标题: STM32按键执行程序 [打印本页]
作者: WR111222    时间: 2019-8-28 15:39
标题: STM32按键执行程序
自己编写的按键执行程序,实现上翻、下翻、功能、确认、返回的功能。新手编写,高手绕道!
  1. #include "stm32f10x.h"
  2. #include "stdio.h"
  3. #include "tm1620.h"
  4. #include "common.h"
  5. #include "KeyScan.h"
  6. #include "delay.h"
  7. #include "Keyexec.h"
  8. #include "tim.h"
  9. ErrorStatus HSEStartUpStatus;
  10. void RCC_Configuration(void);
  11. void NVIC_Configuration(void);
  12. #ifdef  DEBUG
  13. /*******************************************************************************
  14. * Function Name  : assert_failed
  15. * Description    : Reports the name of the source file and the source line number
  16. *                  where the assert error has occurred.
  17. * Input          : - file: pointer to the source file name
  18. *                  - line: assert error line source number
  19. * Output         : None
  20. * Return         : None
  21. *******************************************************************************/
  22. void assert_failed(u8* file, u32 line)
  23. {
  24.   /* User can add his own implementation to report the file name and line number */
  25.   printf("\n\r Wrong parameter value detected on\r\n");
  26.   printf("       file  %s\r\n", file);
  27.   printf("       line  %d\r\n", line);
  28.
  29.   /* Infinite loop */
  30.   /* while (1)
  31.   {
  32.   } */
  33. }
  34. #endif
  35. void RCC_Configuration(void)
  36. {
  37.   /* RCC system reset(for debug purpose) */
  38.   RCC_DeInit();//复位RCC时钟
  39.   /* Enable HSE */
  40.   RCC_HSEConfig(RCC_HSE_ON);//RCC配置
  41.   /* Wait till HSE is ready */
  42.   HSEStartUpStatus = RCC_WaitForHSEStartUp();
  43.   if(HSEStartUpStatus == SUCCESS)
  44.   {
  45.     /* HCLK = SYSCLK */
  46.     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  47.
  48.     /* PCLK2 = HCLK */
  49.     RCC_PCLK2Config(RCC_HCLK_Div1);//72Mhz
  50.     /* PCLK1 = HCLK/2 */
  51.     RCC_PCLK1Config(RCC_HCLK_Div2);
  52.
  53.                 RCC_ADCCLKConfig(RCC_PCLK2_Div6);//ADC时钟   72/6=12M
  54.     /* Flash 2 wait state */
  55.     FLASH_SetLatency(FLASH_Latency_2);
  56.     /* Enable Prefetch Buffer */
  57.     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  58.     /* PLLCLK = 8MHz * 9 = 72 MHz */
  59.     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  60.     /* Enable PLL */
  61.     RCC_PLLCmd(ENABLE);
  62.     /* Wait till PLL is ready */
  63.     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  64.     {
  65.     }
  66.     /* Select PLL as system clock source */
  67.     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  68.     /* Wait till PLL is used as system clock source */
  69.     while(RCC_GetSYSCLKSource() != 0x08)
  70.     {
  71.     }
  72.   }
  73. }
  74. /*******************************************************************************
  75. * Function Name  : NVIC_Configuration
  76. * Description    : Configures Vector Table base location.
  77. * Input          : None
  78. * Output         : None
  79. * Return         : None
  80. *******************************************************************************/
  81. void NVIC_Configuration(void)
  82. {
  83. #ifdef  VECT_TAB_RAM
  84.   /* Set the Vector Table base location at 0x20000000 */
  85.   NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  86. #else  /* VECT_TAB_FLASH  */
  87.   /* Set the Vector Table base location at 0x08000000 */
  88.   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x9000);
  89. #endif
  90. }
  91. void IWDG_Configuration(void)
  92. {
  93.         IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);//启动寄存器读写
  94.         IWDG_SetPrescaler(IWDG_Prescaler_32);//40K时钟32分频
  95.         IWDG_SetReload(0xfff);                 //计数器数值         819.2ms
  96.         IWDG_ReloadCounter();                //重启计数器
  97.         IWDG_Enable();                       //启动看门狗
  98. }
  99. u8 Value;
  100. u8 Value1;
  101. u8 Value2;
  102. u8 Value3;
  103. int main(void)
  104. {
  105.         RCC_Configuration();
  106.         //NVIC_Configuration();
  107.         __set_FAULTMASK(0);  //打开所有中断
  108.         IOOUT_Init();
  109.         TM1616_init();
  110.         KeyScan_Init();
  111.   Timer3_Init(49);
  112.   Timer2_Init(9999);
  113.         while(1)
  114.         {
  115.                  key_function();
  116.                  key_execute();
  117.   }
  118.
  119. }
按键执行程序.7z (182.27 KB, 下载次数: 23)
