EXYNOS4412音乐盒程序设计
weres
2019-9-9 21:51
EXYNOS4412音乐盒程序设计
#include "exynos_4412.h"
void mydelay_ms(int ms);
#define S_CLK 125000
//125KHz
unsigned int sound[15] = {
0x00,
478,426,379,358,319,284,253,
235,213,190,179,159,142,127
//音符0~14
//半音符15~29 -> 0~14音频不变,音长变为二分之一
//连音符30
unsigned char dis[] = {
5,
1+7,30,15+1+7,1+7,3+7,
2+7,30,15+1+7,2+7,3+7,
1+7,30,15+1+7,3+7,5+7,
6+7,30,30,6+7,
5+7,30,15+3+7,3+7,1+7,
1+7,30,15+6,6,5,
1+7,30,30,
0xff
unsigned char dis3[] = {
7+1,7+1,
7+5,7+5,
7+6,7+6,
7+5,30,
7+4,7+4,
7+3,7+3,
7+2,7+2,
7+1,30,
7+5,7+5,
7+4,7+4,
7+3,7+3,
7+2,30,
7+5,7+5,
7+4,7+4,
7+3,7+3,
7+2,30,
7+1,7+1,
7+5,7+5,
7+6,7+6,
7+5,30,
7+4,7+4,
7+3,7+3,
7+2,7+2,
7+1,30,
0xff
void yin1()
unsigned int i;
for(i=0;dis[i] != 0xff;i++)
if(dis[i] != 30)
if(dis[i] < 15)
PWM.TCON = 0;
mydelay_ms(50);
PWM.TCNTB0 = sound[dis[i]];
PWM.TCMPB0 = sound[dis[i]] / 2;
//手动装载TCNTB0和TCMPB0
PWM.TCON = 2; //0010
//自动装载模式,启动定时器0
PWM.TCON = 9; //1001
mydelay_ms(450);
PWM.TCON = 0;
mydelay_ms(50);
PWM.TCNTB0 = sound[dis[i] - 15];
PWM.TCMPB0 = sound[dis[i] - 15] / 2;
//手动装载TCNTB0和TCMPB0
//自动装载模式,启动定时器0
mydelay_ms(200);
mydelay_ms(500);
void yin2()
unsigned int i;
for(i=0;dis3[i] != 0xff;i++)
if(dis3[i] != 30)
if(dis3[i] < 15)
PWM.TCON = 0;
mydelay_ms(100);
PWM.TCNTB0 = sound[dis3[i]];
PWM.TCMPB0 = sound[dis3[i]] / 2;
//手动装载TCNTB0和TCMPB0
//自动装载模式,启动定时器0
mydelay_ms(900);
PWM.TCON = 0;
mydelay_ms(100);
PWM.TCNTB0 = sound[dis3[i] - 15];
PWM.TCMPB0 = sound[dis3[i] - 15] / 2;
//手动装载TCNTB0和TCMPB0
//自动装载模式,启动定时器0
mydelay_ms(400);
mydelay_ms(1000);
void do_irq()
// 获取中断号
unsigned int irq_num = CPU0.ICCIAR & 0x3ff;
switch(irq_num)
case 57:
GPX2.DAT = GPX2.DAT | (1 << 7);
printf("This interrupt id is %d\n", irq_num);
yin1();
PWM.TCON = 0x8; // 自动重装
GPX2.DAT = GPX2.DAT & ~(1 << 7);
// PWM.TCON ^= 0x1;
// WDT.WTCON=WDT.WTCON|0x1<<0;
// WDT.WTCON=WDT.WTCON|0x1<<5;
//PWM.TCON = 0x2; // 手动装载
//PWM.TCON = 0x8; // 自动重装
EXT_INT41_PEND = 0x1 << 1; // 清pend(置1清0)
ICDICPR.ICDICPR1 = 0x1 << 25; // 清gic
break;
case 58:
GPF3.DAT = GPF3.DAT | (1 << 4);
// GPX2.DAT = GPX2.DAT ^ (0x1 << 7);
yin2();
GPF3.DAT = GPF3.DAT & ~(1 << 4);
EXT_INT41_PEND = 0x1 << 2; // 清pend(置1清0)
ICDICPR.ICDICPR1 = 0x1 << 26; // 清gic
break;
default:
printf("error!\n");
break;
// 把处理器中处理完的中断号返回给gic
// 告诉gic该中断处理结束,可以送入下一个pending进入
CPU0.ICCEOIR = (CPU0.ICCEOIR & ~(0x3ff)) | irq_num;
void peripheral_init()
GPX1.CON = 0xff << 4; // 配置GPIO为外部中断
EXT_INT41_CON = 0x22 << 4; // 下降沿触发中断
EXT_INT41_MASK = 0x0; // 使能相应外设
void gic_init()
ICDISER.ICDISER1 = 0x3 << 25; // 使能按键中断号
ICDIPTR.ICDIPTR14 = 0x0101 << 8; // 选择cpu接口
ICDDCR = 0x1; // 使能中断到分配器
CPU0.ICCICR = 0x1; // 把中断从cpu接口送入处理器
// 屏蔽中断优先级,255表示所有中断都允许通过
CPU0.ICCPMR = 0xff;
int i, j;
while(ms--)
for (i = 0; i < 5; i++)
for (j = 0; j < 500; j++);
void wdt_init(){
WDT.WTCON=WDT.WTCON&(~(0xff<<8))|(249<<8);
WDT.WTCON=WDT.WTCON&(~(0x3<<3))|(3<<3);
WDT.WTDAT=10000;
WDT.WTCNT=10000;
void pwm_init()
GPD0.CON = 0x2; // GPIO配置为TOUT_0
PWM.TCNTB0 = 1000;
PWM.TCMPB0 = 500;
PWM.TCFG0 = 0x63; // 预分频值为99 -> 100
PWM.TCFG1 = 0x3; // 二级分频为1/8
void led_init()
GPX2.CON = GPX2.CON & ~(0xf << 28) | (0x1 << 28);
GPF3.CON = GPF3.CON & ~(0xf << 16) | (0x1 << 16);
int main()
peripheral_init();
gic_init();
pwm_init();
led_init();
int i = 0;
mydelay_ms(800);
//WDT.WTCNT=30000;
return 0;
admin
2019-9-10 01:56
