为9600
Hcsr04Init();
printf("大海电子串口测试\r\n");
Hcsr04Init();
printf("超声波初始化成功!\n");
length = Hcsr04GetLength();
printf("距离为:%.3fcm\n",length);
delay_ms(1000);
704597517
2019-6-14 21:51
能问下你这些的主函数是不是少了一些 ,打开定时器和关闭定时器能不用外部中断吗,就IO口判断行吗?定时器4的终端是干什么用的
伊特
2019-8-2 18:50
704597517 发表于 2019-6-14 21:51
能问下你这些的主函数是不是少了一些 ,打开定时器和关闭定时器能不用外部中断吗,就IO口判断行吗?定时器4 ...
你有好的实现方案程序吗,可不可以参考下
