STC15F2K60S2最小系统加pcf8591程序 +lcd1602液晶显示程序
承蒙关照
2019-7-24 15:49
#include <STC15F2K60S2.h>
#include <iic.h>
void Timer0Init(void) //1毫秒@11.0592MHz
AUXR |= 0x80; //定时器时钟1T模式
TMOD &= 0xF0; //设置定时器模式
TL0 = 0xCD; //设置定时初值
TH0 = 0xD4; //设置定时初值
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
EA =1 ;
ET0=1;
bit flag500ms = 0;
unsigned char code str1[] = "Kingst Studio";
unsigned char code str2[] = "Let's move...";
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y,unsigned char *str, unsigned char len);
unsigned char i = 0;
unsigned char index = 0;
unsigned char pdata bufMove1[16 + sizeof(str1) + 16];
unsigned char pdata bufMove2[16 + sizeof(str2) + 16];
unsigned char adc_val;
unsigned char str[10];
P2=0xa0;P0=0;P2=0;
Timer0Init();
InitLcd1602();
write_adc(0x00);
for(i=0; i<16; i++)
bufMove1[i] = ' ';
bufMove2[i] = ' ';
for(i=0; i<(sizeof(str1)-1); i++)
bufMove1[16 + i] = str1[i];
bufMove2[16 + i] = str2[i];
for(i=(16 + sizeof(str1)-1); i<sizeof(bufMove1); i++)
bufMove1[i] = ' ';
bufMove2[i] = ' ';
while (1)
if (flag500ms) //??500msò??ˉò?′??á??
flag500ms = 0;
adc_val=read_adc(0x00);
str[0] = adc_val/100+'0';
str[1] = adc_val/10%10+'0';
str[2] = adc_val%10+'0';
// LcdShowStr(0,0,str,3);
LcdShowStr(0, 0, bufMove1 + index, 16);
LcdShowStr(0, 1, bufMove2 + index, 16);
index++;
if(index >= (16 + sizeof(str1)-1))
index = 0;
void InterruptTimer0() interrupt 1
static unsigned int tmr500ms = 0;
tmr500ms++;
if (tmr500ms >= 500)
tmr500ms = 0;
flag500ms = 1;
}#include <STC15F2K60S2.h>
#include <iic.h>
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
EA =1 ;
ET0=1;
bit flag500ms = 0;
P2=0xa0;P0=0;P2=0;
Timer0Init();
InitLcd1602();
write_adc(0x00);
for(i=0; i<16; i++)
bufMove1[i] = ' ';
bufMove2[i] = ' ';
bufMove1[i] = ' ';
bufMove2[i] = ' ';
while (1)
flag500ms = 0;
index++;
index = 0;
tmr500ms++;
tmr500ms = 0;
flag500ms = 1;
#include <reg52.h>
#define LCD1602_DB P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E = P1^2;
/* 等待液晶准备好 */
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do {
LCD1602_E = 1;
sta = LCD1602_DB; //读取状态字
LCD1602_E = 0;
} while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
/* 向LCD1602液晶写入一字节命令,cmd-待写入命令值 */
void LcdWriteCmd(unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
/* 向LCD1602液晶写入一字节数据,dat-待写入数据值 */
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
/* 设置显示RAM起始地址,亦即光标位置,(x,y)-对应屏幕上的字符坐标 */
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if (y == 0) //由输入的屏幕坐标计算显示RAM的地址
addr = 0x00 + x; //第一行字符地址从0x00起始
addr = 0x40 + x; //第二行字符地址从0x40起始
LcdWriteCmd(addr | 0x80); //设置RAM地址
/* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,
str-字符串指针,len-需显示的字符长度 */
LcdSetCursor(x, y); //设置起始地址
while (len--) //连续写入len个字符数据
LcdWriteDat(*str++); //先取str指向的数据,然后str自加1
/* 初始化1602液晶 */
void InitLcd1602()
LcdWriteCmd(0x38); //16*2显示,5*7点阵,8位数据接口
LcdWriteCmd(0x0C); //显示器开,光标关闭
LcdWriteCmd(0x06); //文字不动,地址自动+1
LcdWriteCmd(0x01); //清屏
#ifndef _IIC_H
#define _IIC_H
//函数声明
void IIC_Start(void);
void IIC_Stop(void);
void IIC_Ack(bit ackbit);
void IIC_SendByte(unsigned char byt);
bit IIC_WaitAck(void);
unsigned char IIC_RecByte(void);
void write_adc(unsigned char add);
unsigned char read_adc(unsigned char add);
#endif
程序说明: IIC总线驱动程序
软件环境: Keil uVision 4.10
硬件环境: CT107单片机综合实训平台 8051,12MHz
日 期: 2011-8-9
#include "reg52.h"
#include "intrins.h"
#define DELAY_TIME 12
#define SlaveAddrW 0xA0
#define SlaveAddrR 0xA1
//总线引脚定义
sbit SDA = P2^1; /* 数据线 */
sbit SCL = P2^0; /* 时钟线 */
void IIC_Delay(unsigned char i)
do{_nop_();}
while(i--);
//总线启动条件
SDA = 1;
SCL = 1;
IIC_Delay(DELAY_TIME);
SDA = 0;
SCL = 0;
//总线停止条件
void IIC_Stop(void)
SDA = 0;
SCL = 1;
SDA = 1;
//发送应答
void IIC_SendAck(bit ackbit)
SCL = 0;
SDA = ackbit; // 0:应答,1:非应答
SCL = 1;
SCL = 0;
SDA = 1;
//等待应答
bit ackbit;
SCL = 1;
ackbit = SDA;
SCL = 0;
return ackbit;
//通过I2C总线发送数据
unsigned char i;
for(i=0; i<8; i++)
SCL = 0;
if(byt & 0x80) SDA = 1;
else SDA = 0;
SCL = 1;
byt <<= 1;
SCL = 0;
//从I2C总线上接收数据
unsigned char i, da;
for(i=0; i<8; i++)
SCL = 1;
da <<= 1;
if(SDA) da |= 1;
SCL = 0;
return da;
IIC_Start();
IIC_SendByte(0x90);
IIC_WaitAck();
IIC_SendByte(add);
IIC_WaitAck();
IIC_Stop();
unsigned char temp;
IIC_Start();
IIC_SendByte(0x90);
IIC_WaitAck();
IIC_SendByte(add);
IIC_WaitAck();
IIC_Start();
IIC_SendByte(0x91);
IIC_WaitAck();
temp=IIC_RecByte();
IIC_WaitAck();
IIC_Stop();
return temp;
admin
2019-7-24 16:48
补全原理图或者详细说明一下电路连接即可获得100+黑币
IdeaMing
2020-3-20 10:38
好像看看效果
lm9417
2020-7-25 13:15
1602读写程序里不用做延时也可以显示吗? STC15的速度不是快于1602吗?
