/*将数据写入AT24C02的0地址处,再读出,并用数码管显示*/
#include"reg51.h"
sbit SDA=P2^0;
sbit SCL=P2^1;
sbit duan=P2^6;
sbit wei=P2^7;
void delay()
void init()
{SCL=1;
SDA=1;
delay();
void start()
{SDA=1;
delay();
SCL=1;
delay();
SDA=0;
delay();
void stop()
{SDA=0;
delay();
SCL=1;
delay();
SDA=1;
delay();
void ack()
{unsigned char i;
SCL=1;
while((SDA==1)&&(i<255))i++;
SCL=0;
delay();
void write(unsigned char date)
{unsigned char i,temp;
temp=date;
for(i=0;i<8;i++)
{SCL=0;
delay();
temp<<=1;
SDA=CY;
delay();
SCL=1;
delay();
SCL=0;
delay();
SDA=1;
delay();
unsigned char read()
{unsigned char i,j;
SCL=0;
delay();
SDA=1;
delay();
for(i=0;i<8;i++)
{SCL=1;
delay();
j=(j<<1)|SDA;
SCL=0;
delay();
return j;
write_addr(unsigned char date,unsigned char addr)
{start();
write(0xa0);
ack();
write(addr);
ack();
write(date);
ack();
stop();
unsigned char read_addr(unsigned char addr)
{unsigned char i;
start();
write(0xa0);
ack();
write(addr);
ack();
start();
write(0xa1);
ack();
i=read();
stop();
return i;
void shumaguan(unsigned char dat,unsigned char addr)
{unsigned char ziku[18]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
unsigned char wzk[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
duan=0;
P0=wzk[addr];
wei=1;
wei=0;
P0=ziku[dat];
duan=1;
delay();
P0=0;
duan=0;
main()
{unsigned char i;
init();
write_addr(0x11,0);
i=read_addr(0);
{shumaguan(i%10,0);
shumaguan(i/10%10,1);
shumaguan(i/100,2);
我调试成功的,只是写的:
void IIC_START()
//DAT_PIN_OUT();
SDIO=1;
NOP();
SCLK=1;
NOP();
SDIO=0;
NOP();
SCLK=0;
void IIC_STOP()
//DAT_PIN_OUT();
SCLK=0;
NOP();
SDIO=0;
NOP();
SCLK=1;
NOP();
SDIO=1;
void IIC_ACK()
SCLK=0;
NOP();
NOP();
NOP();
_pbc = 0b10111111; //DAT_PIN_IN();
SDIO=1;
NOP();
NOP();
SCLK=1;
NOP();
NOP();
if(SDIO){
NOP();
SCLK=0;
_pbc = 0b00111111; //DAT_PIN_OUT();
SDIO=0;
SCLK=0;
//-----------------写一字节数据---------------------
void IICWrByte(uchar DAT)
uchar i;
//DAT_PIN_OUT();
NOP();
for(i=0;i<8;i++) {
NOP();
SCLK=0;
NOP();
if(DAT & 0X01){
SDIO=1;
else {
SDIO=0;
NOP();
SCLK=1;
NOP();
SCLK=0;
DAT >>= 1;
不好意思,后面那段发错了,不是24C02的!一般用示波器看就可以找出问题来的!
IIC的器件的通信协议是一样的。都可以通用的。有些新的器件速度高一些,和速度低得比较,可以加少一些空操作(NOP)。但低速器件的程序可以用在高速器件上。
楼主的程序不是一点两点的问题。
在IIC协议中,不管是主控器件还是从器件,1、向总线发送一个字节数据后,就要检查应答信号,看看接收器件是否“字节接受完成”。
2、接收器件正确接收到一个字节的数据后,也要发送一个应答信号(1bit),告诉发送器件“字节接收完成”
如果接收器件接收不正确,则不会发送应答信号。发送器件就检测不到“应答信号”,这时就要从“开始”步骤重来。
这里就有了这么几个环节:“应答信号(1bit,低位)”、“非应答信号(1bit,高位)、“检测应答信号”。
读的流程:1发送开始信号-->2发送器件地址(含“写”指令位)-->3检测应答-->4发送字节地址-->5检测应答-->6发送开始信号(含“读”指令位)
-->7检测应答-->8读一个字节-->(9发送应答信号-->......(重复第8步)读第2~N字节)-->发送非应答信号-->发送停止信号
写的流程:1发送开始信号-->2发送器件地址(含“写”指令位)-->3检测应答-->4发送字节地址-->5检测应答-->6写一个字节-->7检测应答信号
-->(......(重复第6步)写第2~N字节-->(重复第7步)检测应答信号-->)发送停止信号
如果是单字节读写括号内不用。
