标题: STM32以太网lwip服务器实现程序 [打印本页]
作者: matthewroy    时间: 2019-7-2 10:16
更具lwip移植到stm32上实现以太网服务器
  1. #include "led.h"
  2. #include "lcd.h"
  3. #include "key.h"
  4. #include "stm32f4x7_eth.h"
  5. #include "stm32f4x7_eth_bsp.h"
  6. #include "netconf.h"
  7. #include "tcp.h"
  8. #include "udp.h"
  9. #include "string.h"
  10. #include "TCP_SERVER.h"
  11. #define SYSTEMTICK_PERIOD_MS  10
  12.
  13. /* Private macro -------------------------------------------------------------*/
  14. /* Private variables ---------------------------------------------------------*/
  15. __IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
  16. uint32_t timingdelay;
  17. int main(void)
  18. {
  19.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
  20.         delay_init();         //初始化延时函数
  21.         LED_Init();                                          //初始化LED
  22.         //LCD_Init();                                          //初始化LCD
  23.         KEY_Init();           //初始化KEY
  24.
  25. //        BRUSH_COLOR=RED;
  26. //        LCD_DisplayString(10,10,24,"Illuminati STM32F4");
  27. //  LCD_DisplayString(10,40,16,"Author:Clever");
  28. //        LCD_DisplayString(20,70,24,"23 TCP_Server ");
  29. //
  30. //        BRUSH_COLOR=BLUE;
  31. //        LCD_DisplayString(20,110,16,"IMT407G_IP:192.168.1.240");  //开发板作为服务器时的IP
  32. //        LCD_DisplayString(20,130,16,"TCP_Server_PORT:2040 ");     //开发板作为服务器时的端口号
  33.
  34.         ETH_BSP_Config();     //DP83848相关IO初始化与ETH相关初始化
  35.         LwIP_Init();          //LWIP初始化
  36.         TCP_server_init();    //初始化开发板为服务器
  37.         while (1)
  38.         {
  39.      LwIP_Periodic_Handle(LocalTime);                   /* handle periodic timers for LwIP */
  40.   }
  41. }
  42. /**
  43.   * @brief  Inserts a delay time.
  44.   * @param  nCount: number of 10ms periods to wait for.
  45.   * @retval None
  46.   */
  47. void Delay(uint32_t nCount)
  48. {
  49.   /* Capture the current local time */
  50.   timingdelay = LocalTime + nCount;
  51.   /* wait until the desired delay finish */
  52.   while(timingdelay > LocalTime)
  53.   {
  54.   }
  55. }
  56. /**
  57.   * @brief  Updates the system local time
  58.   * @param  None
  59.   * @retval None
  60.   */
  61. void Time_Update(void)
  62. {
  63.   LocalTime += SYSTEMTICK_PERIOD_MS;
  64. }
  65. #ifdef  USE_FULL_ASSERT
  66. /**
  67.   * @brief  Reports the name of the source file and the source line number
  68.   *   where the assert_param error has occurred.
  69.   * @param  file: pointer to the source file name
  70.   * @param  line: assert_param error line source number
  71.   * @retval None
  72.   */
  73. void assert_failed(uint8_t* file, uint32_t line)
  74. {
  75.   /* User can add his own implementation to report the file name and line number,
  76.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  77.   /* Infinite loop */
  78.   while (1)
  79.   {}
  80. }
  81. #endif
TCP服务器数据收发实验.7z (613.2 KB, 下载次数: 44)
作者: daichenghe    时间: 2019-7-30 09:10
为什么PC无法连接上啊?
