标题: Keil编译显示打不开头文件,出现 before 'jump... [打印本页]
作者: 流浪先生    时间: 2019-6-30 13:43
# include "bsp.h"
# define S        5.0f
uint8_t JumpTime = 0;                /* 外部中断0边沿跳变次数统计 */
uint8_t MeasureOK = 0;        /* 测量完成标志 */
uint32_t Time = 0;                        /* 用于计算两次边沿跳变的时间 */
uint8_t str[20] = {0};        /* LCD显示缓存区 */
sbit key = P3^2;                                /* 外部中断引脚 */
int main(void)
        bsp_Config();                /* 板级外设初始化 */
        EX0 = 1;                /* 开启外部中断0 */
        bsp_lcd_ShowString(1, 0, "Speed Measuring");
void EX0_IRQ(void) interrupt 0
        float speed = 0.0f;
        JumpTime++;                /* 统计中断次数 */
        while(key == 0);                /* 等待按键被释放 */
        if(JumpTime >= 2 && MeasureOK == 0)                /* 按键已经按了两次,计算速度 */
                JumpTime = 0;                /* 清除跳变量 */
                MeasureOK = 1;        /* 已经完成测量了 */
                speed = (float)((S /Time) * 1000.0);
                Time = 0;
                sprintf(str,"%f m/s", speed);
                bsp_lcd_ShowString(0, 1, str);
#include "bsp.h"
void bsp_Config(void)
        bsp_lcd_Config();
        bsp_tim_Config();
void bsp_DelayMs(uint8_t ui_nMs)
        uint8_t a = 0, b = 0;
        for(; ui_nMs > 0; ui_nMs --)
                for(a = 199; a > 0; a --)
                        for(b = 1; b > 0; b --);
# include "bsp.h"
# include "app.h"
# define TIMS (65536 - FOSC/1000)
void bsp_tim_Config(void)
        TMOD = 0x01;
        TL0 = TIMS;
        TH0 = TIMS >> 8;
        TR0 = 1;
        ET0 = 1;
        EA = 1;
static count = 0;
extern uint8_t JumpTime;
extern uint32_t Time;
void timer0_IRQ(void)        interrupt 1 using 1
        TL0 = TIMS;                                /* 需要重装初值 */
        TH0 = TIMS >> 8;
        if(JumpTime == 1)                /* 只有在第一次按下后才开始计数,直到第二次按下 */
                Time ++;
static void bsp_lcd_WriteCmd(uint8_t cmd)
        LCD_EN = 0;                        /*  使能LCD1602  */
        LCD_RD = 0;                        /*  选择发送命令  */
        LCD_RW = 0;                        /*  选择写入  */
        LCD_DATA = cmd;                /* 写入命令 */
        bsp_DelayMs(5);                /* 等待数据稳定延时5ms */
        LCD_EN = 1;                                /* 写入时序 */
        bsp_DelayMs(10);
        LCD_EN = 0;
static void bsp_lcd_WriteData(uint8_t dat)
        LCD_EN = 0;
        LCD_RD = 1;
        LCD_RW = 0;
        LCD_DATA = dat;        //将数据放到LCD里
        bsp_DelayMs(1);
        LCD_EN = 1;
        bsp_DelayMs(5);
        LCD_EN = 0;
void bsp_lcd_Config(void)
        bsp_lcd_WriteCmd(0x38);                /* 开显示 */
        bsp_lcd_WriteCmd(0x0c);                /* 不显示光标 */
        bsp_lcd_WriteCmd(0x06);                /* 写一个指针加1 */
        bsp_lcd_WriteCmd(0x01);                /* 清屏 */
        bsp_lcd_WriteCmd(0x80);                /* 指针复位 */
static void bsp_lcd_SetPos(uint8_t x, uint8_t y)
        /* 坐标超出范围了 */
        if(x > 15) return ;
        if(y > 1) return ;
        if(y == 0)        bsp_lcd_WriteCmd(x + 0x80);
        else if(y == 1) bsp_lcd_WriteCmd(x + 0xc0);
void bsp_lcd_ShowNum(uint8_t x, uint8_t y, uint32_t num, uint8_t xbit)
        uint8_t temp = 0;
        while(xbit)
                temp = num % 10;                /*  取得要显示的个位  */
                /*  从最后一位开始显示  */
                bsp_lcd_SetPos(x + xbit - 1, y);
                bsp_lcd_WriteData(temp + 0x30);
                num/=10;                /* 已经显示完个位了,把个位扔掉 */
                xbit --;                /* 由于是从后往前开始显示,所以x坐标轴要减小 */
void bsp_lcd_ShowChar(uint8_t x, uint8_t y, uint8_t c)
        bsp_lcd_SetPos(x, y);
        bsp_lcd_WriteData(c);
void bsp_lcd_ShowString(uint8_t x, uint8_t y, uint8_t *string)
        uint8_t i = 0;
        while(*(string + i))                /* 在字符串没有结束就一直显示 */
                bsp_lcd_ShowChar(x + i, y, *(string + i));
                i++;
作者: 1952968380    时间: 2019-7-8 15:48
keil文件使用方法你可以查一下,貌似只能打开单片机应用的文件,希望对你有帮助
