标题: N76E003 uart 参考代码 [打印本页]
作者: liyi519    时间: 2019-8-23 18:04
N76E003 uart 参考代码:
  1. #include "N76E003.h"
  2. #include "Common.h"
  3. #include "Delay.h"
  4. #include "SFR_Macro.h"
  5. #include "Function_define.h"
  6. /******************************************************************************
  7. * FUNCTION_PURPOSE: Serial interrupt, echo received data.
  8. * FUNCTION_INPUTS : P0.7(RXD) serial input
  9. * FUNCTION_OUTPUTS: P0.6(TXD) serial output
  10. * Following setting in Common.c
  11. ******************************************************************************/
  12. #if 0
  13. //void InitialUART0_Timer1(UINT32 u32Baudrate)    //T1M = 1, SMOD = 1
  14. //{
  15. //                P06_Quasi_Mode;
  16. //                P07_Quasi_Mode;
  17. //
  18. //    SCON = 0x52;     //UART0 Mode1,REN=1,TI=1
  19. //    TMOD |= 0x20;    //Timer1 Mode1
  20. //
  21. //    set_SMOD;        //UART0 Double Rate Enable
  22. //    set_T1M;
  23. //    clr_BRCK;        //Serial port 0 baud rate clock source = Timer1
  24. //
  25. //#ifdef FOSC_160000
  26. //    TH1 = 256 - (1000000/u32Baudrate+1);               /*16 MHz */
  27. //#endif
  28. //    set_TR1;
  29. //}
  30. ////---------------------------------------------------------------
  31. //void InitialUART0_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
  32. //{
  33. //                P06_Quasi_Mode;
  34. //                P07_Quasi_Mode;
  35. //
  36. //    SCON = 0x52;     //UART0 Mode1,REN=1,TI=1
  37. //    set_SMOD;        //UART0 Double Rate Enable
  38. //    T3CON &= 0xF8;   //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)
  39. //    set_BRCK;        //UART0 baud rate clock source = Timer3
  40. //#ifdef FOSC_160000
  41. //        RH3    = HIBYTE(65536 - (1000000/u32Baudrate)-1);                  /*16 MHz */
  42. //  RL3    = LOBYTE(65536 - (1000000/u32Baudrate)-1);                        /*16 MHz */
  43. //#endif
  44. //    set_TR3;         //Trigger Timer3
  45. //}
  46. #endif
  47. /*******************************************************************************
  48. * FUNCTION_PURPOSE: Main function
  49. ******************************************************************************/
  50. void main (void)
  51. {
  52. #if 0
  53.     InitialUART0_Timer1(9600);           //UART0 Baudrate initial,T1M=0,SMOD=0
  54.     while(1)
  55.     Send_Data_To_UART0(0x55);
  56. #else
  57.                 InitialUART0_Timer3(115200);
  58.     while(1)
  59.     Send_Data_To_UART0(0x55);
  60. #endif
  61.
  62.
  63.
  64. }
全部资料51hei下载地址:
UART0.zip (130.08 KB, 下载次数: 19)
