1602 LCD字符液晶小小迎宾程序
兴仔
2019-6-9 14:28
1602 LCD字符液晶小小迎宾程序
#include<reg51.h>
#include<string.h>
void Initialize_LCD();
void DelayMS(uint ms);
void ShowString(uchar,uchar,uchar *);
sbit K1=P3^2;
uchar const Line_Count=2;
uchar code Msg[][80]={
"welcome to HeiLongJiang polytechnic!",
"2015-2-3 9:09:09",
uchar Disp_Buffer[32];
void H_Scroll_Display()
uchar i,j;
uchar *p=Msg[0];
uchar *q=Msg[0]+strlen(Msg[0]);
for(i=0;i<16;i++)Disp_Buffer[ i]=' ';
while(p<q)
if((i==16||i==31)&&*p==' ')p++;
for(i=16;i<32&&p<q;i++)
if(*p!='\0')
Disp_Buffer[ i]=*p++;
break;
for(j=i;j<32;j++)Disp_Buffer[j]=' ';
for(i=0;i<=16;i++)
while(F0)DelayMS(100);
ShowString(0,0,Disp_Buffer+i);
DelayMS(200);
DelayMS(300);
void EX_INT0() interrupt 0
F0=!F0;
uint Count=0;
IE=0x81;
IT0=1;
F0=0;
Initialize_LCD();
ShowString(0,1,Msg[1]);
H_Scroll_Display();
DelayMS(300);
